Doposażenie Octavia 2 FL
  • wojtasmazi
    • 90
    Czy na podstawie Auto Scanu jesteście w stanie popowiedzieć mi co jeszcze mogę włączyć bez wielkich nakładów finansowych ?? Jeśli tak to prosił bym o info.....
    Interesowało by mnie też dołożenie HHC co z pompą ABS na jaką ewentualnie musiał bym wymienić ??
    VCDS
    Windows Based VAG/VAS Emulator Running on Windows 7 x64
    VCDS Version: Release 18.9.0(x64) Data version: 20180927 DS296.0
    VCDS,VAG-COM,VAGCOM,Diagnose,Diagnostics,DTC,Fault Codes,Data Logging,VW Scan Tool,Audi Scan Tool, VAG Scan Tool,Micro-CAN,HEX-USB+CAN,HEX+CAN,HEX-NET,VAG 11,VAG 12,VAG 14,VAG 15
    Dealer/Shop Name: Dash Solutions
    Workshop Code: 000 00000 000000
    Self-Diagnosis Log
    Sunday,16,December,2018,14:31:48:60351
    VIN: TMBGJ61Z6A8021885 License Plate:
    Mileage: 124170km-77155mi Repair Order:
    Chassis Type: 1Z-SK35 (1K0)
    Scan: 01 03 08 09 10 15 16 17 19 25 2E 42 44 46 52 56 62 72 77
    VIN: TMBGJ61Z6A8021885 Mileage: 124170km-77155miles
    01-Engine -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: Malfunction 1010
    09-Cent. Elect. -- Status: Malfunction 0010
    10-Park/Steer Assist -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: Malfunction 0010
    25-Immobilizer -- Status: OK 0000
    2E-Media Player 3 -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    56-Radio -- Status: OK 0000
    62-Door, Rear Left -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    77-Telephone -- Status: OK 0000
    Address 01: Engine (CAX) Labels: 03C-906-016-CAX.clb
    Part No SW: 03C 906 016 AK HW: 03C 906 016 C
    Component: MED17.5.5 G 5295
    Revision: LCH04--- Serial number:
    Coding: 0000072
    Shop #: WSC 73430 790 00000
    VCID: 68DFDDAA5B98640A7D-803C
    No fault code found.
    Readiness: 0000 0000 [
    VCDS
    Self-Diagnosis Log
    Page 2
    Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-60EC1F.clb
    Part No SW: 1K0 907 379 AH HW: 1K0 907 379 AH
    Component: ESP MK60EC1 H30 0107
    Revision: 00H30001
    Coding: 113B201C092400FB881304EC901E0040300800 Shop #: WSC 73430 790 12345
    VCID: 78FF8DEACB38F48AED-802C
    Address 08: Auto HVAC (J255) Labels:| 5K0-907-044.clb
    Part No SW: 3T0 907 044 AC HW: 3T0 907 044 AC
    Component: Climatronic 122 0203
    Revision: 00003001
    Coding: 0100000000
    Shop #: WSC 73430 790 00999
    ASAM Dataset: EV_Climatronic A01001
    ROD: EV_ClimaAutoBasis_SK35.rod
    VCID: 73E5BAC6DA5E97D2D8-8026
    2 Faults Found:
    9479443 - Control Circuit for Front Right Seat Heater
    B10A5 13 [008] - Open Circuit
    Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 27
    Mileage: 123942 km
    Date: 2018.12.01
    Time: 11:21:22
    9479699 - Control Circuit for Front Left Seat Heater
    B10A6 13 [008] - Open Circuit
    Fault Priority: 3
    Fault Frequency: 4
    Reset counter: 27
    Mileage: 123669 km
    Date: 2018.11.17
    Time: 09:01:54
    VCDS
    Self-Diagnosis Log
    Page 3
    Address 09: Cent. Elect. (J519) Labels:. 1K0-937-08x-09.clb
    Part No SW: 1K0 937 087 D HW: 1K0 937 087 D
    Component: BCM PQ35 H 103 0573
    Revision: 00103 AF
    Coding: 46180AB8B05BF1C040080081150081E4434000AE630189605C 0540000000 Shop #: WSC 20270 456 00001
    VCID: 326B7FC26DC4DEDA13-8066
    Subsystem 1 - Part No: 1Z1 955 119 C Labels: 1KX-955-119.CLB
    Component: Wischer 24100 22 0601
    Coding: 00D7B7
    Subsystem 2 - Part No: 1Z0 951 171 A
    Component: Innenraumuebe 009 5103
    Subsystem 3 - Part No: 1K8 951 605
    Component: LIN BACKUP HO H09 9002
    9 Faults Found:
    01320 - Control Module for Climatronic (J255)
    004 - No Signal/Communication - Intermittent Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 17
    Mileage: 123669 km
    Time Indication: 0
    Date: 2013.04.04
    Time: 10:29:50
    Freeze Frame:
    Term 15 Off
    Voltage: 12.20 V
    OFF
    OFF
    Term 50 Off
    OFF
    OFF
    00061 - Footwell Lights
    010 - Open or Short to Plus - Intermittent Freeze Frame:
    Fault Status: 00101010
    Fault Priority: 5
    Fault Frequency: 6
    Reset counter: 17
    Mileage: 123669 km
    Time Indication: 0
    Date: 2013.04.04
    Time: 10:58:29
    VCDS
    Self-Diagnosis Log
    Page 4
    Freeze Frame:
    Term 15 Off
    Voltage: 12.15 V
    OFF
    ON
    Term 50 Off
    OFF
    OFF
    00834 - Signal for Activation of Heated Rear Window
    009 - Open or Short to Ground - Intermittent
    Freeze Frame:
    Fault Status: 00101001
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 17
    Mileage: 123669 km
    Time Indication: 0
    Freeze Frame:
    Term 15 Off
    Voltage: 12.35 V
    OFF
    OFF
    Term 50 Off
    OFF
    OFF
    00924 - Relay for Headlamp Cleaning System (J39)
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 17
    Mileage: 123669 km
    Time Indication: 0
    Freeze Frame:
    Term 15 Off
    Voltage: 12.35 V
    OFF
    OFF
    Term 50 Off
    OFF
    OFF
    01259 - Fuel Pump Relay (J17)
    009 - Open or Short to Ground - Intermittent Freeze Frame:
    Fault Priority: 5
    VCDS
    Self-Diagnosis Log
    Page 5
    Fault Frequency: 1
    Reset counter: 17
    Mileage: 123669 km
    Time Indication: 0
    Freeze Frame:
    Term 15 Off
    Voltage: 12.35 V
    OFF
    OFF
    Term 50 Off
    OFF
    OFF
    03266 - Control Circuit for Signal Horn
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 17
    Mileage: 123669 km
    Time Indication: 0
    Freeze Frame:
    Term 15 Off
    Voltage: 12.35 V
    OFF
    OFF
    Term 50 Off
    OFF
    OFF
    03396 - Supply voltage terminal 30 for central locking
    011 - Open Circuit - Intermittent
    Freeze Frame:
    Fault Status: 00101011
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 17
    Mileage: 123669 km
    Time Indication: 0
    Date: 2013.04.04
    Time: 14:37:10
    Freeze Frame:
    Term 15 Off
    Voltage: 12.35 V
    OFF
    OFF
    Term 50 Off
    OFF
    VCDS
    Self-Diagnosis Log
    Page 6
    OFF
    02195 - Dimmer Switch Instrument Panel & Switch Lighting (E20)
    002 - Lower Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Status: 00100010
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 17
    Mileage: 123669 km
    Time Indication: 0
    Date: 2013.04.04
    Time: 14:37:10
    Freeze Frame:
    Term 15 Off
    Voltage: 12.35 V
    OFF
    OFF
    Term 50 Off
    OFF
    OFF
    01800 - Light Switch (E1)
    008 - Implausible Signal - Intermittent Freeze Frame:
    Fault Status: 00101000
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 17
    Mileage: 123669 km
    Time Indication: 0
    Freeze Frame:
    Term 15 Off
    Voltage: 12.05 V
    OFF
    ON
    Term 50 Off
    OFF
    OFF
    VCDS
    Self-Diagnosis Log
    Page 7
    Address 10: Park/Steer Assist (J446) Labels:. 1Z0-919-475-V1.clb
    Part No SW: 1Z0 919 475 C HW: 1Z0 919 475 A
    Component: PARKHILFE 8K H06 0006
    Revision: -------- Serial number: 66540927803497
    Coding: 100001
    VCID: 4189200ED86275429A-8014
    Address 15: Airbags Labels: 1K0-909-605.lbl
    Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
    Component: Q6 AIRBAG VW8 020 2300
    Revision: 05020000 Serial number: 0038PD2GEY6Z
    Coding: 0020790
    VCID: 3D715CFE649A11A2FE-8068
    Subsystem 1 - Serial number: 6332MSME4A446B1FQ
    Subsystem 2 - Serial number: 6342MSME4C457841H
    Subsystem 3 - Serial number: 6351HSME1D784466G
    Subsystem 4 - Serial number: 6361HSME1E252F04B No fault code found.
    Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
    Part No SW: 1K0 953 549 CF HW: 1K0 953 549 CF
    Component: J0527 056 0111
    Coding: 0000532
    VCID: 78FF8DEA0B38F48AED-802C
    Subsystem 1 - Part No: 3T0 959 537 Labels: 3C8-959-537.CLB Component: E221__MFL-URO H07 0012
    Coding: 00000128
    Shop #: WSC 00000
    VCDS
    Self-Diagnosis Log
    Page 8
    Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
    Part No SW: 1Z0 920 843 F HW: 1Z0 920 843 F
    Component: KOMBI H05 0305
    Serial number: 00000000000000
    Coding: 110F00
    Shop #: WSC 73430 031 12345
    ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04052 ROD: EV_Kombi_UDS_VDD_RM09_004_SK34.rod VCID: 3B7552E6B28E1F92C0-806E
    Address 19: CAN Gateway Labels:. 1K0-907-530-V4.clb
    Part No SW: 1K0 907 530 AD HW: 1K0 907 951
    Component: J533 Gateway H16 0231
    Revision: H16 Serial number: 4320K09A130234
    Coding: E9A07F06000612002302
    VCID: 69D9D8AE40925D0262-803C
    1 Fault Found:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 16
    Mileage: 123669 km
    Time Indication: 0
    Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
    Part No SW: 5K0 953 234 HW: 5K0 953 234
    Component: IMMO H05 0305
    Coding: 000000
    Shop #: WSC 00000 000 00000
    ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03005
    ROD: EV_Immo_UDS_VDD_RM09.rod
    VCID: 6ADBA7A28D94561A6B-803E
    Address 2E: Media Player 3
    Cannot be reached
    VCDS
    Self-Diagnosis Log
    Page 9
    Address 42: Door Elect, Driver Labels:. 1K0-959-701-MAX3.clb
    Part No SW: 1T0 959 701 AA HW: 1T0 959 701 AA
    Component: Tuer-SG 009 2113
    Coding: 0004342
    VCID: 76E383D2012C82FAFF-8022
    Address 44: Steering Assist
    Part No: 1K0 909 144 H
    Component: EPS_ZFLS Kl. 68 Revision: 00H17000
    VCID: 2F6D76B6BEF6F3327C-807A
    Address 52: Door Elect, Pass.
    Labels: 1K0-909-14x-GEN3.clb
    2901
    Labels:. 1K0-959-702-MAX3.clb
    Part No SW: 1T0 959 702 S HW: 1T0 959 702 S
    Coding: 0004342
    VCID: 489F3D2A3B58440A5D-801C
    Address 56: Radio (J503) Labels:. 5M0-035-1xx-56.clb
    Part No SW: 1Z0 035 156 M HW: 1Z0 035 156 M
    Component: BOLERO 001 0012
    Revision: -----08S Serial number: SKZ4Z3M1132527
    Coding: 090004000401
    Shop #: WSC 52328 001 104857
    VCID: 3C7751FABF8018AAC9-8068
    Address 62: Door, Rear Left Labels:. 1K0-959-703-GEN3.clb
    Part No SW: 5K0 959 703 A HW: 5K0 959 703 A
    Component: Tuer-SG 007 2101
    Coding: 0000144
    Shop #: WSC 73430 790 1012544
    VCID: 326B7FC2ADC4DEDA13-8066
    VCDS
    Self-Diagnosis Log
    Page 10
    Address 72: Door, Rear Right Labels:. 1K0-959-704-GEN3.clb
    Part No SW: 5K0 959 704 A HW: 5K0 959 704 A
    Coding: 0000144
    VCID: 33657AC652DED7D218-8066
    Address 77: Telephone (J412) Labels:| 5N0-035-729.clb
    Part No SW: 5N0 035 729 HW: 5N0 035 729
    Component: TELEFON H05 0592
    Revision: 1B001001 Serial number: 00007666036305
    Coding: 0200000000010110
    Shop #: WSC 20016 119 20016
    ASAM Dataset: EV_UHVUMI 001007
    ROD: EV_UHVUMI.rod
    VCID: 6DD1ACBEBC7A41220E-8038
    End-------------------------(Elapsed Time: 02:13
  • Maly745
    • 773
    Twoja pompa nie obsługuje HHC
    1K0-907-37?-AE ; MK60EC1 z HHC
    1K0-907-37?-AJ ; MK60EC1 z HHC
    1K0-907-37?-AM ; MK60EC1 z HHC
    1K0-907-37?-AP ; MK60EC1 z HHC
    1K0-907-37?-AR ; MK60EC1 z HHC
    1K0-907-37?-BE ; MK60EC1 z HHC
    1K0-907-37?-BG ; MK60EC1 z HHC
    1K0-907-37?-BJ ; MK60EC1 z HHC
    1K0-907-37?-BL ; MK60EC1 z HHC
    1K0-907-37?-BM ; MK60EC1z HHC
    Skoda Octavia II FL
    • wojtasmazi
      • 90
      Dzięki za podpowiedz. A co z możliwością dokodowania dołożenia czegoś jeszcze ?
      • #4
        Czy ja to dobrze rozumiem, że 5 lat temu przebieg był o tysiąc mniejszy niż teraz?
        • wojtasmazi
          • 90
          Troche mnie zmartwiłeś tym co napisałeś i przestraszyłem się że licznik był kręcony chociaż kupowałem auto od osoby którą znam i wiem ze był w jednej rodzinie od początku (salon polska)
          Przebieg rzeczywisty w pełni pokrywa mi się z książka serwisową i wykazem z CEPiK-u.
          Poniżej masz skopiowany pierwszy wpis z CEPiK-u (CEPiK przebieg rejestrowany od 2014)
          Badanie techniczne (ważne do 19.11.2015)
          Rodzaj badania: okresowe
          Wynik badania: pozytywne
          Ostatni zarejestrowany stan licznika: 66 217 km
          (Uwaga. Stan licznika gromadzimy od 2014)
          Nie jestem w stanie napisać dlaczego tak wyszło w autoscanie
          Pytanie do pozostały czy widzicie by coś jeszcze dało się zakodować ??
          • kowaltom99
            • 753
            Poszukaj topic-u o zakodowaniu TPMS przez MAXI-DOT.
            Nie wiem czy zegary z końcówką F mają tę funkcję - ale spróbować można.
            edit
            tu jest
            Przeróbki poszerzające funkcjonalność auta. Np. dodanie Xenonów, zmiana foteli, dodatkowe funkcje, wymiana modułu centralnej elektryki. Radio/nawigacja z nowszego modelu itd.
            Ostatnio edytowany przez kowaltom99; 6234.
            • Kitmenk
              • 19
              Podłącze się pod temat, bo naczytałęm wiele, ale za cholerę nie mogę u siebie włączyć świateł dziennych żeby świeciły tylko z przodu i wyłączały się hamulcem ręcznym. VCDS tego nie pokazuje, a kombinując w 11 bajcie nie poradziłem tego zakodować. Czy może być tak, że moje auto tego w ogóle nie ma? Czy raczej te sterowniki tego nie obsługują?
              • Maly745
                • 773
                Masz oddzielne dzienne w halogenach?
                Skoda Octavia II FL
                • Kitmenk
                  • 19
                  Nie. Ten typ wcale halogenów nie ma, znaczy przeciwmgielnych z przodu. Myślę z tego co wyczytałem, że światłą mijania powinny świecić w trybie Ameryka bez tylnych pozycyjnych tylko, że nie ma zaznaczonego tego kodowania, a do II FL nikt jeszcze dokładnie nie opisał teg bitu do włączenia. Prawdopodobnie w bajcie 11, ale dokładnie który to nie wiem.
                  • Maly745
                    • 773
                    U mnie ręczny gasi dzienne muszę sprawdzić który to był bit, jaką masz wartość bajtu 11? 84?
                    Ostatnio edytowany przez Maly745; 34973.
                    Skoda Octavia II FL
                    • Maly745
                      • 773
                      Masz 84 powinno być 85
                      Skoda Octavia II FL
                      • georgg
                        • 17156
                        Bajt 11 bit 2 to jest kodowanie dzienne przez światła mijania.
                        Grzegorz
                        Moja Ambitna Czarnula
                        • Maly745
                          • 773
                          i ręczny Byte 11 Bit 0
                          Skoda Octavia II FL
                          • Kitmenk
                            • 19
                            No zaraz idę sprawdzić, ale ma być, że jak 11 bit 0 ma być 0 czy 1 i bit 2 0 czy 1 ?
                            • Kitmenk
                              • 19
                              Tak sobie teraz przeglądałem ten mój scan i wyszło, że auto w 2012 roku miało 215000 przebiegu. No to musi być chyba ze 200000 cofnięte z tego wynika.
                              • Maly745
                                • 773
                                Zamieszczone przez Kitmenk Zobacz wpis
                                Zaznaczone oba bity
                                Skoda Octavia II FL
                                • Kitmenk
                                  • 19
                                  Zgadza się! Działają światła mijania jako dzienne wyłączane hamulcem ręcznym trzeba było wpisać 10000101 i zadziałało. Teraz jak wyłączyć pozycyjne, bo po co się mają świecić w dzień z mijania.
                                  • mcaris
                                    • 423
                                    Pompę ABS polecam 1K0-907-379-BJ zakładałem taką do siebie i w zupełności wystarczy i można wyrwać w dobrej cenie. TPMS na tym liczniku z literką F nie pójdzie zostaje tylko fleszowanie licznika do Q
                                    Ostatnio edytowany przez mcaris; 37031.
                                    ByŁ Leonsio 1.8T 200 km. Jest Szkodnik 140km
                                    • #19
                                      A ten Q to jest ostatnia wersja w o2?
                                      • mcaris
                                        • 423
                                        Dla beny raczej tak mowa oczywiście O II FL
