pare bledow, prosze o pomoc bo ja sie nie znam
  • iKac
    • 10
    Iwan89, Masz centralny z pilota :?:
  • stembalski17
    • 8
    moze ktos powiedziec co to sa za bledy ?
    Monday,07,July,2014,20:46:23:10074
    VCDS Version: Beta 11.2.0
    Data version: Unknown
    Chassis Type: 1K0
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 55 56 62 72 76 7D
    VIN: TMBBE61Z058039514 Mileage: 196530km/122118miles
    00-Steering Angle Sensor -- Status: OK 0000
    01-Engine -- Status: Malfunction 0010
    03-ABS Brakes -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: Malfunction 0010
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    25-Immobilizer -- Status: OK 0000
    42-Door Elect, Driver -- Status: Malfunction 0010
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    52-Door Elect, Pass. -- Status: Malfunction 0010
    55-Xenon Range -- Status: OK 0000
    56-Radio -- Status: OK 0000
    62-Door, Rear Left -- Status: Malfunction 0010
    72-Door, Rear Right -- Status: OK 0000
    76-Park Assist -- Status: OK 0000
    7D-Aux. Heat -- Status: OK 0000
    Address 01: Engine Labels: None
    Part No SW: 03G 906 016 HF HW: 028 101 229 2
    Component: R4 2,0L EDC G010SG 7000
    Revision: 12345678 Serial number: SKZ7Z0E2970921
    Coding: 0000072
    Shop #: WSC 73430 790 00000
    VCID: 6ED7CA8B0257
    2 Faults Found:
    17056 - Cylinder 2 Glow Plug Circuit (Q11): Electrical Fault
    P0672 - 000 - -
    Freeze Frame:
    RPM: 0 /min
    Torque: 282.0 Nm
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 11.48 V
    Bin. Bits: 00101100
    Temperature: -12.6°C
    Bin. Bits: 00110000
    18104 - Powertrain Data Bus: Implausible Message from Steering Column Controller
    P1696 - 000 - - - Intermittent
    Freeze Frame:
    RPM: 0 /min
    Torque: 134.0 Nm
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 11.63 V
    Bin. Bits: 00101100
    Bin. Bits: 11000000
    (no units): 3.0
    Readiness: 0 0 0 0 0
    Address 03: ABS Brakes Labels: Redir Fail!
    Part No: 1K0 907 379 K
    Component: ESP FRONT MK60 0104
    Coding: 0023170
    VCID: 3A7F36DB0E9F
    No fault code found.
    Address 08: Auto HVAC Labels: None
    Part No: 1Z0 907 044 J
    Component: ClimatronicPQ35 084 0305
    Shop #: WSC 00000 000 00000
    VCID: 3D753DC71FB1
    Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
    Part No SW: 1K0 937 049 N HW: 1K0 937 049 N*
    Component: Bordnetz-SG H34 0803
    Revision: 00H34000 Serial number: 00000003040473
    Coding: F18A8F381008140000110D000000000000187F0632
    VCID: 3A7F36DB0E9F
    Subsystem 1 - Part No: 1Z1 955 119 A
    Component: Wischer SK351 012 0401
    Coding: 00065525
    Shop #: WSC 73430
    Subsystem 2 - Part No: 1K0 955 559 M
    Component: RegenLichtSens 005 0605
    Coding: 00217125
    Shop #: WSC 73430
    Address 15: Airbags Labels: None
    Part No SW: 1K0 909 605 M HW: 1K0 909 605 M
    Component: Q2 AIRBAG VW8 024 0700
    Revision: 07024000 Serial number: 0038DD0RKN0L
    Coding: 0020786
    VCID: 366722EB3A87
    Address 16: Steering wheel Labels: None
    Part No SW: 1K0 953 549 G HW: 1K0 953 549 G
    Component: Lenksäulenmodul 021 0050
    Coding: 0002042
    VCID: 366722EB3A87
    Part No: XXXXXXXXXXX
    Component: Lenkradmodul 007 0050
    1 Fault Found:
    00888 - Wiper Switch for Intermittent Operation (E22)
    014 - Defective
    Address 17: Instruments Labels: None
    Part No: 1Z0 920 841 D
    Component: KOMBIINSTRUMENT VD1 0918
    Coding: 0005101
    Shop #: WSC 40711 146 18283
    VCID: 37792FEF3D8D
    Address 19: CAN Gateway Labels: None
    Part No SW: 1K0 907 530 E HW: 1K0 907 951
    Component: Gateway H11 0110
    Revision: 11 Serial number: 29001054088435
    Coding: 7D3F0F40071302
    VCID: 295DF997FB39
    Address 25: Immobilizer Labels: None
    Component: IMMO VD1 0918
    VCID: 37792FEF3D8D
    Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN1.lbl
    Part No: 1T0 959 701
    Component: Tuersteuergeraet 09 0165
    Coding: 0000118
    VCID: F4E358E3EC7B
    1 Fault Found:
    00928 - Locking Module for Central Locking; Front Driver Side (F220)
    008 - Implausible Signal - Intermittent
    Address 44: Steering Assist Labels: 1Kx-909-14x-44.lbl
    Part No: 1K1 909 144 H
    Component: EPS_ZFLS Kl.2 1502
    VCID: 306B14F3D8E3
    Address 46: Central Conv. Labels: 1K0-959-433-MIN.lbl
    Part No: 1K0 959 433 AK
    Component: KSG 0401
    Coding: 00D002403F2D8505484FC61004C8
    VCID: 79FDE9D74B19
    Subsystem 5 - Part No: 1Z0 951 171 A
    Component: NeigungsSensor 008 4802
    Coding: 00000000
    Shop #: WSC 00000
    Part No: 1K0 951 605 C
    Component: LIN BACKUP HORN H03 1301
    Component: Innenraumueberw.008 4802
    Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN1.lbl
    Part No: 1T0 959 702
    Coding: 0000118
    VCID: F5E565E7E701
    1 Fault Found:
    00944 - Heated Exterior Mirror; Passenger Side (Z5)
    012 - Electrical Fault in Circuit
    Address 55: Xenon Range Labels: None
    Part No: 1T0 907 357
    Component: Dynamische LWR 0002
    Coding: 0000007
    VCID: F4E358E3EC7B
    Address 56: Radio Labels: None
    Part No SW: 1Z0 035 161 A HW: 01. 01. 03
    Component: Radio FO3 1008
    Coding: 0000400
    Shop #: WSC 40711 150 82544
    VCID: 2C530083F4CB
    Address 62: Door, Rear Left Labels: None
    Part No: 1K0 959 703 B
    Component: Tuersteuergeraet 06 0219
    Coding: 0000048
    VCID: 2F69178FC5DD
    1 Fault Found:
    00934 - Electric Window Motor; Rear Left (V26)
    005 - No or Incorrect Basic Setting / Adaptation - Intermittent
    Address 72: Door, Rear Right Labels: None
    Part No: 1K0 959 704 B
    Coding: 0000048
    VCID: 306B14F3D8E3
    Address 76: Park Assist Labels: None
    Part No SW: 1Z0 919 283 B HW: 1Z0 919 283 B
    Component: Parkhilfe 4-Kan H04 0020
    Coding: 0000001
    VCID: 3D753DC71FB1
    Address 7D: Aux. Heat Labels: None
    Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
    Component: PTC-Element 0404
    Revision: 00800000 Serial number:
    VCID: 2D550D87CFD1
    End ---------------------------------------------------------------------
    jesli wpisalem nie w tym poscie to prosze o wyrozumialosc i przeniesc temat do odpowiedniego postu
    • 1 6 D
      • 547
      Druga świeca żarowa może być spalona, lub styk uszkodzony, drugi błąd w silniku jeśli dobrze kojarzę jest jak manetka tempomatu chyba szwankuje. Manetka wycieraczek a raczej pokrętło do regulacji częstotliwości może być też do wyczyszczenia.
      Szkło lusterka po stronie pasażera ma wypalone grzanie lub kabel ułamany.
      Tylne lewe drzwi potrzebują adaptacji końcowych położeń szyby. Robi się to przyciskami w drzwiach kierowcy. Należy to zrobić tak, zjechać szybą do końca w dół i przytrzymać guzik wciśnięty na około 2 sekundy jak już do końca szyba dojedzie i to samo w górę razem z przytrzymaniem guzika na 2 sekundy po dojechaniu szyby do końca.
      http://chomikuj.pl/lusob/VCDS
        • 11318
        drzwi kierowcy - mikrostyk/czujnik zamknięcia drzwi do reanimacji lub wymiana zamka lub uszkodzona wiązka do drzwi
        • stembalski17
          • 8
          no to tak jak myslalem w dzwiach to same pierdoly, ale najbardziej chodzilo mi o te bledy w silniku i w kierownicy, naszczescie nic powaznego z tego co mowicie.
          Swiece sie sprawdzi, manetka faktycznie czasami szwankuje i nie da sie wlaczyc tempomatu, pokretlo do regulacji szybkosci wycieraczek zdaje sie wogole nie dzialac, lusterko nie grzeje bo jest klejone ( to samo bylo z druga strona, po wymianie grzeje), adaptacje zaraz zrobie (dzieki za info jak to zrobic), a w drzwiach kierowcy tez czujnik poszedl bo nie daje znaku otwartch drzwi na MFA no ale czasem da znac ze dziala (po mimo zamknietych drzwi, da sygnal ze sa otwarte) np w nocy i alarm budzi wszystkich do okola
          Dziekuje wam za pomoc
          • stembalski17
            • 8
            Witam, znowu potrzebuje waszej pomocy kupilem superba i wrzucilem go w domu na kompa oto lista bledow ktore mi pokazal VCDS
            Saturday,21,October,2017,16:16:06:10074
            Data version: 20110305
            Chassis Type: 7N0
            Scan: 01 03 05 08 09 10 15 16 17 19 22 25 2B 2E 36 37 42 44 46 47
            52 55 56 62 6D 72 77
            VIN: TMBLB93T0B9007837
            04-Steering Angle -- Status: OK 0000
            05-Acc/Start Auth. -- Status: Malfunction 0010
            10-Park/Steer Assist -- Status: OK 0000
            16-Steering wheel -- Status: OK 0000
            22-AWD -- Status: Malfunction 0010
            2B-Steer. Col. Lock -- Status: OK 0000
            2E-Media Player 3 -- Status: OK 0000
            36-Seat Mem. Drvr -- Status: OK 0000
            37-Navigation -- Status: OK 0000
            42-Door Elect, Driver -- Status: OK 0000
            47-Sound System -- Status: OK 0000
            62-Door, Rear Left -- Status: OK 0000
            6D-Trunk Elect. -- Status: OK 0000
            77-Telephone -- Status: OK 0000
            Address 01: Engine (CDA) Labels: 06J-907-115-CDA.clb
            Part No SW: 3T0 907 115 G HW: 1Z0 907 115 F
            Component: 1.8l R4/4V TFSI 0030
            Revision: AAH17--- Serial number:
            Coding: 0203000C180F0160
            Shop #: WSC 00320 223 96732
            VCID: 356525E72781
            1 Fault Found:
            000665 - Boost Pressure Regulation: Control Range Not Reached
            P0299 - 000 - -
            Freeze Frame:
            Fault Status: 01100000
            Fault Priority: 0
            Fault Frequency: 1
            Mileage: 190862 km
            Time Indication: 0
            Date: 2000.14.11
            Time: 07:34:20
            Freeze Frame:
            RPM: 2370 /min
            Load: 84.7 %
            Speed: 80.0 km/h
            Temperature: 95.0°C
            Temperature: 21.0°C
            Absolute Pres.: 960.0 mbar
            Voltage: 13.843 V
            Readiness: 0000 0000
            Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
            Part No SW: 1K0 907 379 AT HW: 1K0 907 379 AT
            Component: ESP MK60EC1 H30 0105
            Revision: 00H30001
            Coding: 843D601619220001211306E798200041350000
            Shop #: WSC 33361 790 00070
            VCID: 84030823BCDB
            Address 05: Acc/Start Auth. (J513) Labels: 5K0-959-434.clb
            Part No SW: 5K0 959 434 HW: 5K0 959 434
            Component: VWKESSYPQ35GP 082 0707
            Revision: 00082000 Serial number: 0000000000
            Coding: 030C0C
            Shop #: WSC 33361 074 00070
            ASAM Dataset: EV_KESSY_PQ35GP A01010
            ROD: EV_KESSY_PQ35GP_SK46.rod
            VCID: F2EF5EFB966F
            2 Faults Found:
            1052936 - Touch Sensor on Exterior Door Grip; Driver Side
            B116B 29 [008] - Bus Signal/Message Failure
            Freeze Frame:
            Fault Status: 00000001
            Fault Priority: 4
            Fault Frequency: 1
            Reset counter: 101
            Mileage: 190651 km
            Date: 2014.14.24
            Time: 08:01:57
            1057035 - Antenna for Keyless Entry System; Drivers Side
            B116F 13 [009] - Reserved by ISO 15031-6:2005
            Freeze Frame:
            Fault Priority: 4
            Fault Frequency: 5
            Reset counter: 54
            Mileage: 187669 km
            Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
            Part No SW: 3T0 907 044 BC HW: 3T0 907 044 BC
            Component: Climatronic H15 0401
            Revision: 00005001
            Coding: 0000000002
            Shop #: WSC 33361 790 00999
            ASAM Dataset: EV_Climatronic A01006
            ROD: EV_Climatronic_SK46.rod
            VCID: 74E3D8E36C7B
            Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
            Part No SW: 1K0 937 087 P HW: 1K0 937 087 P
            Component: BCM PQ35 H+ 104 0615
            Revision: 00104 AE
            Coding: 46190AB8E85BF1C040080080110089E4427100AE776D8FF05C 014000A040
            VCID: 3E773ACB12B7
            Subsystem 1 - Part No: 3T1 955 119
            Component: Wischer 01061 22 0602
            Coding: 00D7B7
            Subsystem 2 - Part No: 1K0 955 559 AH
            Component: RLS 290510 05 54 0403
            Coding: 072BED
            Subsystem 3 - Part No: 7N0 951 171
            Component: DWA-Sensor 00 002 0205
            Subsystem 4 - Part No: 1K0 951 605 C
            Component: LIN BACKUP HO H05 1501
            Address 10: Park/Steer Assist (J791) Labels: 1T0-919-475.clb
            Part No SW: 3T0 919 475 A HW: 3T0 919 475
            Component: PARKHILFE PLA H07 0003
            Revision: -------- Serial number: 78331014000098
            Coding: 100008
            VCID: 3B7133DF01A5
            Address 15: Airbags Labels: 5N0-959-655.lbl
            Part No SW: 3T0 959 655 B HW: 3T0 959 655 B
            Component: J234__LCR VW10 HI 1916
            Revision: 19014000 Serial number: 003GRPAJRB3C
            Coding: 0017234
            VCID: 408B44336843
            Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
            Part No SW: 5K0 953 521 BR HW: 5K0 953 569 E
            Component: LENKS.MODUL 009 0136
            Revision: FF010036 Serial number: 20100515200056
            Coding: 100A140000
            ASAM Dataset: EV_SMLSNGVOLWS A01004
            ROD: EV_SMLSNGVOLWS_SK46.rod
            VCID: 7DF5FDC75F31
            MFL:
            Subsystem 1 - Part No SW: 3T0 959 537 HW: 3T0 959 537
            Component: E221__MFL-URO H07 0012
            Coding: 820000
            Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
            Part No SW: 3T1 920 841 G HW: 3T1 920 841 G
            Component: KOMBI H04 0406
            Serial number: 00000000000000
            Coding: 111F01
            ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04089
            ROD: EV_Kombi_UDS_VDD_RM09_SK46.rod
            VCID: 37792FEF3D8D
            Address 19: CAN Gateway Labels: 7N0-907-530-V1.clb
            Part No SW: 7N0 907 530 HW: 1K0 907 951
            Component: J533 Gateway H27 0602
            Revision: H27 Serial number: 290510F2001565
            Coding: E9A3FF0652061203009302
            VCID: EDD54D878F51
            Address 22: AWD Labels: Redir Fail!
            Part No SW: 0BR 907 554 B HW: 0BR 907 554 B
            Component: Haldex 4Motion 3017
            Coding: 0000005
            VCID: 448348237C5B
            1 Fault Found:
            01155 - Clutch
            003 - Mechanical Failure - Intermittent
            Freeze Frame:
            Fault Status: 10000011
            Fault Priority: 2
            Fault Frequency: 57
            Reset counter: 48
            Mileage: 3618101 km
            Time Indication: 4
            Freeze Frame:
            Time: 0.00 s
            Raw, Form. N/A: 000 000 000
            Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
            Part No SW: 5K0 953 234 HW: 5K0 953 234
            Component: IMMO H04 0406
            Coding: 000007
            ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03008
            ROD: EV_Immo_UDS_VDD_RM09_SK46.rod
            VCID: EADF469BBEBF
            Address 2B: Steer. Col. Lock (J764) Labels: 5K0-905-861.clb
            Part No SW: 5K0 905 861 HW: 5K0 905 861
            Component: ELV-PQ35 018 0100
            Revision: 00000000 Serial number: 10000084425003
            Coding: 0100000000000000
            ASAM Dataset: EV_ELVMarquVW360UDS A01003
            ROD: EV_ELVMarquVW360UDS_SK46.rod
            VCID: EDD54D878F51
            Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
            Part No SW: 5N0 035 342 C HW: 5N0 035 342 C
            Component: SG EXT.PLAYER H13 0111
            Revision: A1001003 Serial number: 7668084870
            Coding: 010000
            VCID: 2759FFAFED2D
            Address 36: Seat Mem. Drvr Labels: 3C0-959-760.lbl
            Part No SW: 3C8 959 760 HW: 3C8 959 760
            Component: J810 0801
            Revision: 00002000 Serial number: 00000000000000
            Coding: 0000003
            VCID: F2EF5EFB966F
            Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
            Part No SW: 3T0 035 680 A HW: 3T0 035 680 A
            Component: RNS-MID H06 2724
            Revision: AB001001 Serial number: SKZ6Z7K9150014
            Coding: 020600020000008100
            ASAM Dataset: ------------------------- ------
            VCID: 2E570A8BC2D7
            Address 42: Door Elect, Driver (J386) Labels: 8X0-959-793.clb
            Part No SW: 8X0 959 793 C HW: 8X0 959 793 C
            Component: TSG FA H09 0409
            Revision: -------- Serial number: --------------
            Coding: 011D0220DE00001000
            VCID: 4D956D07AF11
            Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
            Part No: 1K0 909 144 J
            Component: EPS_ZFLS Kl. 195 3001
            Revision: 00H17000
            VCID: 316D11F7D3E9
            Address 47: Sound System (R12) Labels: 3T0-035-456.clb
            Part No SW: 3T0 035 456 HW: 3T0 035 456
            Component: KonzernAmp10K H06 0342
            Revision: -------- Serial number: BP218209142623
            ASAM Dataset: EV_AudioVerst10KanalBNO1 A01003
            ROD: EV_AudioVerst10KanalBNO1_SK46.rod
            VCID: EED74A8B8257
            Address 52: Door Elect, Pass. (J387) Labels: 8X0-959-792.clb
            Part No SW: 8X0 959 792 C HW: 8X0 959 792 C
            Component: TSG BF H09 0409
            VCID: 4C936003540B
            1 Fault Found:
            02123 - Door Warning Light / Entry Light
            012 - Electrical Fault in Circuit - Intermittent
            Freeze Frame:
            Fault Status: 00101100
            Fault Priority: 3
            Fault Frequency: 1
            Reset counter: 111
            Mileage: 190916 km
            Time Indication: 0
            Address 55: Xenon Range Labels: 5M0-907-357-V2.lbl
            Part No SW: 5M0 907 357 C HW: 5M0 907 357 C
            Component: AFS-Steuergeraet 0142
            Revision: 00H04000 Serial number:
            Coding: 1376839
            VCID: 346318E32CFB
            Subsystem 1 - Part No: 7L6 941 329 B
            Component: AFS-Lst.-Modul l 0004
            Coding: 00000021
            Subsystem 2 - Part No: 7L6 941 329 B
            Component: AFS-Lst.-Modul r 0004
            Coding: 00000021
            Address 56: Radio (J0506) Labels: 1T0-035-680.clb
            VCID: 2E570A8BC2D7
            Address 62: Door, Rear Left (J388) Labels: None
            Part No SW: 8X0 959 795 B HW: 8X0 959 795 B
            Component: TSG HL H06 0409
            Coding: 010C00200000001000
            VCID: 4E976A0BA217
            Address 6D: Trunk Elect. (----) Labels: 7N0-959-107.clb
            Part No SW: 7N0 959 107 A HW: 7N0 959 107 A
            Component: HDSG-Modul H11 0802
            Revision: 41011001 Serial number: 141000031
            Coding: 082301C002
            ASAM Dataset: EV_HDSGSk462 301133
            ROD: EV_HDSGSk462.rod
            VCID: 356525E72781
            Address 72: Door, Rear Right (J389) Labels: None
            Component: TSG HR H06 0409
            VCID: 4E976A0BA217
            Address 77: Telephone (J412) Labels: 3C8-035-730-A.clb
            Part No SW: 3C8 035 730 A HW: 3C8 035 730 A
            Component: Telefon 007 0078
            Revision: -------- Serial number: 35909603004528
            Coding: 020100000100010000000000
            ASAM Dataset: EV_UHVPremi A01005
            ROD: EV_UHVPremi_SK46.rod
            VCID: 214DE1B78309
            • hubi_pl
              • 39
              Czy po wykasowaniu błędów, te wyżej wklejone powróciły?
              Dobrze jakbyś napisał jakie są objawy usterek, np napęd 4x4, czy działa, czy nie?
              ps. dobrze jest wrzucać tylko odczyty z błędami, te gdzie nie ma błędów tylko zamazują całokształt.
              Mr Haldex - jak umiem to zawsze pomogę.
              www.awdcarparts.com
              • stembalski17
                • 8
                po wykasowaniu bledow nie sprawdzalem juz drugi raz, naped nie wiem czy dziala bo nie mam tak duzego trawnika zeby polatac bokiem, jestem umowiony na wymiane oleju i filtra w haldexie
                • hubi_pl
                  • 39
                  Nie potrzebujesz trawnika.
                  Wyłącz ESP i rusz mocno, jak przód zerwie to znaczy że nie masz napędu.
                  www.awdcarparts.com
                  • stembalski17
                    • 8
                    przod nie moze mielic ? sprobujemy Dzieki za podpowiedz
                    a te trzy bledy elektryczne to co to moze byc ?
                    • hubi_pl
                      • 39
                      Sczytaj jeszcze raz po kasowaniu błędów czy powróciły. Te błędy mają związek z centralnym zamkiem jak widać - klamka, odbiornik kluczyka i światło.
                      www.awdcarparts.com
                      • stembalski17
                        • 8
                        no wiec probowalem tak jak mowiles i przednie nie mieszaly auto mozna powiedziec ze wystrzelilo z miejsca, cos zasmierdzialo (chyba sprzeglo hehehe) ale po chwilii przestalo.
                        W domu podlaczylem do kompa i bledu haldexa nie bylo szkoda ze reszta swieci nadal. W Haldexie tak czy siak wymienie olej i filtry bedzie spokoj na jakis czas.
                        Dzieki za pomoc.
                        • hubi_pl
                          • 39
                          Przy wymianie oleju w Haldexie wyczyść magnes i wymień sobie olej w dyfrze. pzdr
                          www.awdcarparts.com
                          • stembalski17
                            • 8
                            jaki magnes ?
                            • hubi_pl
                              • 39
                              Widzisz ten temat - zdjęcia? https://www.klubtt.pl/showthread.php...l=1#post173038
                              www.awdcarparts.com
