trzesie przy przyspieszaniu
  • bmiara
    • 12
    Zamieszczone przez spacewalker
    daj cały autoscan z auta
    Chassis Type: 7N0
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56
    VIN: TMBJA21Z7D2017978
    01-Engine -- Status: Malfunction 0010
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: Malfunction 0010
    09-Cent. Elect. -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: Malfunction 0010
    25-Immobilizer -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    56-Radio -- Status: Not registered 0011
    Address 01: Engine (BSE) Labels: None
    Part No SW: 06A 906 033 NT HW: 06A 906 033 MP
    Component: BSE S71 1.6 2V 8459
    Revision: --H01--- Serial number:
    Coding: 0044071
    Shop #: WSC 73430 790 00090
    VCID: 7EF9E02129EC549
    No fault code found.
    Readiness: 0110 1001
    Address 03: ABS Brakes Labels: 1K0-907-379-MK70M.clb
    Part No SW: 1K0 907 379 AK HW: 1K0 907 379 AK
    Component: MK70 M MASR 0106
    Revision: 00H35001
    Coding: 0017665
    VCID: 7BFFE9353AFE411
    Address 08: Auto HVAC (J301) Labels: 3C8-907-336.clb
    Part No SW: 3T0 820 047 AF HW: 3T0 820 047 AF
    Component: AC Manuell H20 0607
    Revision: 00001012
    Coding: 0010000002
    ASAM Dataset: EV_ACManueBHBVW36X A01010
    ROD: EV_ACManueBHBVW36X_SK35.rod
    VCID: 73EFC115DAAE091
    Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.lbl
    Part No SW: 1K0 937 086 N HW: 1K0 937 086 N
    Component: BCM PQ35 M+ 110 0649
    Revision: 00110 AA
    Coding: 46000AB880B72D90001000860500812047680088524D896050 8440020040
    Shop #: WSC 33361 790 00068
    VCID: 3B7F2935BA7E811
    Subsystem 1 - Part No: 1Z1 955 119 D Labels: 1KX-955-119.CLB
    Component: Wischer 02061 26 0601
    Coding: 00D7B7
    1 Fault Found:
    02195 - Dimmer Switch Instrument Panel & Switch Lighting (E20)
    002 - Lower Limit Exceeded
    Freeze Frame:
    Fault Status: 01100010
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 143
    Mileage: 24028 km
    Time Indication: 0
    Date: 2018.14.17
    Time: 13:03:30
    Freeze Frame:
    Term 15 On
    Voltage: 11.95 V
    ON
    ON
    Term 50 Off
    OFF
    OFF
    Address 15: Airbags Labels: 1K0-909-605.lbl
    Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
    Component: Q2 AIRBAG VW8 020 2300
    Revision: 05020000 Serial number: 0038PD2WZE03
    Coding: 0020786
    VCID: 3D7B272D646A8F1
    Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
    Part No SW: 5K0 953 521 BJ HW: 5K0 953 569 C
    Component: LENKS.MODUL 014 0140
    Revision: FF010041 Serial number: 20120608801282
    Coding: 5080040000
    ASAM Dataset: EV_SMLSNGVOLWSXS A01004
    ROD: EV_SMLSNGVOLWSXS_SK35.rod
    VCID: 75EBFF0DD4DA171
    Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
    Part No SW: 1Z0 920 803 Q HW: 1Z0 920 803 Q
    Component: KOMBI H06 0608
    Serial number: 00000000000000
    Coding: 110A00
    Shop #: WSC 73430 031 00090
    ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04114
    ROD: EV_Kombi_UDS_VDD_RM09_SK35.rod
    VCID: 428154D1D594F09
    Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
    Part No SW: 7N0 907 530 R HW: 7N0 907 530 H
    Component: J533 Gateway H42 1632
    Revision: H42 Serial number: 260512F2000730
    Coding: 352302
    VCID: 3F875D25AE669D1
    1 Fault Found:
    01044 - Control Module Incorrectly Coded
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 1
    Fault Frequency: 1
    Mileage: 24028 km
    Time Indication: 0
    Date: 2018.14.17
    Time: 13:04:19
    Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
    Part No SW: 5K0 953 234 HW: 5K0 953 234
    Component: IMMO H06 0608
    Coding: 000000
    Shop #: WSC 00000 000 00000
    ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03009
    VCID: EAD15C710D64489
    Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
    Part No SW: 1T0 959 701 T HW: 1T0 959 701 T
    Component: Tuer-SG 009 2119
    Coding: 0000116
    VCID: 489546F93BA8DA9
    Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
    Part No: 1K0 909 144 P
    Component: EPS_ZFLS Kl. 67 3305
    Revision: 00H22000
    VCID: 377735054656A51
    Address 46: Central Conv.
    Cannot be reached
    Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
    Part No SW: 1T0 959 702 R HW: 1T0 959 702 R
    Coding: 0000116
    VCID: 479745C536B6D51
    Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
    Part No SW: 1Z0 035 161 F HW: 1Z0 035 161 F
    Component: SWING 009 0065
    Revision: 0H001001 Serial number: SKZ1Z2K8366794
    Coding: 0D0004000001
    Shop #: WSC 73430 790 00999
    VCID: 31630B1D68327B1
  • weeman42217
    • 28
    Witam kolegow,
    gdy przysiepszam samochodem powiedzmy jade 60km na godzine i delikatnie dodaje gazu to calym samochodem trzesie...
    1 mechanik mowi na pewno przeguby wewnetrzne
    2gi mechanik mowi na pewno sprzeglo...?
    3ci mowi to chyba opony do wymiany?
    jakas masakra. Tym bardziej tez ze bylem na przegladzie i robilem zbieznosc wczoraj. podobno rzadnych luzow w zawieszeniu nie ma. zbieznosc zrobiona.
    jakies pomysly? octavia z 2001 r. 1.9TD, 110 koni
    • magi2
      • 83
      miałem to samo okazały się przeguby wewnętrzne
      • weeman42217
        • 28
        ale miales jakies luzy? mechanik mi spradzil przeguby i mowi ze sa ok
        • magi2
          • 83
          żadnych luzów , po wymianie przyjemność z przyspieszania
          • lilo
            • 4317
            • Mercedes-Benz
            może to też dwu mas robić
            Daniel
