Pomocy . Po wymianie modułu pod kierownicą wyskoczyły takie błędy:
Teraz świeci sie knotrolka trakcji i abs i " kierownica" nie działa czujniki parkowania nie działają , lane assist oraz park assist również nie działa. Wygląda na brak komunikacji ale w moduły vcds można wejść .
Co to może być POMOCY:
Address 03: ABS Brakes Labels: 1K0-907-379-60EC1F.clb
Control Module Part Number: 1K0 907 379 CC HW: 1K0 907 379 CC
Component and/or Version: ESP MK60EC1 H46 0175
Software Coding: 113B401C09240003881102E690200042A50D509B
Work Shop Code: WSC 00066 123 12345
VCID: 75E154D3DCC13FE7BA-8020
4 Faults Found:
01325 - Control Module for Tire Pressure Monitoring (J502)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 190
Mileage: 361632 km
Time Indication: 0
Date: 2043.14.02
Time: 03:30:43
Freeze Frame:
Count: 3
Count: 4
Count: 12800
Count: 16390
Count: 50944
Count: 0
Count: 510
Count: 0
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 190
Mileage: 361632 km
Time Indication: 0
Date: 2043.14.02
Time: 03:30:34
Freeze Frame:
Count: 3
Count: 4
Count: 4608
Count: 297
Count: 49920
Count: 0
Count: 510
Count: 0
00668 - Supply Voltage Terminal 30
002 - Lower Limit Exceeded
Freeze Frame:
Fault Status: 01100010
Fault Priority: 1
Fault Frequency: 1
Reset counter: 190
Mileage: 361634 km
Time Indication: 0
Date: 2043.14.02
Time: 03:38:54
Freeze Frame:
Count: 3
Count: 2
Count: 4096
Count: 128
Count: 43008
Count: 0
Count: 254
Count: 0
00287 - ABS Wheel Speed Sensor; Rear Right (G44)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 1
Fault Frequency: 1
Reset counter: 190
Mileage: 361632 km
Time Indication: 0
Date: 2043.14.02
Time: 03:30:34
Freeze Frame:
Count: 3
Count: 4
Count: 4608
Count: 80
Count: 49920
Count: 0
Count: 510
Count: 0
4 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 190
Mileage: 361632 km
Time Indication: 0
Date: 2043.14.02
Time: 03:30:43
Freeze Frame:
Count: 3
Count: 4
Count: 12800
Count: 16390
Count: 50944
Count: 0
Count: 510
Count: 0
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 190
Mileage: 361632 km
Time Indication: 0
Date: 2043.14.02
Time: 03:30:34
Freeze Frame:
Count: 3
Count: 4
Count: 4608
Count: 297
Count: 49920
Count: 0
Count: 510
Count: 0
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 190
Mileage: 361634 km
Time Indication: 0
Date: 2043.14.02
Time: 03:38:54
Freeze Frame:
Count: 3
Count: 2
Count: 4096
Count: 128
Count: 43008
Count: 0
Count: 254
Count: 0
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 190
Mileage: 361632 km
Time Indication: 0
Date: 2043.14.02
Time: 03:30:34
Freeze Frame:
Count: 3
Count: 4
Count: 4608
Count: 80
Count: 49920
Count: 0
Count: 510
Count: 0
Address 10: Park/Steer Assist Labels: 1Q0-919-475.clb
Control Module Part Number: 7N0 919 475 F HW: 5Q0 919 298 C
Component and/or Version: PLA 3.0 12KH08 0007
Software Coding: 4061166001
Work Shop Code: WSC 12345 123 61029
ASAM Dataset: EV_EPHVA3CVW428GP00 001005 (VW36)
ROD: EV_EPHVA2CVW428GP00.rod
VCID: 3E738BFFA177BCBFAB-806A
8 Faults Found:
13637416 - Databus
U1123 00 [009] - Received Error Message
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 17
Reset counter: 190
Mileage: 361632 km
Date: 2043.14.02
Time: 03:10:23
13637423 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 16
Reset counter: 190
Mileage: 361632 km
Date: 2043.14.02
Time: 03:10:23
13637426 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 189
Mileage: 361632 km
Date: 2043.14.02
Time: 03:10:23
13637427 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 18
Reset counter: 190
Mileage: 361632 km
Date: 2043.14.02
Time: 03:10:27
13679388 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 6
Reset counter: 190
Mileage: 361632 km
Date: 2043.14.02
Time: 03:10:27
12648480 - Databus
U1121 00 [008] - Missing Message
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Reset counter: 230
Mileage: 361632 km
Date: 2043.14.02
Time: 03:10:23
13637397 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 18
Reset counter: 190
Mileage: 361632 km
Date: 2043.14.02
Time: 03:10:23
13688835 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 189
Mileage: 361632 km
Date: 2043.14.02
Time: 03:10:23
8 Faults Found:
13637416 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 17
Reset counter: 190
Mileage: 361632 km
Date: 2043.14.02
Time: 03:10:23
13637423 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 16
Reset counter: 190
Mileage: 361632 km
Date: 2043.14.02
Time: 03:10:23
13637426 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 189
Mileage: 361632 km
Date: 2043.14.02
Time: 03:10:23
13637427 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 18
Reset counter: 190
Mileage: 361632 km
Date: 2043.14.02
Time: 03:10:27
13679388 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 6
Reset counter: 190
Mileage: 361632 km
Date: 2043.14.02
Time: 03:10:27
12648480 - Databus
Freeze Frame:
Fault Priority: 6
Reset counter: 230
Mileage: 361632 km
Date: 2043.14.02
Time: 03:10:23
13637397 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 18
Reset counter: 190
Mileage: 361632 km
Date: 2043.14.02
Time: 03:10:23
13688835 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 189
Mileage: 361632 km
Date: 2043.14.02
Time: 03:10:23
