adapter bluetooth
  • chrisunm1
    • 60
    adapter bluetooth
    na allegro czasmi trafia sie jakas oryginalna uzywana, reszta to podorbki ktore mozna poznac po braku wyciszenia :wink:
    MOja czeszka
  • onyx73
    • 282
    adapter bluetooth
    ..http://cgi.ebay.pl/ws/eBayISAPI.dll?...vi:1:2v_search
    • djczas
      • 9612
      teoretycznie tak ale nie wiem tak by wynikało z opisu jesli założyć ze oem monitor to maxi dot
      • yoschua
        • 339
        To jest tylko kabelek.
        Przejściówka z 'nowego' na 'stare' ISO i z powrotem, do podłaczenia np systemu głośnomówiącego który wykorzystuje stare ISO coby kabli nie ciąć.
        Parrot - producent - robi takie systemy po Bluetooth głośnowiące do samochodów które wykorzystują głośniki standardowej instalacji radiowej.
        Sam posiadam papuge i bardzo sobie chwale
        Octavia Combi 4x4 1,8T ARX 2001
        HPI Baja 5B SS - nowa zabawka
        • onyx73
          • 282
          hmm a to ?
          Your new 2005 and Bluetooth enabled cell phone have developed a symbiotic relationship thanks to the innovative engineers at Volkswagen and Nokia Automotive. The new Passat will have an integrated handset which harnesses Bluetooth wireless technology. The technology supports the Bluetooth SIM Access Profile which enables the car to connect to your SIM card via Bluetooth and log onto the GSM network.
          "For the first time, an automaker is offering a communication solution using the Bluetooth SIM Access Profile that is factory-fitted in the vehicle. This represents an important engineering achievement: we have taken a further step toward universality in the domain of factory-installed, integrated communication solutions: Users looking for wide-ranging compatibility with a variety of mobile phones have a choice between an aftermarket solution or a factory-fitted system," says Marcus Stahl, General Manager Nokia Automotive.
          The car will be fitted with an external GSM antenna, excellent audio quality in hands-free mode, and alphanumerical keyboard integrated into the steering wheel. In addition, you can access all personal contact data stored in the mobile phone using the cars built-in Bluetooth technology. As soon as you enter the car, your compatible phone will connect and login to the GSM network, when you exit or press a button on the handset, it will seamlessly return you to the mobile network.
          bluetooth modules..part# 8P0 862 335 J...400.00
          Upload, organize and share your photos with ImageShack. Fast, reliable image hosting with albums, privacy controls, direct links and resizing.
          http://cgi.ebay.pl/VW-Passat-3C-Bedi...QQcmdZViewItem
          • dinderi
            • 129
            Zamieszczone przez yoschua
            Temat troche stary. Ale jako, ze od czegoś trzeba zacząć swoją bytność na forum, pozwolę sobie go odswieżyć.
            Również mam Papugę. Niestety, franca ma błędy w sofcie i niekiedy nie reaguje na klawisze. Szczególnie po głosowym wybraniu nr tel. i nawiązaniu połączenia, nie można go zerwać z panelu radia, lecz guzikiem na telefonie. Czasami równiez, nie przełacza się automatycznie, z trybu zestawu głośno-mówiącego, na muzykę lub radio.
            Zastanawiam się, czy kolega zaobserwował podobne kaprysy, czy to moze przypadłość mojego sprzętu i trzeba reklamować?
            Takie są i tak najpiekniejsze...
            • Lukasso
              • 611
              Zamieszczone przez dinderi
              8) z Francą to tak zawsze :-)
              • franca
                • 532
                hahaha boki zrywac :P
                • dinderi
                  • 129
                  Zamieszczone przez franca
                  hahaha boki zrywac
                  Upssss, nie spodziewałem się, ze ktoś przyjął tak zacny nick na forum. :P Nie chciałem urazić
                  • franca
                    • 532
                    :szeroki_usmiech luuzik :szeroki_usmiech
