VCDS - bledy
  • VCDS - bledy
    Niedawno wszedlem w posiadanie VCDS 17.8 i zrobilem skan automatyczny co zaksutkowalo ponizszym:
    Saturday,07,March,2020,12:47:03:00001
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
    VCDS Version: 17.8.0.1 (x64)
    Data version: 20170721 DS276.2
    Ross-Tech: Home
    VIN: TMBAC7NE0F0022422 License Plate:
    Mileage: 156082km-96984mi Repair Order:
    Chassis Type: NE-SK37 (5Q0)
    Scan: 01 03 08 09 10 15 16 17 19 42 44 52 5F
    VIN: TMBAC7NE0F0022422 Mileage: 156082km-96984miles
    01-Engine -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    08-Auto HVAC -- Status: Malfunction 0010
    09-Cent. Elect. -- Status: OK 0000
    10-Park/Steer Assist -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: Malfunction 0010
    52-Door Elect, Pass. -- Status: OK 0000
    5F-Information Electr. -- Status: Cannot be reached 0100
    Address 01: Engine (J623-CHPA) Labels:. 04E-907-309-V1.clb
    Part No SW: 04E 906 016 F HW: 04E 907 309 A
    Component: 1,4l R4 TSI X09 6186
    Revision: WAX09---
    Coding: 01190012232400080000
    Shop #: WSC 31952 002 1048576
    ASAM Dataset: EV_ECM14TFS01014E906016F 002009
    ROD: N/A
    VCID: 2540C90824E1076ED9-8070
    No ASAM data for: "EV_ECM14TFS01014E906016F" (SK37)
    1 Fault Found:
    10593 - ROD - Unknown Error Code
    - 00 [096]
    Intermittent - Not Confirmed - Tested Since Memory Clear
    Readiness: 0000 0000
    Address 03: ABS Brakes (J104) Labels:. 5Q0-907-379-ESP-V1.clb
    Part No SW: 5Q0 907 379 K HW: 5Q0 907 379 F
    Component: ESC H31 0371
    Revision: 00000000 Serial number: 61414000004597
    Coding: 1A076A912422096E007B060241C5245856249000608224B000 630070C002
    Shop #: WSC 73430 031 00063
    ASAM Dataset: EV_Braek1UDSContiMK100ESP 033001
    ROD: N/A
    VCID: 4486748CCF9BDE66EE-8010
    No ASAM data for: "EV_Braek1UDSContiMK100ESP" (SK37)
    No fault code found.
    Address 08: Auto HVAC (J255) Labels:. 5G0-907-044.clb
    Part No SW: 5E0 907 044 L HW: 5E0 907 044 L
    Component: Climatronic H03 0907
    Revision: 00001K06
    Coding: 01010004000100010005004000101000
    ASAM Dataset: EV_ACLcimaBHBVW37X 003017
    ROD: N/A
    VCID: 2E5236247117443628-807A
    No ASAM data for: "EV_ACLcimaBHBVW37X" (SK37)
    1 Fault Found:
    328197 - ROD - Unknown Error Code
    - 00 [009]
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 224
    Mileage: 146276 km
    Date: 2019.08.28
    Time: 06:59:05
    Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-HV1.clb
    Part No SW: 5Q0 937 084 AJ HW: 5Q0 937 084 AJ
    Component: BCM MQBAB H H18 0134
    Serial number: 01011414301696
    Coding: 0C000846404702FB47E04000001C0700000000000000000000 0000000000
    Shop #: WSC 73430 790 00161
    ASAM Dataset: EV_BCMCONTI 013000
    ROD: EV_BCMBOSCH_013.rod
    VCID: 000EB89C9B0302468A-8054
    Control Unit For Wiper Motor:
    Subsystem 1 - Part No SW: 5E1 955 119 HW: 5E1 955 119 Labels: 5QX-955-119-V1.CLB
    Component: WWS371 140511 041 0570
    Serial number: 140513202007
    Coding: 065DFD
    Rain Light Recognition Sensor:
    Subsystem 2 - Part No SW: 5Q0 955 547 A HW: 5Q0 955 547 A Labels: 5Q0-955-547.CLB
    Component: RLHS 037 0059
    Serial number: S5Y14M06D07H04M30S09
    Coding: 00885D
    Address 10: Park/Steer Assist (J791) Labels:. 5Q0-919-294.clb
    Part No SW: 5Q0 919 294 E HW: 5Q0 919 294 A
    Component: PARKHILFE 8K H03 0048
    Revision: -------- Serial number: 94231415203898
    Coding: 0031051001
    Shop #: WSC 73430 790 00063
    ASAM Dataset: EV_EPHV1A8AU3700000 002024
    ROD: N/A
    VCID: 3D700168AC71AFAEA1-8068
    No ASAM data for: "EV_EPHV1A8AU3700000" (SK37)
    Address 15: Airbags (J234) Labels:. 5Q0-959-655.clb
    Part No SW: 3Q0 959 655 AC HW: 3Q0 959 655 AC
    Component: Airbag VW20 012 0189
    Revision: -------- Serial number: 003P4PAEPNKK
    Coding: 98CCC000000000005C5400CC000800000065
    ASAM Dataset: EV_AirbaVW20ST6VW48X 001116
    ROD: N/A
    VCID: 7F0C3B60E6FD7DBEF3-802A
    Subsystem 1 - Part No SW: ----------- HW: 454 001 705 14
    Component: SideSensor_Df 008 0887
    Serial number: 3576U000000861B0EF0K
    Coding: 2D2D2D
    Subsystem 2 - Part No SW: ----------- HW: 454 001 705 14
    Component: SideSensor_Pf 008 0887
    Serial number: 3586U000000B4D90EF0W
    Coding: 2D2D2D
    Subsystem 3 - Part No SW: ----------- HW: 454 802 105 14
    Component: SideSensor_Dr 111 0148
    Serial number: 3516RA910A703000000$
    Coding: 2D2D2D
    Subsystem 4 - Part No SW: ----------- HW: 454 802 105 14
    Component: SideSensor_Pr 111 0148
    Serial number: 3526RA531A603000000
    Coding: 2D2D2D
    Subsystem 5 - Part No SW: ----------- HW: 454 801 204 14
    Component: FrontSensor_D 114 0149
    Serial number: 3556V385C84030000007
    Coding: 2D2D2D
    No ASAM data for: "EV_AirbaVW20ST6VW48X" (SK37)
    Address 16: Steering wheel (J527) Labels:| 5Q0-953-549.clb
    Part No SW: 5Q0 953 507 AC HW: 5Q0 953 549
    Component: Lenks. Modul 007 0070
    Revision: -------- Serial number: 08061404220306
    Coding: 1400
    ASAM Dataset: EV_SMLSKLOMQB 009001
    ROD: EV_SMLSKLOMQB_009_AU37.rod
    VCID: 77FCD340CECD45FEBB-8022
    Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb
    Part No SW: 5E0 920 740 HW: 5E0 920 740
    Component: KOMBI 204 4290
    Coding: 03A502002180000807007A001000000000000000
    Shop #: WSC 73430 031 00161
    ASAM Dataset: EV_DashBoardVDDMQBAB 009040
    ROD: EV_DashBoardVDDMQBAB_009_SK37.rod
    VCID: 60CE981C7B43A246EA-8034
    1 Fault Found:
    16777022 - Function Restricted due to Interrupted Communications
    U1110 00 [009] - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 2
    Reset counter: 197
    Mileage: 146276 km
    Date: 2019.08.28
    Time: 06:59:08
    Address 19: CAN Gateway (J533) Labels:| 5Q0-907-530-V1.clb
    Part No SW: 5Q0 907 530 S HW: 5Q0 907 530 E
    Component: GW MQB Mid 127 1188
    Revision: -------- Serial number: 0002070676
    Coding: 0101000820085700EF000208080F0000000105000000000000 0000000000
    ASAM Dataset: EV_GatewLear 011016
    ROD: EV_GatewLear_011.rod
    VCID: 41887D98D089CB4EC5-8014
    Alternator:
    Multi Function Steering Wheel Control Module:
    Subsystem 2 - Part No SW: 5E0 919 719 A HW: 5E0 919 719 A
    Component: E221__MFL-PR6 H04 0130
    Serial number: 000000000C0064310514
    1 Fault Found:
    131699 - Control unit for information electronics 1
    U1054 00 [009] - No Communication
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 224
    Mileage: 146276 km
    Date: 2019.08.28
    Time: 06:59:05
    Supply voltage: Terminal 30: 13.4 V
    Terminal 15: On
    Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb
    Part No SW: 5Q4 959 593 B HW: 5Q4 959 593 B
    Component: TSG FS 009 0014
    Serial number: 0000105021933
    Coding: 00110120D000040000001100
    ASAM Dataset: EV_DCUDriveSideEWMAXCONT 006001
    ROD: EV_DCUDriveSideEWMAXCONT_VW37.rod
    Drivers Door Rear Control Module:
    Subsystem 1 - Part No SW: 5Q0 959 811 A HW: 5Q0 959 811 A Labels: 5QX-959-81X-V1.CLB
    Component: FOND_FHSG_DRV 005 0005
    Serial number: 00000000000002882733
    Coding: 010200
    Address 44: Steering Assist (J500) Labels:| 5Q0-909-144.clb
    Part No SW: 5Q0 909 144 P HW: 5Q0 909 144 P
    Component: EPS_MQB_ZFLS 123 1043
    Coding: 0102
    ASAM Dataset: EV_SteerAssisMQB 010031
    ROD: EV_SteerAssisMQB_010.rod
    5 Faults Found:
    22272 - Databus
    U1121 00 [008] - Missing Message
    Intermittent - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 9
    Mileage: 146276 km
    Date: 2019.08.28
    Time: 06:59:05
    Motor status: 03
    System status: Driving mode
    Supply voltage: 13.25 V
    Temperature: 47.0 �C
    KFC: 57
    KFA: 00 00
    Environmental conditions: 20
    uAdSensI_U1V2Filtered_gdu16: 1.20 V
    uAdSensI_U5VFiltered_xdu16: 0.00000 V
    uioUdNotFilt_xdu16: 13.55 V
    uAdSensI_SwitchedKl30_xdu16: 13.54 V
    ASC_CTRL_GET_ILWS_ERR_FLAGS: 00
    22528 - Databus
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 9
    Mileage: 146276 km
    Date: 2019.08.28
    Time: 06:59:05
    Motor status: 03
    KFC: 58
    KFA: 00 00
    23040 - Databus
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 9
    Mileage: 146276 km
    Date: 2019.08.28
    Time: 06:59:05
    Motor status: 03
    KFC: 5A
    KFA: 00 00
    uioUdNotFilt_xdu16: 13.38 V
    uAdSensI_SwitchedKl30_xdu16: 13.39 V
    22784 - Databus
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 9
    Mileage: 146276 km
    Date: 2019.08.28
    Time: 06:59:05
    Motor status: 03
    KFC: 59
    KFA: 00 00
    19716 - Databus
    U1123 00 [008] - Received Error Message
    Freeze Frame:
    Fault Priority: 6
    Reset counter: 9
    Mileage: 146278 km
    Date: 2019.08.28
    Time: 07:14:25
    Motor status: 02
    Supply voltage: 13.50 V
    Temperature: 45.0 �C
    KFC: 4D
    KFA: 00 04
    uioUdNotFilt_xdu16: 13.77 V
    uAdSensI_SwitchedKl30_xdu16: 13.76 V
    Address 52: Door Elect, Pass. (J387) Labels:| 5QX-959-X92-52.clb
    Part No SW: 5Q4 959 592 B HW: 5Q4 959 592 B
    Component: TSG BFS 009 0014
    Serial number: 0000105841713
    Coding: 00110120DC00040000001100
    ASAM Dataset: EV_DCUPasseSideEWMAXCONT 006001
    ROD: EV_DCUPasseSideEWMAXCONT_VW37.rod
    VCID: 43847790CA95D95ED7-8016
    Passengers Rear Door Control Module:
    Subsystem 1 - Part No SW: 5Q0 959 812 A HW: 5Q0 959 812 A Labels: 5QX-959-81X-V1.CLB
    Component: FOND_FHSG_PSG 005 0005
    Serial number: 00000000000002868895
    Coding: 190200
    Address 5F: Information Electr.
    Cannot be reached
    End-------------------------(Elapsed Time: 03:58)--------------------------
    Z racji tego ze jestem "zielony" w tych tematach czy ktos moze mi poradzic czy to co powyzej to rzeczy ktorymi trzeba sie zajac natychmiast czy to jakies pierdoly ?
    Z mojej perspektywy wszystko w aucie dziala i nie mam zadnych problemow (poki co ) a z rzeczy "niestandardowych" to jest wpiete radio 2 Din na androidzie oraz chip tunning silnika.
    Czy te bledy to konsekwencja tych modyfikacji czy cos innego ?
    Z gory dziekuje za ewentualne porady
POWRÓT NA GÓRĘ
