jalalewale, sachs podobno mocniejszy od luk-a
[O1] pomoc w analizie logow
jak poniżej:
Tuesday, 10 January 2012, 18:57:47:0
Chassis Type: 1U - Skoda Octavia I
Scan: 01,02,03,08,15,16,17,19,22,29,35,36,37,39,46,56,76
Address 01: Engine Labels: Redir Fail!
Controller: 06A 906 018 CF
Component: 1.8L R4/5VT MOTR HS D03
Coding: 04000
Shop #: WSC 00035
2 Faults Found:
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
16500 - Shareware Version. To Decode all DTCs
P0116 - 35-10 - Please Register/Activate - Intermittent
Readiness: N/A
Address 03: ABS Brakes Labels: 1J0-907-37x-ABS.LBL
Controller: 1J0 907 379 H
Component: ABS/EDS 20 IE CAN 0001
Coding: 13504
Shop #: WSC 31480
No fault code found.
Address 08: Auto HVAC Labels: 1Ux-907-044.LBL
Controller: 1U1 907 044
Component: CLIMATRONIC S 0.3.2
Coding: 01000
Shop #: WSC 31480
1 Fault Found:
01274 - Air Flow Flap Positioning Motor (V71)
35-00 - -
Address 15: Airbags Labels: 1J0-909-60x-VW3.LBL
Controller: 1J0 909 603 AS
Component: AIRBAG VW3 - V04
Coding: 16723
Shop #: WSC 31480
Address 17: Instruments Labels: 1Ux-919-xxx-17.LBL
Controller: 1U1 919 034 C
Component: A4-KOMBIINSTR. VDO V22
Coding: 02142
Shop #: WSC 00000
IMMO-IDENTNR: SKZ7Z0W0209543
Address 46: Central Conv. Labels: 1J0-959-799.LBL
Controller: 1J0 959 799 AH
Component: 5U Zentral-SG Komf. 0001
Coding: 04097
Shop #: WSC 31480
2 Faults Found:
01179 - Incorrect Key Programming
35-00 - -
00930 - Locking Module for Central Locking; Rear Left (F222)
27-10 - Implausible Signal - Intermittent
End --------------------------------------------------------------------------------------------------
I jeszcze to:
VCDS-Lite Version: Release 1.0
Tuesday, 10 January 2012, 19:03:51:0
Control Module Part Number: 06A 906 018 CF
Component and/or Version: 1.8L R4/5VT MOTR HS D03
Software Coding: 04000
Work Shop Code: WSC 00035
2 Faults Found:
16500 - Engine Coolant Temp. Sensor (G62): Implausible Signal
P0116 - 35-10 - - - Intermittent
:/Radio: C90r+XDP210EQ
Kable:Opt,Skyline,50 mm
Wzm:XES M1+FP 1.800
1 bład jest zapisywany po odłonczeniu akumlatora
2 nie wiarygodny sygnał czyjnika temp. silnika do wymiany
3 nie działajaca klapa obiegu wewnetrznego naj prawdo podobniej pekła zebatka w silniczku klapy wymiana albo naprawa starego .(pewnie szyby ci paruja).
4 nie prawidłowe kodowanie pilota centralnego zamka
5 nie zrozumiały sygnał z lewego tylnego zamkadiagnostyka vag 602-614-253
