Błędy Octavia II VCDS
  • judox
    • 3
    Witam może mi ktoś pomóc z błędami
    Te w silniku to wiem czujnik G62 prawdopodobnie uszkodzony a drugi dotyczy tempomatu prawdopodobnie kabel urwany. Wkurza mnie ten błąd w CAN Gateway-u 01044 (nadmieniam że dołożone w aucie było radio i czujniki parkowania tył) No i jeszcze ten ostatni błąd 00576 w Park Assist
    Poniżej wklejam to co otrzymałem z VCDS
    Tuesday,07,February,2017,16:50:57:49450
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
    VCDS Version: 16.8.0.3
    Data version: 20160803 DS255
    VCDS,VAG-COM,VAGCOM,Diagnose,Diagnostics,DTC,Fault Codes,Data Logging,VW Scan Tool,Audi Scan Tool, VAG Scan Tool,Micro-CAN,HEX-USB+CAN,HEX+CAN,HEX-NET,VAG 11,VAG 12,VAG 14,VAG 15
    VIN: TMBCS61Z358030254 License Plate:
    Mileage: 272590km-169379mi Repair Order:
    Chassis Type: 1Z (1K0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 69 72 76
    VIN: TMBCS61Z358030254 Mileage: 272590km-169379miles
    00-Steering Angle Sensor -- Status: OK 0000
    01-Engine -- Status: Malfunction 0010
    03-ABS Brakes -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: Malfunction 0010
    25-Immobilizer -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    56-Radio -- Status: OK 0000
    62-Door, Rear Left -- Status: OK 0000
    69-Trailer -- Status: Not registered 0001
    72-Door, Rear Right -- Status: OK 0000
    76-Park Assist -- Status: Not registered 0011
    Address 01: Engine Labels: 03G-906-016-BKC.lbl
    Part No SW: 03G 906 016 DJ HW: 028 101 188 3
    Component: R4 1,9L EDC G000SG 6250
    Revision: 12345678 Serial number: SKZ7Z0E2884773
    Coding: 0000071
    Shop #: WSC 66565 257 00032
    VCID: 6ED3A4DE79562F3242-803A
    2 Faults Found:
    18104 - Powertrain Data Bus
    P1696 - 000 - Implausible Message from Steering Column Controller - Intermittent
    Freeze Frame:
    RPM: 1008 /min
    Torque: 78.0 Nm
    Speed: 18.0 km/h
    Load: 21.6 %
    Voltage: 14.67 V
    Bin. Bits: 11001100
    Bin. Bits: 00000000
    (no units): 1.0
    16502 - Engine Coolant Temp. Sensor (G62)
    P0118 - 000 - Signal too High
    Freeze Frame:
    RPM: 1722 /min
    Torque: 70.0 Nm
    Speed: 81.0 km/h
    Load: 23.9 %
    Voltage: 14.59 V
    Bin. Bits: 11001000
    Temperature: 45.9°C
    Temperature: 33.3°C
    Readiness: 0 0 0 0 0
    Address 03: ABS Brakes Labels: 1K0-907-379-MK70.lbl
    Part No: 1K0 907 379 P
    Component: ASR FRONT MK70 0105
    Coding: 0017025
    Shop #: WSC 73430 790 00000
    VCID: 3F8D299A6EBC96BA99-806A
    No fault code found.
    Address 08: Auto HVAC Labels: 1K0-820-047.lbl
    Part No: 1Z0 820 047
    Component: Climatic PQ35 004 0201
    Shop #: WSC 00000 000 00000
    VCID: 70EFBAA6636239C250-8024
    Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
    Part No SW: 1K0 937 049 N HW: 1K0 937 049 N*
    Component: Bordnetz-SG H34 0803
    Revision: 00H34000 Serial number: 00000001465318
    Coding: 01080E020004140000110D000000000000087F075C
    VCID: 3A7B588E759EB392AE-806E
    Subsystem 1 - Part No: 1Z1 955 119 A Labels: 1KX-955-119.CLB
    Component: Wischer SK351 012 0401
    Coding: 00065525
    Shop #: WSC 73430
    Address 15: Airbags Labels: 1K0-909-605.lbl
    Part No SW: 1K0 909 605 H HW: 1K0 909 605 H
    Component: 08 AIRBAG VW8 023 0700
    Revision: 06023000 Serial number: 00385D0N6TYZ
    Coding: 0012344
    VCID: 31697FA2A8E870CA1F-8064
    Subsystem 1 - Serial number: 6332MSME593F7C08
    Subsystem 2 - Serial number: 6342MSME3A357C08
    Subsystem 3 - Serial number: 6351HSME700D0A06
    Subsystem 4 - Serial number: 6361HSME07671E06
    Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
    Part No SW: 1K0 953 549 F HW: 1K0 953 549 F
    Component: Lenksäulenmodul 021 0050
    Coding: 0000042
    VCID: 35614BB25C805CEA43-8060
    Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
    Part No: 1Z0 920 810 D
    Component: KOMBIINSTRUMENT VD1 3560
    Coding: 0003101
    Shop #: WSC 80093 222 69422
    VCID: 336575AA52F442DA6D-8066
    Address 19: CAN Gateway Labels: 1K0-907-530-V1.clb
    Part No SW: 1K0 907 530 E HW: 1K0 907 951
    Component: Gateway H09 0110
    Revision: 09 Serial number: 2700104C29015A
    Coding: 3D3F0340071302
    VCID: 295997C28038080AD7-807C
    1 Fault Found:
    01044 - Control Module Incorrectly Coded
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 1
    Fault Frequency: 4
    Reset counter: 158
    Mileage: 272555 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 12:04:06
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
    Component: IMMO 3560
    Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN1.lbl
    Part No: 1T0 959 701
    Component: Tuersteuergeraet 09 0165
    Coding: 0000116
    VCID: 74E7B6B6177A05E2B4-8020
    Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
    Part No: 1K1 909 144 H
    Component: EPS_ZFLS Kl.1 1502
    VCID: 306F7AA6A3E279C210-8064
    Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb
    Part No: 1K0 959 433 BL
    Component: 01 KSG 0301
    Coding: 00F802007F2D8505084F010004
    VCID: 7BF59D8A3A244A9AF5-802E
    Subsystem 1 - Component: Sounder n.mounted
    Subsystem 2 - Component: NGS n.mounted
    Subsystem 3 - Component: IRUE n.mounted
    Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN1.lbl
    Part No: 1T0 959 702
    Coding: 0000116
    VCID: 75E18BB21C001CEA83-8020
    Address 56: Radio Labels: 1K0-035-1xx-56.lbl
    Part No SW: 1Z0 035 161 A HW: 01. 01. 03
    Component: Radio FO3 0008
    Coding: 0000200
    VCID: 2C576ED68FCA1D222C-8078
    Address 62: Door, Rear Left Labels: 1K0-959-703-GEN1.lbl
    Part No: 1K0 959 703 B
    Component: Tuersteuergeraet 06 0219
    Coding: 0000048
    VCID: 2F6D79DABEDC663A09-807A
    Address 69: Trailer
    Cannot be reached
    Address 72: Door, Rear Right Labels: 1K0-959-704-GEN1.lbl
    Part No: 1K0 959 704 B
    Coding: 0000048
    Address 76: Park Assist Labels: 1Z0-919-283.lbl
    Part No SW: 1Z0 919 283 B HW: 1Z0 919 283 B
    Component: Parkhilfe 4-Kan H04 0020
    Coding: 0001001
    Shop #: WSC 131071 1023 2097151
    VCID: 3D71539264B084AA8B-8068
    1 Fault Found:
    00576 - Terminal 15
    008 - Implausible Signal - Intermittent
    Freeze Frame:
    Fault Status: 00101000
    Fault Priority: 3
    Fault Frequency: 18
    Reset counter: 198
    Mileage: 272556 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 12:13:12
    End-------------------------(Elapsed Time: 01:46)--------------------------
  • kowaltom99
    • 760
    Wykoduj moduł 69 - Przyczepa - z CAN GATEWAY - to zniknie ten jeden błąd.
    Poza tym w CANGATEWAY zakoduj moduł 76
    Ostatnio edytowany przez kowaltom99; 6234.
    • judox
      • 3
      Ale w moim aucie znajduje się hak holowniczy z modułem CAN
        • 11351
        masz ori sterownik haka czy coś z modułem can?
        bo jeżeli coś to kibel
