Błędy w ABS i PDC
  • mcaris
    • 425
    Błędy w ABS i PDC
    Pomocy . Po wymianie modułu pod kierownicą wyskoczyły takie błędy:
    Teraz świeci sie knotrolka trakcji i abs i " kierownica" nie działa czujniki parkowania nie działają , lane assist oraz park assist również nie działa. Wygląda na brak komunikacji ale w moduły vcds można wejść .
    Co to może być POMOCY:
    Address 03: ABS Brakes Labels: 1K0-907-379-60EC1F.clb
    Control Module Part Number: 1K0 907 379 CC HW: 1K0 907 379 CC
    Component and/or Version: ESP MK60EC1 H46 0175
    Software Coding: 113B401C09240003881102E690200042A50D509B
    Work Shop Code: WSC 00066 123 12345
    VCID: 75E154D3DCC13FE7BA-8020
    4 Faults Found:
    01325 - Control Module for Tire Pressure Monitoring (J502)
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 190
    Mileage: 361632 km
    Time Indication: 0
    Date: 2043.14.02
    Time: 03:30:43
    Freeze Frame:
    Count: 3
    Count: 4
    Count: 12800
    Count: 16390
    Count: 50944
    Count: 0
    Count: 510
    Count: 0
    01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 190
    Mileage: 361632 km
    Time Indication: 0
    Date: 2043.14.02
    Time: 03:30:34
    Freeze Frame:
    Count: 3
    Count: 4
    Count: 4608
    Count: 297
    Count: 49920
    Count: 0
    Count: 510
    Count: 0
    00668 - Supply Voltage Terminal 30
    002 - Lower Limit Exceeded
    Freeze Frame:
    Fault Status: 01100010
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 190
    Mileage: 361634 km
    Time Indication: 0
    Date: 2043.14.02
    Time: 03:38:54
    Freeze Frame:
    Count: 3
    Count: 2
    Count: 4096
    Count: 128
    Count: 43008
    Count: 0
    Count: 254
    Count: 0
    00287 - ABS Wheel Speed Sensor; Rear Right (G44)
    012 - Electrical Fault in Circuit
    Freeze Frame:
    Fault Status: 01101100
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 190
    Mileage: 361632 km
    Time Indication: 0
    Date: 2043.14.02
    Time: 03:30:34
    Freeze Frame:
    Count: 3
    Count: 4
    Count: 4608
    Count: 80
    Count: 49920
    Count: 0
    Count: 510
    Count: 0
    Address 10: Park/Steer Assist Labels: 1Q0-919-475.clb
    Control Module Part Number: 7N0 919 475 F HW: 5Q0 919 298 C
    Component and/or Version: PLA 3.0 12KH08 0007
    Software Coding: 4061166001
    Work Shop Code: WSC 12345 123 61029
    ASAM Dataset: EV_EPHVA3CVW428GP00 001005 (VW36)
    ROD: EV_EPHVA2CVW428GP00.rod
    VCID: 3E738BFFA177BCBFAB-806A
    8 Faults Found:
    13637416 - Databus
    U1123 00 [009] - Received Error Message
    [New feature! Extended UDS fault detail is only supported by current gen. interfaces]
    Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 6
    Fault Frequency: 17
    Reset counter: 190
    Mileage: 361632 km
    Date: 2043.14.02
    Time: 03:10:23
    13637423 - Databus
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 16
    Reset counter: 190
    Mileage: 361632 km
    Date: 2043.14.02
    Time: 03:10:23
    13637426 - Databus
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 189
    Mileage: 361632 km
    Date: 2043.14.02
    Time: 03:10:23
    13637427 - Databus
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 18
    Reset counter: 190
    Mileage: 361632 km
    Date: 2043.14.02
    Time: 03:10:27
    13679388 - Databus
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 6
    Reset counter: 190
    Mileage: 361632 km
    Date: 2043.14.02
    Time: 03:10:27
    12648480 - Databus
    U1121 00 [008] - Missing Message
    Intermittent - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 6
    Reset counter: 230
    Mileage: 361632 km
    Date: 2043.14.02
    Time: 03:10:23
    13637397 - Databus
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 18
    Reset counter: 190
    Mileage: 361632 km
    Date: 2043.14.02
    Time: 03:10:23
    13688835 - Databus
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 189
    Mileage: 361632 km
    Date: 2043.14.02
    Time: 03:10:23
    ByŁ Leonsio 1.8T 200 km. Jest Szkodnik 140km
    • 11323
    po pierwsze skasuj te błędy
    po drugie tym interfejsem dużo nie poroobisz
    po trzecie zapodaj scan jeszcze raz po skasowaniu
    • mcaris
      • 425
      Błędy skasowane i dalej to samo no może w module 10 zostają tylko trzy błędy ale dalej świeci się to co napisałem wcześniej. Mam jeszcze obd eleven.
      • mcaris
        • 425
        dodatkowo jeszcze ten błąd w abs:
        Freeze Frame:
        Fault Priority: 1
        Fault Frequency: 1
        Reset counter: 190
        Mileage: 361634 km
        Time Indication: 0
        Date: 2043.14.02
        Time: 03:38:54​
        • mcaris
          • 425
          skan z vcp:
            • 11323
            coś na zasilaniu się dzieje, jak abs krzyczy o za niskim napięciu
            • mcaris
              • 425
              Panowie .
              Czy pierścień magnetyczny na piaście w tej sytuacji jak błąd wskazuje prawy tył może robić takie wariacje??. Już tłumacze . Dzisiaj poszedłem do auta kalibracja czyli kiera w prawo lewo środek gaśnie kierownica ruszam powoli do przodu gaśnie reszta błedów (tcs ,abs) i działa PDC ale po przekroczeniu 20km/h błedy wracają . I kilka takich powtórzeń i to samo czyżby ten pierścień??
              • mcaris
                • 425
                Sprawa chyba się rozwiązała. Uwalony moduł 1K0953549CH . W sumie nie cały moduł tylko część odpowiedzialna za czujnik g85 reszta ok. Na szczęście mam magiel 3gen. i tam jest też g85 więc przeprowadziłem kalibrację odpiołem dwa przewody can 11 i 12 z wtyczki wchodzącej do modułu. Teraz jest tylko błąd:
                012 - Electrical Fault in Circuit ale dopiero wyskakuje jak przejadę mały odcinek. Po wykasowaniu błędu wszystko gaśnie dopiero jak ruszę znowu błąd więc obstawiam piastę bo czujnik wymieniony na nowy.​
                • mcaris
                  • 425
                  Jednak problem z czujnikiem nie zniknął tzn. Latem i przy dodatnich temperaturach nie było problemu teraz jak temperatura spada poniżej zera to z automatu zapalaja się kontrolki abs i wywala bład : 00287 - ABS Wheel Speed Sensor; Rear Right (G44)
                  I teraz czy może to jest wina samego połączenia (czujnik wymieniony) czujnika z pompą czy co najgorsze uszkodzona elektronika w pompie?
                  Dodam że przewód od abs przedzwoniony i "przejście" jest.
                  Już nie mam pojęcia co to może być?
