Błąd 03075 - jak usunąć
  • rodro
    • 238
    Jak w temacie, po uruchomieniu stacyjki pojawia się wykrzyknik przy ikonce kierownicy. Po chwili gaśnie i w trakcie jazdy już się nie pojawia. Wszystko funkcjonuje prawidłowo. Po usunięciu błąd wraca.
    Saturday,04,November,2017,13:39:31:10074
    VCDS Version: Release 10.6.4
    Data version: 20110418
    Chassis Type: 7N0
    Scan: 01 03 08 09 10 15 16 17 19 25 42 44 46 4C 52 56 62 72
    VIN: TMBCJ61Z2C2
    01-Engine -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    10-Park/Steer Assist -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    25-Immobilizer -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: Malfunction 0010
    46-Central Conv. -- Status: OK 0000
    4C-Tire Pressure II -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    56-Radio -- Status: OK 0000
    62-Door, Rear Left -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    Address 01: Engine (CAX) Labels: 03C-906-016-CAX.clb
    Part No SW: 03C 906 016 AK HW: 03C 906 016 C
    Component: MED17.5.5 G 9970
    Revision: LCH12--- Serial number:
    Coding: 0000072
    Shop #: WSC 22366 000 1048576
    VCID: 68DBBC9322E3
    No fault code found.
    Readiness: 0110 0000
    Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
    Part No SW: 1K0 907 379 BH HW: 1K0 907 379 BH
    Component: ESP MK60EC1 H31 0121
    Revision: 00H31001
    Coding: 113B201C092400FE881404EC901B0040360C00
    Shop #: WSC 73430 790 00085
    VCID: 79FDE9D74949
    Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
    Part No SW: 3T0 907 044 BK HW: 3T0 907 044 BK
    Component: Climatronic H18 0506
    Revision: 00001007
    Coding: 0100000002
    ASAM Dataset: EV_Climatronic A01010
    ROD: EV_Climatronic_SK35.rod
    VCID: 7CF3F0C3467B
    Part No SW: 1K0 937 087 Q HW: 1K0 937 087 Q
    Component: BCM PQ35 H 110 0651
    Revision: 00110 AC
    Coding: 46000AB8A00508C040080081110081E4450000AE524989605C 8440000040
    VCID: 3F8947CF17ED
    Part No: 1Z1 955 119 D
    Component: Wischer 18061 26 0601
    Coding: 00D7B7
    Address 10: Park/Steer Assist (J446) Labels: 5J0-919-475.clb
    Part No SW: 5J0 919 475 A HW: 5J0 919 475 A
    Component: PARKHILFE 4K H11 0005
    Revision: --H11--- Serial number: 32901117301329
    Coding: 10000E
    Shop #: WSC 13765 790 00085
    ASAM Dataset: EV_EPHVA14SKxxx0000 001001
    ROD: EV_EPHVA14SKxxx0000.rod
    VCID: 33611BFF2BA5
    Address 15: Airbags Labels: 1K0-909-605.lbl
    Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
    Component: Q6 AIRBAG VW8 020 2300
    Revision: 05020000 Serial number: 0038PD2RKWTU
    Coding: 0020790
    VCID: 3D753DC71DE1
    Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
    Part No SW: 5K0 953 521 BL HW: 5K0 953 569 C
    Component: LENKS.MODUL 014 0140
    Revision: FF010040 Serial number: 20110623301533
    Coding: 5080140000
    ASAM Dataset: EV_SMLSNGVOLWSXS A01004
    ROD: N/A
    VCID: 77F9EFEF7F5D
    No ASAM data for: "EV_SMLSNGVOLWSXS" (SK35)
    Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
    Part No SW: 1Z0 920 843 Q HW: 1Z0 920 843 Q
    Component: KOMBI H04 0607
    Serial number: 00000000000000
    Coding: 110A01
    ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04114
    ROD: EV_Kombi_UDS_VDD_RM09_SK35.rod
    VCID: 4687522B4837
    Address 19: CAN Gateway (J533) Labels: None
    Part No SW: 7N0 907 530 H HW: 1K0 907 951
    Component: J533 Gateway H42 1620
    Revision: H42 Serial number: 170611F1002383
    Coding: 351302
    VCID: 356525E725D1
    Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
    Part No SW: 5K0 953 234 HW: 5K0 953 234
    Component: IMMO H04 0607
    Coding: 000000
    Shop #: WSC 00000 000 00000
    ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03009
    ROD: EV_Immo_UDS_VDD_RM09_SK35.rod
    VCID: EADF469BBCEF
    Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
    Part No SW: 1T0 959 701 T HW: 1T0 959 701 T
    Component: Tuer-SG 009 2119
    Coding: 0000244
    VCID: 489B5C134223
    Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
    Part No: 1K0 909 144 M
    Component: EPS_ZFLS Kl. 68 3201
    Revision: 00H20000
    VCID: 346318E32EAB
    1 Fault Found:
    03075 - Parallel Parking Assistance Control Module (J791)
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 17
    Mileage: 68734 km
    Time Indication: 0
    Date: 2008.14.13
    Time: 13:32:31
    Freeze Frame:
    Voltage: 13.13 V
    DD
    Temperature: 12.0°C
    RPM: 0 /min
    Speed: 0.0 km/h
    Speed: 0.0 km/h
    Count: 0
    Address 4C: Tire Pressure II
    Cannot be reached
    Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
    Part No SW: 1T0 959 702 R HW: 1T0 959 702 R
    Coding: 0000244
    VCID: 47995F2F4F3D
    Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
    Part No SW: 1Z0 035 161 F HW: 1Z0 035 161 F
    Component: SWING 010 0082
    Revision: 0I001001 Serial number: SKZ1Z2L9063875
    Coding: 090002000204
    Shop #: WSC 20770 456 17823
    VCID: 316D11F7D1B9
    Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
    Part No SW: 5K0 959 703 A HW: 5K0 959 703 A
    Component: Tuer-SG 007 2101
    Coding: 0000144
    Shop #: WSC 73430 790 1012565
    VCID: 326F1EFBD4BF
    Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
    Part No SW: 5K0 959 704 A HW: 5K0 959 704 A
    Coding: 0000144
    VCID: 33611BFF2BA5
    End ---------------------------------------------------------------------
  • kowaltom99
    • 757
    W module 44 masz zakodowany asystent parkowania (a fizycznie go nie posiadasz).
    Wejdź w adaptacje modułu 44 i wyłącz park assistance. (jest w podpowiedziach VCDS-a)
    Ostatnio edytowany przez kowaltom99; 6234.
    • rodro
      • 238
      Dziękuję za odpowiedź, ale mam tam ustawioną wartość 0 - z podpowiedzi wynika, że tej wartości odpowiada brak asystenta.
      Spróbuję odłączyć akumulator, może ten sposób zadziała. Nie mam już innych pomysłów.
      • kowaltom99
        • 757
        Zamieszczone przez rodro Zobacz wpis
        I tu jest pies pogrzebany :-)
        Teraz zauważyłem, masz starą wersję VCDS z błędnymi podpowiedziami.
        Ustaw na "2" - to jest wartość wyłączająca.
        Poprawione podpowiedzi były w już wersji 11.11
        A004,5,Installation Park Steer Assist
        A004,6,0 = Park Steer Assist (PR-7X5/7X6) installed (< MY 2009 / PLA 1.0)
        A004,7,1 = Park Steer Assist (PR-7X5/7X6) installed (MY 2010 > / PLA 1.5/2.0)
        A004,8,2 = Park Steer Assist (PR-7X0/7X1/7X2) NOT installed
        • rodro
          • 238
          Serdecznie dziękuję Koledze kowaltom99, zadziałało, błąd wykasowany i nie powraca.
          Wniosek - muszę wymienić kabel na nowszy.
          • kowaltom99
            • 757
            No to super, że działa.
            Kabelek da się zaktualizować. Poszukaj topic "VCDS reaktywacja"
            Ale żeby na szybko mieć w miarę aktualne podpowiedzi w VCDS - ściągnij pliki lbl z chomika kolegi lusob i wklej do katalogu VCDS/LABELS/USER
            Chomikuj.pl to przyjazny serwis do przechowywania i udostępniania plików. Darmowa, nieograniczona przestrzeń i mnóstwo plików do pobrania.
