Skoda Octavia 1.8TSI nierówna praca, brak mocy, kody błędów z VCDS
  • Michal2
    • 131
    Cześć,
    Czy ktoś mi pomoże odczytać kody błędów silnika?
    Wracałem dzisiaj z trasy, chciałem przyspieszać, a tu dziwne szarpanie i brak mocy.
    Chassis Type: 1Z (7N0)
    Scan: 01 03 08 09 10 15 16 17 19 25 42 44 46 52 56 62 72
    VIN: TMBGK61Z1B2057954 Mileage: 106470km-66157miles
    01-Engine -- Status: Malfunction 0010
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: Malfunction 0010
    10-Park/Steer Assist -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    25-Immobilizer -- Status: OK 0000
    42-Door Elect, Driver -- Status: Malfunction 0010
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    52-Door Elect, Pass. -- Status: Malfunction 0010
    56-Radio -- Status: Malfunction 0010
    62-Door, Rear Left -- Status: OK 0000
    72-Door, Rear Right -- Status: Malfunction 0010
    Address 01: Engine (CDA) Labels: 06J-907-115-CDA.clb
    Part No SW: 3T0 907 115 G HW: 1Z0 907 115 F
    Component: 1.8l R4/4V TFSI 0020
    Revision: AAH18--- Serial number:
    Coding: 0203000C18070160
    Shop #: WSC 73430 790 00000
    VCID: 35793787C54183AAFC769F9-8060
    4 Faults Found:
    008213 - Intake Manifold Flap Position Sensor (Bank 1)
    P2015 - 000 - Implausible Signal - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 0
    Fault Frequency: 3
    Reset counter: 255
    Mileage: 106044 km
    Time Indication: 0
    Date: 2011.07.06
    Time: 22:20:03
    Freeze Frame:
    RPM: 2402 /min
    Load: 26.3 %
    Speed: 87.0 km/h
    Temperature: 93.0°C
    Temperature: 0.0°C
    Absolute Pres.: 1020.0 mbar
    Voltage: 14.478 V
    000769 - Cylinder 1
    P0301 - 000 - Misfire Detected
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 106469 km
    Time Indication: 0
    Date: 2011.08.03
    Time: 17:08:31
    Freeze Frame:
    RPM: 2952 /min
    Load: 76.0 %
    Speed: 106.0 km/h
    Temperature: 93.0°C
    Temperature: 13.0°C
    Absolute Pres.: 1000.0 mbar
    Voltage: 13.970 V
    004874 - Cylinder Disabling
    P130A - 000 - - Intermittent
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 2
    Reset counter: 255
    Mileage: 106471 km
    Time Indication: 0
    Date: 2011.08.03
    Time: 17:45:43
    Freeze Frame:
    RPM: 853 /min
    Load: 18.0 %
    Speed: 8.0 km/h
    Temperature: 77.0°C
    Temperature: 28.0°C
    Voltage: 13.843 V
    004688 - Fuel Level too Low
    P1250 - 000 -
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 106475 km
    Time Indication: 0
    Date: 2011.08.03
    Time: 17:55:39
    Freeze Frame:
    RPM: 853 /min
    Load: 25.1 %
    Speed: 0.0 km/h
    Temperature: 71.0°C
    Temperature: 23.0°C
    Voltage: 13.716 V
    Readiness: 0000 0000
    Myślę, że całą tę gamę błędów powodują klapy w kolektorze ssącym (może sam czujnik, a może już są zasyfiałe) - czyli ten pierwszy błąd na górze:
    https://a4-klub.pl/topic/272895-18tf...ami-i-dolotem/
    tylko nie wiem czemu masz błąd paliwa
