Analiza LOG-ow 1.6 BFQ z gazem LR
  • Analiza LOG-ow 1.6 BFQ z gazem LR
    Hej,
    Czy ktos madry wypowiedzialby sie odnosnie logow ktore zgralem ?
    " VCDS-Lite Version: Release 1.2
    Tuesday, 25 April 2017, 10:18:36:0
    Chassis Type: 1U - Skoda Octavia I
    Scan: 01,02,03,08,15,16,17,19,22,29,35,36,37,39,46,56,76
    Address 01: Engine Labels: 06A-906-033-APF.LBL
    Controller: 06A 906 033 DM
    Component: SIMOS33 1.6l 2V 00HS7290
    Coding: 00231
    Shop #: WSC 73430
    VCID: 6DAD4AB73489
    2 Faults Found:
    16514 - Oxygen (Lambda) Sensor B1 S1: Malfunction in Circuit
    P0130 - 35-10 - - - Intermittent
    17831 - Secondary Air Injection System; Bank 1: Insufficient Flow
    P1423 - 35-10 - - - Intermittent
    Readiness: 0000 0000
    Address 03: ABS Brakes Labels: 1C0-907-37x-ABS.LBL
    Controller: 1C0 907 379 L
    Component: ABS FRONT MK60 0101
    Coding: 0001025
    Shop #: WSC 73430
    VCID: 33199CCF122D
    No fault code found.
    Address 08: Auto HVAC Labels: 1C0-907-37x-ABS.LBL
    Controller: 1U1 907 044 A
    Component: CLIMATRONIC
    VCID: 301393C3E33B
    Address 17: Instruments Labels: 1U0-920-xxx-17.LBL
    Controller: 1U0 920 811 B
    Component: KOMBI+WEGFAHRSP VDO V13
    Coding: 19113
    Shop #: WSC 73430
    VCID: 2D2D8AB7F409
    Address 19: CAN Gateway Labels: 6N0-909-901-19.LBL
    Controller: 6N0 909 901
    Component: Gateway K<->CAN 0001
    Coding: 00006
    Shop #: WSC 73430
    VCID: F093D3C3A3BB
    Address 46: Central Conv. Labels: 1C0-959-799.LBL
    Controller: 1C0 959 799 A
    Component: DR Komfortgerát HLO 0004
    Coding: 00067
    Shop #: WSC 73430
    VCID: 351DA2D71C59
    3 Faults Found:
    01044 - Control Module Incorrectly Coded
    35-00 - -
    00928 - Locking Module for Central Locking; Front Driver Side (F220)
    27-10 - Implausible Signal - Intermittent
    00929 - Locking Module for Central Locking; Front Passenger Side (F221)
    Address 76: Park Assist Labels: 6Y6-919-283.LBL
    Controller: 6Y6 919 283 A
    Component: Einparkhilfe 0001
    Coding: 00103
    Shop #: WSC 73430
    VCID: 46FFD51B71BF
    End --------------------------------------------------------------------------------------------------
    Ostatnio edytowany przez swiatus85; 27719.
  • #2
    Ten błąd miałem w BFQ przy nieszczelnym dolocie. Sławne dolne uszczelki kolektora, połączenie plastik - blok silnika. Długo szukałem rozwiązania. Dopiero użycie PLAKA potwierdziło moją diagnozę.
    Z tego co się orientuję błąd ten powodują też nieszczelne połączenia (rury) pompy napowietrzania spalin lub też uszkodzenie (często zalanie wodą) samej pompy.
    Jak widać błąd od lambdy ale cholera wie czy nie pochodna tego powyżej. Gdy zaburzony jest przepływ powietrza to i mieszanka jest do kitu. Co za tym idzie pewnie lambda może tez mieć dziwne odczyty.
    Wniosek:
    Sprawdź dolot.
    Ostatnio edytowany przez niezal; 14477.
    "coś być musi, do cholery, za zakrętem"
    O2 Tour BSE+LPG LR - MED
    POWRÓT NA GÓRĘ
