Mam do was pytanie. Macie jakieś informacje dotyczące wzmacniacza Kenwood KAC-8404. Ciężko coś konkretnego o nim znaleźć. Miałby on zasilać przód: Helix 62.1 i z kanałów 3 i 4 zrobić bridge na subwoofer: Rockford Fosgate R1 lub P1 w skrzyni closed. Nie chodzi mi o to, żeby najpierw słyszeli mnie ludzie z 1 km, a po chwili zobaczyli, ale o przyjemne granie. Aktualne radio to Kenwood KDC-W4044UGY, z którego jestem zadowolony, żadnych problemów z odczytem nawet dysku przenośnego. Proszę o opinie na ten temat.
DANE TECHNICZNE
Key Features
Signal sensing turn-on
600 Watts max Output Power
2Ω Load Capability
Cooling Fan (2x)
Built-in Low-pass filter
Built-in High-pass filter
Bass Boost 40Hz (0~+18dB)
Blue illumination
Speaker level input
Amplifier Features
Load Capability 2Ω Stable
Maximum Output Power 600W
Rated Power Output 50W x 4 (4Ω)
Rated Power Output 75W x 4 (2Ω)
Bridged Power Output (4Ω) 180W x 2
CEA-2006 Compliant Yes
Low-pass Filter Yes
High-pass Fliter Yes
Bass Boost Circuit Yes
Switched Mode Power supply Yes, with Power MOS-FET
Cooling Fan Yes
Power Indicator Yes
Blue Illumination Yes
Signal Sensing Turn-on Yes
Protection function Yes
Line in 2 RCA (Gold Plated)
Input Selector no
Line out no
Speaker level Input Yes
Single Side Terminals Yes
Gold Plated Power & Speaker Terminals Yes
Die-Cast Aluminium Heat Sink Yes
Removable Coverplate Yes
Amplifier-Specifications
Maximum Power Output (4Ω) 150W x 4
Rated Power Output (4Ω, 14,4V) 40W x 4 (20Hz ~ 20000Hz, 0.08%THD)
Rated Power Output (2Ω, 14,4V) 75W x 4 (1000Hz, 0.8%THD)
Bridged Power Output (4Ω, 14,4V) 180W x 2 (1000Hz, 0.8%THD)
Rated Power Output (CEA-2006) 50Watts RMS x 4 at 4 ohms and 1% THD
Low-pass Filter 50~200Hz (-12dB/oct)(B-Channel)
High-pass Fliter 50~200Hz (12dB/oct)
Bass Boost Circuit 0~18dB (Variable)
Bass Boost Frequency 40Hz
Input Sensitivity 0.2 ~ 5V
Input Impedance 10kΩ
Signal to Noise Ratio 100dB
Signal To Noise Ratio (CEA-2006) 80dBa (Reference: 1 Watt into 4 Ohms)
Frequency response (+0dB, -3dB) 5Hz ~ 50000Hz
Operating voltage 14.4V (11V ~ 16V allowable)
Maximum current consumption 40A
Dimensions (WxHxD) 280 x 59 x 238(mm),
Weight 2.8kg
