oj tak zwierzaczki lubią samochody bo silniki sa ciepłe to tam sie pchają...I niech sie pchaja byle by kabli nie zjadały. Dobrze jest okolice naarować kostka domestosa ten zapach mocno chemiczny sztuczny i toksyczny skutecznie odstrasza gra wierzchu. mozna taką kostke zawiesic w okolicy komory silnika...
Corner lights
Tagi: Brak
Corner lights
Hi, sorry to write in english
Have a 06/2010 1.6tdi Octavia Break and activated corner light with Vagcom.
Works in reverse and when turning the steering wheel.
With the blinker( turning signal) it does not work.
Other octavias with week 22/2010 changes donnot work either,
models before work ok.
thanks
alberg,
just try enble the byte 17 bit 0
if it doesn't help you have newest soft in Your module
we are on the way to recognize what's new in it, and will let You know if found any solution. You can ask a question on thos forum as well;
regards!Pozdrawiam
I have tried byte 17 from 0 to 1, but nothing.Zamieszczone przez Enriquezalberg,
if it doesn't help ... have newest soft in Your module
we are on the way to recognize what's new in it, and will let ... know if found any solution. ... can ask a question on thos forum as well;
regards!
