Mam limuzyne, ale pomyślałem też wcześniej o tych odbojnikach. dzięki za podpowiedź, zerknę i zobacze cy to przyniosło efekty
Pozdr
Andrzej
Pozdr
Andrzej
Address 01 ------------------------------------------------------- Controller: 06A 906 018 FK Component: 2.0l R4/2V MOTR HS V05 Coding: 00031 Shop #: WSC 31480 2 Faults Found: 16684 - Random/Multiple Cylinder Misfire Detected P0300 - 35-10 - - - Intermittent 16687 - Cylinder 3 Misfire Detected P0303 - 35-10 - - - Intermittent Readiness: 0000 0000 Address 03 ------------------------------------------------------- Controller: 1C0 907 379 L Component: ABS FRONT MK60 0101 Coding: 0004097 Shop #: WSC 31480 No fault code found. Skipping Address 15-Airbags Address 17 ------------------------------------------------------- Controller: 1U0 920 811 B Component: KOMBI+WEGFAHRSP VDO V07 Coding: 18102 Shop #: WSC 31480 TMBCE41U532741213 SKZ7Z0B1675273 No fault code found. Address 19 ------------------------------------------------------- Controller: 6N0 909 901 Component: Gateway K<->CAN 0001 Coding: 00006 Shop #: WSC 31480 No fault code found. Address 46 ------------------------------------------------------- Controller: 1C0 959 799 Component: 3P Komfortgerát HLO 0002 Coding: 00259 Shop #: WSC 31480 No fault code found. VAG-COM
