Iwan89, Masz centralny z pilota :?:
pare bledow, prosze o pomoc bo ja sie nie znam
moze ktos powiedziec co to sa za bledy ?
Monday,07,July,2014,20:46:23:10074
VCDS Version: Beta 11.2.0
Data version: Unknown
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 55 56 62 72 76 7D
VIN: TMBBE61Z058039514 Mileage: 196530km/122118miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: Malfunction 0010
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
7D-Aux. Heat -- Status: OK 0000
Address 01: Engine Labels: None
Part No SW: 03G 906 016 HF HW: 028 101 229 2
Component: R4 2,0L EDC G010SG 7000
Revision: 12345678 Serial number: SKZ7Z0E2970921
Coding: 0000072
Shop #: WSC 73430 790 00000
VCID: 6ED7CA8B0257
2 Faults Found:
17056 - Cylinder 2 Glow Plug Circuit (Q11): Electrical Fault
P0672 - 000 - -
Freeze Frame:
RPM: 0 /min
Torque: 282.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.48 V
Bin. Bits: 00101100
Temperature: -12.6°C
Bin. Bits: 00110000
18104 - Powertrain Data Bus: Implausible Message from Steering Column Controller
P1696 - 000 - - - Intermittent
Freeze Frame:
RPM: 0 /min
Torque: 134.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.63 V
Bin. Bits: 00101100
Bin. Bits: 11000000
(no units): 3.0
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: Redir Fail!
Part No: 1K0 907 379 K
Component: ESP FRONT MK60 0104
Coding: 0023170
VCID: 3A7F36DB0E9F
No fault code found.
Address 08: Auto HVAC Labels: None
Part No: 1Z0 907 044 J
Component: ClimatronicPQ35 084 0305
Shop #: WSC 00000 000 00000
VCID: 3D753DC71FB1
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 1K0 937 049 N HW: 1K0 937 049 N*
Component: Bordnetz-SG H34 0803
Revision: 00H34000 Serial number: 00000003040473
Coding: F18A8F381008140000110D000000000000187F0632
VCID: 3A7F36DB0E9F
Subsystem 1 - Part No: 1Z1 955 119 A
Component: Wischer SK351 012 0401
Coding: 00065525
Shop #: WSC 73430
Subsystem 2 - Part No: 1K0 955 559 M
Component: RegenLichtSens 005 0605
Coding: 00217125
Shop #: WSC 73430
Address 15: Airbags Labels: None
Part No SW: 1K0 909 605 M HW: 1K0 909 605 M
Component: Q2 AIRBAG VW8 024 0700
Revision: 07024000 Serial number: 0038DD0RKN0L
Coding: 0020786
VCID: 366722EB3A87
Address 16: Steering wheel Labels: None
Part No SW: 1K0 953 549 G HW: 1K0 953 549 G
Component: Lenksäulenmodul 021 0050
Coding: 0002042
VCID: 366722EB3A87
Part No: XXXXXXXXXXX
Component: Lenkradmodul 007 0050
1 Fault Found:
00888 - Wiper Switch for Intermittent Operation (E22)
014 - Defective
Address 17: Instruments Labels: None
Part No: 1Z0 920 841 D
Component: KOMBIINSTRUMENT VD1 0918
Coding: 0005101
Shop #: WSC 40711 146 18283
VCID: 37792FEF3D8D
Address 19: CAN Gateway Labels: None
Part No SW: 1K0 907 530 E HW: 1K0 907 951
Component: Gateway H11 0110
Revision: 11 Serial number: 29001054088435
Coding: 7D3F0F40071302
VCID: 295DF997FB39
Address 25: Immobilizer Labels: None
Component: IMMO VD1 0918
VCID: 37792FEF3D8D
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN1.lbl
Part No: 1T0 959 701
Component: Tuersteuergeraet 09 0165
Coding: 0000118
VCID: F4E358E3EC7B
1 Fault Found:
00928 - Locking Module for Central Locking; Front Driver Side (F220)
008 - Implausible Signal - Intermittent
Address 44: Steering Assist Labels: 1Kx-909-14x-44.lbl
Part No: 1K1 909 144 H
Component: EPS_ZFLS Kl.2 1502
VCID: 306B14F3D8E3
Address 46: Central Conv. Labels: 1K0-959-433-MIN.lbl
Part No: 1K0 959 433 AK
Component: KSG 0401
Coding: 00D002403F2D8505484FC61004C8
VCID: 79FDE9D74B19
Subsystem 5 - Part No: 1Z0 951 171 A
Component: NeigungsSensor 008 4802
Coding: 00000000
Shop #: WSC 00000
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Component: Innenraumueberw.008 4802
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN1.lbl
Part No: 1T0 959 702
Coding: 0000118
VCID: F5E565E7E701
1 Fault Found:
00944 - Heated Exterior Mirror; Passenger Side (Z5)
012 - Electrical Fault in Circuit
Address 55: Xenon Range Labels: None
Part No: 1T0 907 357
Component: Dynamische LWR 0002
Coding: 0000007
VCID: F4E358E3EC7B
Address 56: Radio Labels: None
Part No SW: 1Z0 035 161 A HW: 01. 01. 03
Component: Radio FO3 1008
Coding: 0000400
Shop #: WSC 40711 150 82544
VCID: 2C530083F4CB
Address 62: Door, Rear Left Labels: None
Part No: 1K0 959 703 B
Component: Tuersteuergeraet 06 0219
Coding: 0000048
VCID: 2F69178FC5DD
1 Fault Found:
00934 - Electric Window Motor; Rear Left (V26)
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
Address 72: Door, Rear Right Labels: None
Part No: 1K0 959 704 B
Coding: 0000048
VCID: 306B14F3D8E3
Address 76: Park Assist Labels: None
Part No SW: 1Z0 919 283 B HW: 1Z0 919 283 B
Component: Parkhilfe 4-Kan H04 0020
Coding: 0000001
VCID: 3D753DC71FB1
Address 7D: Aux. Heat Labels: None
Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
Component: PTC-Element 0404
Revision: 00800000 Serial number:
VCID: 2D550D87CFD1
End ---------------------------------------------------------------------
jesli wpisalem nie w tym poscie to prosze o wyrozumialosc i przeniesc temat do odpowiedniego postu
Druga świeca żarowa może być spalona, lub styk uszkodzony, drugi błąd w silniku jeśli dobrze kojarzę jest jak manetka tempomatu chyba szwankuje. Manetka wycieraczek a raczej pokrętło do regulacji częstotliwości może być też do wyczyszczenia.
Szkło lusterka po stronie pasażera ma wypalone grzanie lub kabel ułamany.
Tylne lewe drzwi potrzebują adaptacji końcowych położeń szyby. Robi się to przyciskami w drzwiach kierowcy. Należy to zrobić tak, zjechać szybą do końca w dół i przytrzymać guzik wciśnięty na około 2 sekundy jak już do końca szyba dojedzie i to samo w górę razem z przytrzymaniem guzika na 2 sekundy po dojechaniu szyby do końca.http://chomikuj.pl/lusob/VCDS
drzwi kierowcy - mikrostyk/czujnik zamknięcia drzwi do reanimacji lub wymiana zamka lub uszkodzona wiązka do drzwi->Usługi elektroniki/małej mechaniki VAG, usługi IT
no to tak jak myslalem w dzwiach to same pierdoly, ale najbardziej chodzilo mi o te bledy w silniku i w kierownicy, naszczescie nic powaznego z tego co mowicie.
Swiece sie sprawdzi, manetka faktycznie czasami szwankuje i nie da sie wlaczyc tempomatu, pokretlo do regulacji szybkosci wycieraczek zdaje sie wogole nie dzialac, lusterko nie grzeje bo jest klejone ( to samo bylo z druga strona, po wymianie grzeje), adaptacje zaraz zrobie (dzieki za info jak to zrobic), a w drzwiach kierowcy tez czujnik poszedl bo nie daje znaku otwartch drzwi na MFA no ale czasem da znac ze dziala (po mimo zamknietych drzwi, da sygnal ze sa otwarte) np w nocy i alarm budzi wszystkich do okola
Dziekuje wam za pomoc
Witam, znowu potrzebuje waszej pomocy kupilem superba i wrzucilem go w domu na kompa oto lista bledow ktore mi pokazal VCDS
Saturday,21,October,2017,16:16:06:10074
Data version: 20110305
Chassis Type: 7N0
Scan: 01 03 05 08 09 10 15 16 17 19 22 25 2B 2E 36 37 42 44 46 47
52 55 56 62 6D 72 77
VIN: TMBLB93T0B9007837
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
22-AWD -- Status: Malfunction 0010
2B-Steer. Col. Lock -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
47-Sound System -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (CDA) Labels: 06J-907-115-CDA.clb
Part No SW: 3T0 907 115 G HW: 1Z0 907 115 F
Component: 1.8l R4/4V TFSI 0030
Revision: AAH17--- Serial number:
Coding: 0203000C180F0160
Shop #: WSC 00320 223 96732
VCID: 356525E72781
1 Fault Found:
000665 - Boost Pressure Regulation: Control Range Not Reached
P0299 - 000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 1
Mileage: 190862 km
Time Indication: 0
Date: 2000.14.11
Time: 07:34:20
Freeze Frame:
RPM: 2370 /min
Load: 84.7 %
Speed: 80.0 km/h
Temperature: 95.0°C
Temperature: 21.0°C
Absolute Pres.: 960.0 mbar
Voltage: 13.843 V
Readiness: 0000 0000
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AT HW: 1K0 907 379 AT
Component: ESP MK60EC1 H30 0105
Revision: 00H30001
Coding: 843D601619220001211306E798200041350000
Shop #: WSC 33361 790 00070
VCID: 84030823BCDB
Address 05: Acc/Start Auth. (J513) Labels: 5K0-959-434.clb
Part No SW: 5K0 959 434 HW: 5K0 959 434
Component: VWKESSYPQ35GP 082 0707
Revision: 00082000 Serial number: 0000000000
Coding: 030C0C
Shop #: WSC 33361 074 00070
ASAM Dataset: EV_KESSY_PQ35GP A01010
ROD: EV_KESSY_PQ35GP_SK46.rod
VCID: F2EF5EFB966F
2 Faults Found:
1052936 - Touch Sensor on Exterior Door Grip; Driver Side
B116B 29 [008] - Bus Signal/Message Failure
Freeze Frame:
Fault Status: 00000001
Fault Priority: 4
Fault Frequency: 1
Reset counter: 101
Mileage: 190651 km
Date: 2014.14.24
Time: 08:01:57
1057035 - Antenna for Keyless Entry System; Drivers Side
B116F 13 [009] - Reserved by ISO 15031-6:2005
Freeze Frame:
Fault Priority: 4
Fault Frequency: 5
Reset counter: 54
Mileage: 187669 km
Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
Part No SW: 3T0 907 044 BC HW: 3T0 907 044 BC
Component: Climatronic H15 0401
Revision: 00005001
Coding: 0000000002
Shop #: WSC 33361 790 00999
ASAM Dataset: EV_Climatronic A01006
ROD: EV_Climatronic_SK46.rod
VCID: 74E3D8E36C7B
Part No SW: 1K0 937 087 P HW: 1K0 937 087 P
Component: BCM PQ35 H+ 104 0615
Revision: 00104 AE
Coding: 46190AB8E85BF1C040080080110089E4427100AE776D8FF05C 014000A040
VCID: 3E773ACB12B7
Subsystem 1 - Part No: 3T1 955 119
Component: Wischer 01061 22 0602
Coding: 00D7B7
Subsystem 2 - Part No: 1K0 955 559 AH
Component: RLS 290510 05 54 0403
Coding: 072BED
Subsystem 3 - Part No: 7N0 951 171
Component: DWA-Sensor 00 002 0205
Subsystem 4 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Address 10: Park/Steer Assist (J791) Labels: 1T0-919-475.clb
Part No SW: 3T0 919 475 A HW: 3T0 919 475
Component: PARKHILFE PLA H07 0003
Revision: -------- Serial number: 78331014000098
Coding: 100008
VCID: 3B7133DF01A5
Address 15: Airbags Labels: 5N0-959-655.lbl
Part No SW: 3T0 959 655 B HW: 3T0 959 655 B
Component: J234__LCR VW10 HI 1916
Revision: 19014000 Serial number: 003GRPAJRB3C
Coding: 0017234
VCID: 408B44336843
Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
Part No SW: 5K0 953 521 BR HW: 5K0 953 569 E
Component: LENKS.MODUL 009 0136
Revision: FF010036 Serial number: 20100515200056
Coding: 100A140000
ASAM Dataset: EV_SMLSNGVOLWS A01004
ROD: EV_SMLSNGVOLWS_SK46.rod
VCID: 7DF5FDC75F31
MFL:
Subsystem 1 - Part No SW: 3T0 959 537 HW: 3T0 959 537
Component: E221__MFL-URO H07 0012
Coding: 820000
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 3T1 920 841 G HW: 3T1 920 841 G
Component: KOMBI H04 0406
Serial number: 00000000000000
Coding: 111F01
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04089
ROD: EV_Kombi_UDS_VDD_RM09_SK46.rod
VCID: 37792FEF3D8D
Address 19: CAN Gateway Labels: 7N0-907-530-V1.clb
Part No SW: 7N0 907 530 HW: 1K0 907 951
Component: J533 Gateway H27 0602
Revision: H27 Serial number: 290510F2001565
Coding: E9A3FF0652061203009302
VCID: EDD54D878F51
Address 22: AWD Labels: Redir Fail!
Part No SW: 0BR 907 554 B HW: 0BR 907 554 B
Component: Haldex 4Motion 3017
Coding: 0000005
VCID: 448348237C5B
1 Fault Found:
01155 - Clutch
003 - Mechanical Failure - Intermittent
Freeze Frame:
Fault Status: 10000011
Fault Priority: 2
Fault Frequency: 57
Reset counter: 48
Mileage: 3618101 km
Time Indication: 4
Freeze Frame:
Time: 0.00 s
Raw, Form. N/A: 000 000 000
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H04 0406
Coding: 000007
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03008
ROD: EV_Immo_UDS_VDD_RM09_SK46.rod
VCID: EADF469BBEBF
Address 2B: Steer. Col. Lock (J764) Labels: 5K0-905-861.clb
Part No SW: 5K0 905 861 HW: 5K0 905 861
Component: ELV-PQ35 018 0100
Revision: 00000000 Serial number: 10000084425003
Coding: 0100000000000000
ASAM Dataset: EV_ELVMarquVW360UDS A01003
ROD: EV_ELVMarquVW360UDS_SK46.rod
VCID: EDD54D878F51
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 C HW: 5N0 035 342 C
Component: SG EXT.PLAYER H13 0111
Revision: A1001003 Serial number: 7668084870
Coding: 010000
VCID: 2759FFAFED2D
Address 36: Seat Mem. Drvr Labels: 3C0-959-760.lbl
Part No SW: 3C8 959 760 HW: 3C8 959 760
Component: J810 0801
Revision: 00002000 Serial number: 00000000000000
Coding: 0000003
VCID: F2EF5EFB966F
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 3T0 035 680 A HW: 3T0 035 680 A
Component: RNS-MID H06 2724
Revision: AB001001 Serial number: SKZ6Z7K9150014
Coding: 020600020000008100
ASAM Dataset: ------------------------- ------
VCID: 2E570A8BC2D7
Address 42: Door Elect, Driver (J386) Labels: 8X0-959-793.clb
Part No SW: 8X0 959 793 C HW: 8X0 959 793 C
Component: TSG FA H09 0409
Revision: -------- Serial number: --------------
Coding: 011D0220DE00001000
VCID: 4D956D07AF11
Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 195 3001
Revision: 00H17000
VCID: 316D11F7D3E9
Address 47: Sound System (R12) Labels: 3T0-035-456.clb
Part No SW: 3T0 035 456 HW: 3T0 035 456
Component: KonzernAmp10K H06 0342
Revision: -------- Serial number: BP218209142623
ASAM Dataset: EV_AudioVerst10KanalBNO1 A01003
ROD: EV_AudioVerst10KanalBNO1_SK46.rod
VCID: EED74A8B8257
Address 52: Door Elect, Pass. (J387) Labels: 8X0-959-792.clb
Part No SW: 8X0 959 792 C HW: 8X0 959 792 C
Component: TSG BF H09 0409
VCID: 4C936003540B
1 Fault Found:
02123 - Door Warning Light / Entry Light
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 111
Mileage: 190916 km
Time Indication: 0
Address 55: Xenon Range Labels: 5M0-907-357-V2.lbl
Part No SW: 5M0 907 357 C HW: 5M0 907 357 C
Component: AFS-Steuergeraet 0142
Revision: 00H04000 Serial number:
Coding: 1376839
VCID: 346318E32CFB
Subsystem 1 - Part No: 7L6 941 329 B
Component: AFS-Lst.-Modul l 0004
Coding: 00000021
Subsystem 2 - Part No: 7L6 941 329 B
Component: AFS-Lst.-Modul r 0004
Coding: 00000021
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
VCID: 2E570A8BC2D7
Address 62: Door, Rear Left (J388) Labels: None
Part No SW: 8X0 959 795 B HW: 8X0 959 795 B
Component: TSG HL H06 0409
Coding: 010C00200000001000
VCID: 4E976A0BA217
Address 6D: Trunk Elect. (----) Labels: 7N0-959-107.clb
Part No SW: 7N0 959 107 A HW: 7N0 959 107 A
Component: HDSG-Modul H11 0802
Revision: 41011001 Serial number: 141000031
Coding: 082301C002
ASAM Dataset: EV_HDSGSk462 301133
ROD: EV_HDSGSk462.rod
VCID: 356525E72781
Address 72: Door, Rear Right (J389) Labels: None
Component: TSG HR H06 0409
VCID: 4E976A0BA217
Address 77: Telephone (J412) Labels: 3C8-035-730-A.clb
Part No SW: 3C8 035 730 A HW: 3C8 035 730 A
Component: Telefon 007 0078
Revision: -------- Serial number: 35909603004528
Coding: 020100000100010000000000
ASAM Dataset: EV_UHVPremi A01005
ROD: EV_UHVPremi_SK46.rod
VCID: 214DE1B78309
Czy po wykasowaniu błędów, te wyżej wklejone powróciły?
Dobrze jakbyś napisał jakie są objawy usterek, np napęd 4x4, czy działa, czy nie?
ps. dobrze jest wrzucać tylko odczyty z błędami, te gdzie nie ma błędów tylko zamazują całokształt.
Mr Haldex - jak umiem to zawsze pomogę.
www.awdcarparts.com
Nie potrzebujesz trawnika.
Wyłącz ESP i rusz mocno, jak przód zerwie to znaczy że nie masz napędu.Mr Haldex - jak umiem to zawsze pomogę.
www.awdcarparts.com
Sczytaj jeszcze raz po kasowaniu błędów czy powróciły. Te błędy mają związek z centralnym zamkiem jak widać - klamka, odbiornik kluczyka i światło.Mr Haldex - jak umiem to zawsze pomogę.
www.awdcarparts.com
no wiec probowalem tak jak mowiles i przednie nie mieszaly auto mozna powiedziec ze wystrzelilo z miejsca, cos zasmierdzialo (chyba sprzeglo hehehe) ale po chwilii przestalo.
W domu podlaczylem do kompa i bledu haldexa nie bylo szkoda ze reszta swieci nadal. W Haldexie tak czy siak wymienie olej i filtry bedzie spokoj na jakis czas.
Dzieki za pomoc.
Przy wymianie oleju w Haldexie wyczyść magnes i wymień sobie olej w dyfrze. pzdrMr Haldex - jak umiem to zawsze pomogę.
www.awdcarparts.com
Widzisz ten temat - zdjęcia? Mr Haldex sie obrazil - mozna z tym jezdzic? - Strona 4Mr Haldex - jak umiem to zawsze pomogę.
www.awdcarparts.com
