Zamieszczone przez 1 6 D
Aktualizacja softu przekładni 3 generacji 1K0909144...
Have U tried to edit this script for Octavia? This is my edition of this two files, I have corrected issue with -1- button:
Zostaw komentarz:
Zamieszczone przez 1 6 DEvery option I choose, there is the same error, I haven't changed Octavia 2 RS and there was error too. This 234 and -1- I haven't changed in script files.
t4 — Fabia 1999;
t5 — Fabia 2007;
t6 — Octavia 1997;
t7 — Octavia 2004;
t8 — Roomster 2006;
t9 — Rapid 2012;
t10 — Superb 2001;
t11 — Superb 2008;
t12 — Yeti 2012.
Zostaw komentarz:
Zostaw komentarz:
Also I see some entangled buttons in last screenshot, eg. curve 234 stands for button -1-.
Zostaw komentarz:
There was some numbers, I will connect second time with this edited script, maybe something more should be changed in more files.
I made small research and file name "v074N0741K0___Lenkung_Reibung" was used in few nore files in skoda_31 folder, for example "SYS48_60____1_1110_31_Anpassung_J500.tst", it's in t8/testprog and t12/testprog folders.
Zostaw komentarz:
Zamieszczone przez 1 6 DHi, I have edited this two files about adapting but I have error during it, I haven't made print screen so I have to do it again.
Zostaw komentarz:
Hi, I have edited this two files about adapting but I have error during it, I haven't made print screen so I have to do it again. After last screen there appear error, if U choose one position from list.
Zostaw komentarz:
Zamieszczone przez 1 6 DOne of this?
Java_SDK_v.1.4.2.15_for_Win-x32.exe
Java_SE_Development_Kit_7u2-win-x86.exe
And u must install both of them.
Zostaw komentarz:
One of this?
Zostaw komentarz:
Zamieszczone przez 1 6 DI tried run VAS on VW Sharan 2011 with UDS, it doesn't want to connect with ECU, Air condition, it can connect other nonUDS modules.
I have installed ODIS-E but when I select VW36x project it loads but nothing more, only some fault.
A couple of persons had this error, too. But somehow they fixed it.
Try to reinstall odis with proper java version (Программы › VAS PC › Java)
I used this installer and everything works fine.
Zostaw komentarz:
16D do you have any UDS controler which you can diagnose via VAS ?
ODIS also can diagnose older controlers, so there is no problem with missing chip fopr UDS.
Dont listen china seller
Most problem is with a right sw install and proper JAVA
Zostaw komentarz:
My VAS5054a head doesn't have chips for UDS and it doesn't works with ODIS, maybe in few days I will buy them and solder.
Zostaw komentarz:
Zamieszczone przez 1 6 DI found scan with 5N1 P/R versions:
Address 44: Steering Assist Labels: 5N1-909-144.clb
Part No SW: 5N1 909 144 P HW: 5N1 909 148 J
Component: J500__APA-BS KL.302 1202Address 44: Steering Assist Labels: 5N1-909-144.clb
Part No SW: 5N1 909 144 R HW: 5N1 909 148 J
Component: J500__APA-BS KL.374 1401
16D, still can't understand why u don't want to use odis E :roll:
Zostaw komentarz:
Only TPI on this moment have number 2026486/3
And some text from it:
Chassis: insufficient efficiency power steering fault indicator / warning on power steering Date of resolution of publication: 28.12.2012
This update affects only cars with left-hand drive!
Fault description clients:
• Red light on the power steering malfunction in the instrument cluster.
Table from this TPI:
old______________new______________Calendar Week
5N1.909.144.J 0502 5N1.909.144.J 1101 45/2011
5N1.909.144.J 0503 5N1.909.144.J 1101 45/2011
5N1.909.144.K 0703 5N1.909.144.K 1101 45/2011
5N1.909.144.L 0802 5N1.909.144.L 1101 45/2011
5N1.909.144.L 1002 5N1.909.144.L 1101 45/2011
5N1.909.144.M 1002 5N1.909.144.M 1101 45/2011
Probably SVM code is 35FA
File appear in 064 flash DVD for VW
Before flashing check if U have offline option in VAS to flash curve characteristic.
BTW, tomorrow I will test edited script with this list od characteristics:
Curve \L\S\K\A69\L\S\K\N ... Scirocco TDI. >>>>>my factory setting
Curve \L\S\K\A234\L\S\K\N ... Audi S3.
Curve \L\S\K\A239\L\S\K\N ... Audi TTRS.
Curve \L\S\K\A243\L\S\K\N ... Audi RS3.
Curve \L\S\K\A251\L\S\K\N ... VW R-version.
Curve \L\S\K\A74\L\S\K\N ... Octavia II RS.
Zostaw komentarz:
Zamieszczone przez 1 6 DI found something about updating 5N1 Steering on Seat flash DVD:
Kod:; --- 5N1909144J - AM2678948 5N1909144J; 0503; 5N1909144J; 5N1909144N_1101.sgo; 5N1909144J; 5N1909144N_1101.sgo; ; ; ; --- 5N1909144K - AM2678948 5N1909144K; 0703; 5N1909144K; 5N1909144N_1101.sgo; 5N1909144K; 5N1909144N_1101.sgo; ; ; ; --- 5N1909144L - AM2668736 5N1909144L; 1002; 5N1909144L; 5N1909144N_1101.sgo; 5N1909144L; 5N1909144N_1101.sgo; ; ; ; --- 5N1909144M - AM2668736 DUM000027; v074N2378J0___Lenkung_Reibung.sgo; 5N1909144M; v074N2388J0___Lenkung_Reibung.sgo ; Mehrfachflashen 5N1909144M; 1002; 5N1909144M; 5N1909144N_1101.sgo; 5N1909144M; 5N1909144N_1101.sgo; ; ;
5N1909144N_1401_BP.sgo is 100% safe to flash on
5N1909144M 5N1909148G J500_APA-BS KL.286 H03 1002
Zostaw komentarz:
Probably newest version file is 5N1909144R_1401_BP.sgo, but for sure we need find TPI about this.
Zostaw komentarz:
Zamieszczone przez nightrider.......
U can download latest available TPIs and search thru them for the info about new firmwares.
It is 100% risk free if ... will follow the instructions.
Finally I figured out how to flash the rack (thanks to 16D 8) ), the next step is to find out how to edit a curve...Downloaded eeprom from my rack, digging it for any clues how all this works.
Part No SW: 5N1 909 144 M HW: 5N1 909 148 G
Component: J500__APA-BS KL.310 1002
Zostaw komentarz:
Zostaw komentarz:
Zamieszczone przez 1 6 DU want to create own curve characteristic? Maybe ... should decode few sgo files with characteristics to bin and look inside with hex editor or something. Find same data which could be speed values for example.
Some sgo crypted with AES, so there is no luck (yet....) to decode them. Feels we have to use some kind of disassembler...
Zostaw komentarz:
U want to create own curve characteristic? Maybe you should decode few sgo files with characteristics to bin and look inside with hex editor or something. Find same data which could be speed values for example.
Zostaw komentarz:
Zamieszczone przez spacewalkerMy one is 5N1 .... but I am not gonna try SW update. All is working so no point for me.
Is not a cluster which ... can replace within a 5 min 8)
It is 100% risk free if you will follow the instructions.
Zostaw komentarz:
Zostaw komentarz:
