"Jak ogarnąć" kostki od radia...
  • Greg00pl
    • 35
    Witam!
    Zasadniczy problem polega na tym, że poprzedni właściciel montując "chińczyka" "pokopał" do cna oryginalne okablowanie -> tu uciął tam połączył, tu se nowy kabelek wyciągnął... i teraz ładu dojść nie można...
    Najpierw trochę danych...
    Skodawka O2 przedlift CLASSIC... silnik 1.6 BSE
    To co udało sie odczytać z tabliczki z nominalnym wyposażeniem:
    E0A AAU No special edition
    1D0 AHV Without trailer hitch
    5SL ASL Left exterior mirror: aspherical
    5RQ ASR Right exterior mirror, convex????
    6FA BBO Components without special surface appearance
    1AC BRS Anti-lock brake system (ABS)
    3FA DEI Without roof insert (standard roof)
    1N3 LEN Speed-related variable steering assist (Servotronic)
    1ND RAA Wheel trims
    H7F REI Tires 195/65 R15 91H
    4UF AIB Driver and front passenger airbag with front passenger airbag deactivation???
    4R5 FEH Power windows with comfort operation andcircuit breaker, mechanical window regulators rear ????
    B17B17 TPL Type approval country Poland
    3QT RSV 3-point seat belts in front, with pretensioner and height adjustment
    4X1 SAB Side airbag in front
    4A0 SIH Without seat heater
    8L3 ANT Roof antenna
    J1P BAT Battery 220 A (44 Ah)
    7AA EDW Electronic engine immobilizer
    8GU GEN Alternator 140 A ?????
    6Y0 GWA Without cruise control warning system
    9AP HKA Climatic air-conditioning system (semi-automatic)
    8RE LSE 4 speakers (passive)
    7Q0 NAV Without navigation device
    8AA RAO Without radio
    8QA SLR Key without LED
    8X0 SWR Without headlamp washer system
    4F1 TKV Central locking system
    G02 DFV Shock absorption in front
    QN0 SVS Without drawers under front seats
    3L1 SIE Manual height adjustment for left front seat???
    QP1 BAR Bar compartment????
    7X1 EPH Park distance control
    9WG AUD Without multimedia in the vehicle but with Mirror Link and APP feature???
    8WA NES Without front fog lamps
    7A0 CDW Without CD changer/CD player
    3GA LBH Without cargo area
    QG1 WIV Service interval prolongation?????
    0GG AGM Emission standard EU4
    L01 GKV Suspension range 01 installation control only, no requirement forecast
    7P0 LOR Without lumbar support in seat backrests
    F0A FZS No special purpose vehicle, standard equipment
    3S4 DAR Preparation for roof load rack
    2UA SWP Standard design
    1G4 RER Space-saving spare wheel
    1Z3 KRM Double initial standard fuel filling
    Te z ?? na końcu nie mam pewności - mało czytelne kody
    Chińczyk wiele o sobie nie mowi => jedyna dwa oznaczenia z bebechów to płyta glówna: 803a-kv 1.4 i panel przedni: xph-8242-tft-v01
    A teraz co popierniczone... Oryginalna kostka (ta wychodząca do radia) ma obcięte 3 przewody... 2 cieńkie kolor pomarańczowo-fioletowy i jeden gruby czerwono-biały => zastąpiony jakimś czerwonym przewodem podciągniętym nie wiadomo skąd...
    Byłbym wdzięczny za podrzucenie rozpiski zorgyginalnej kostki - jaki przewód i do czego i jaka pozycja w kostce...
    Tu zdjęcia z stanu zastanego:
    I teraz pytania:
    1) Czy to radio potrzebuje dekodera CAN? jak np tu => Link Wg opisu który gdzieś kiedyś mi się napatoczył to radio potrafi z CAN podać informacje o prędkości, poziomie paliwa etc...
    2) Czy jest sens dozbrajać skodawkę w kierownicę multi- czy radio będzie ją obsługiwać?
    3) Jak pod "toto" podpiąć kamerę cofania (taką z ramki tablic rejestracyjnych) i czy będzie sie ona włączać automatycznie... Znalazłem podobny "problem" TU
    4)Czy moja skodawka ma oryginalne głośniki z tyłu (wg kodów wyposażenia), czy trzeba sobie dołożyć, a jesli tak, czy wiąki tam będą, czy trzeba ciągnąć okablowanie samemu?
    5) Czy ktoś z państwa ma namiary na obudowę Subwoofera pasującą w "boczki" bagażnika do lifta ? ewentualnie jakiś dobry poradnik jak taką wykonać...
    Z góry dziekuję i pozdrawiam
    Paweł.
    PS Przepraszam za takie "bycze" zdjęcia, ale jakchciałemwstawić jako miniatury z odnośnikiem to wywalało głupoty...
    Ostatnio edytowany przez Greg00pl; 43972.
