Prośba o pomoc w odczycie błędów z VCDSa i w kwestii jego obsługi - pilne
  • River
    • 24
    • CXXB 1.6 TDI CR 110 KM
    Panowie, a więc pod koniec grudnia dotarł do mnie zamówiony u Chińczyka najnowszy VCDS 16.8, ale z braku czasu wziąłem się za jego testy dopiero teraz. W 1 kolejności wklejam odczyt po wykonaniu skanowania:
    Wednesday,15,February,2017,14:20:19:49450
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
    VCDS Version: 16.8.0.3
    Data version: 20160803 DS255
    www.Ross-Tech.com
    VIN: TMBDA21Z8B2102080 License Plate:
    Mileage: 147590km-91708mi
    Chassis Type: 1Z (7N0)
    Scan: 01 03 08 09 15 16 17 19 20 25 3D 42 44 46 52 56
    VIN: TMBDA21Z8B2102080 Mileage: 147590km-91708miles
    01-Engine -- Status: Malfunction 0010
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: Malfunction 0010
    19-CAN Gateway -- Status: Malfunction 0010
    20-High Beam Assist. -- Status: Cannot be reached 1100
    25-Immobilizer -- Status: OK 0000
    3D-Special Function -- Status: Cannot be reached 1100
    42-Door Elect, Driver -- Status: Malfunction 0010
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    52-Door Elect, Pass. -- Status: Malfunction 0010
    56-Radio -- Status: OK 0000
    Address 01: Engine (BSE) Labels: 06A-906-033-BGU.lbl
    Part No SW: 06A 906 033 NT HW: 06A 906 033 MP
    Component: BSE S71 1.6 2V 8459
    Revision: --H01--- Serial number:
    Coding: 0044071
    Shop #: WSC 11111 111 45725
    VCID: 7EF3949E29365FB2D2-802A
    1 Fault Found:
    16804 - Catalyst System; Bank 1
    P0420 - 000 - Efficiency Below Threshold - Intermittent
    Freeze Frame:
    RPM: 2656 /min
    Hex Value: 0x0069
    Speed: 84.4 km/h
    Temperature: 544.0°C
    Mass Air / Rev.: 218.0 mg/str
    Tank Cont.: 0.0 l
    Readiness: 0000 0000
    Address 03: ABS Brakes Labels: 1K0-907-379-MK70M.clb
    Part No SW: 1K0 907 379 AK HW: 1K0 907 379 AK
    Component: MK70 M MASR 0105
    Revision: 00H35001
    Coding: 0017665
    Shop #: WSC 73430 790 00085
    VCID: 7BF59D8A3A244A9AF5-802E
    No fault code found.
    Address 08: Auto HVAC (J301) Labels: 3C8-907-336.clb
    Part No SW: 3T0 820 047 R HW: 3T0 820 047 R
    Component: AC Manuell H16 0401
    Revision: 00007001
    Coding: 0000000002
    ASAM Dataset: EV_ACManueBHBVW36X A01010
    ROD: EV_ACManueBHBVW36X_VW32.rod
    VCID: 3E73549EA1B69FB292-806A
    Part No SW: 1K0 937 085 H HW: 1K0 937 085 H
    Component: BCM PQ35 B+ 104 0615
    Revision: 00104 AE
    Coding: 40000AB8A00508B040100080110000E4430000AE520089605C 8440000040
    Shop #: WSC 12345 123 45725
    VCID: 346776B697FA45E274-8060
    Subsystem 1 - Part No: 1Z1 955 119 D Labels: 1KX-955-119.CLB
    Component: Wischer 09011 26 0601
    Coding: 00D7B7
    1 Fault Found:
    00380 - Special Vehicle Control Module (J608)
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 43
    Mileage: 50824 km
    Time Indication: 0
    Date: 2014.05.02
    Time: 11:50:00
    Freeze Frame:
    Term 15 On
    Voltage: 12.25 V
    ON
    ON
    Term 50 Off
    OFF
    OFF
    Address 15: Airbags Labels: 1K0-909-605.lbl
    Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
    Component: Q2 AIRBAG VW8 020 2300
    Revision: 05020000 Serial number: 0038PC234KG7
    Coding: 0020786
    VCID: 3D71539264B084AA8B-8068
    Subsystem 1 - Serial number: 6332MSME5954140BA
    Subsystem 2 - Serial number: 6342MSME5A517548H
    Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
    Part No SW: 1K5 953 521 AE HW: 5K0 953 569
    Component: LENKS.MODUL 009 0136
    Revision: FF010039 Serial number: 20110114201283
    Coding: 4080040000
    ASAM Dataset: EV_SMLSNGVOLWS A01004
    ROD: EV_SMLSNGVOLWSXS.rod
    VCID: 70EFBAA6AB6239C250-8024
    Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
    Part No SW: 1Z0 920 803 K HW: 1Z0 920 803 K
    Component: KOMBI H05 0405
    Serial number: 00000000000000
    Coding: 110A00
    Shop #: WSC 73430 031 00085
    ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04089
    ROD: EV_Kombi_UDS_VDD_RM09_VW25.rod
    VCID: 3C775E96B7AA8DA2BC-8068
    1 Fault Found:
    13635328 - Function Restricted due to Missing Message(s)
    U1111 00 [009] - -
    Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 6
    Fault Frequency: 254
    Reset counter: 33
    Mileage: 50824 km
    Date: 2014.05.02
    Time: 11:49:55
    Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
    Part No SW: 7N0 907 530 C HW: 1K0 907 951
    Component: J533 Gateway H37 0614
    Revision: H37 Serial number: 080111F1001455
    Coding: 351302
    VCID: 306F7AA663E279C210-8064
    3 Faults Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 43
    Mileage: 50824 km
    Time Indication: 0
    Date: 2014.05.02
    Time: 11:50:03
    00469 - Infotainment Databus in Single Wire Operation
    011 - Open Circuit - Intermittent
    Freeze Frame:
    Fault Status: 00101011
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 46
    Mileage: 147005 km
    Time Indication: 0
    Date: 2017.01.31
    Time: 20:09:51
    03395 - Control Module for High Beam Assistant
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 43
    Mileage: 50824 km
    Time Indication: 0
    Date: 2014.05.02
    Time: 11:50:07
    Address 20: High Beam Assist.
    Cannot be reached
    Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
    Part No SW: 5K0 953 234 HW: 5K0 953 234
    Component: IMMO H05 0405
    Coding: 000000
    Shop #: WSC 00000 000 00000
    ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03008
    ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
    VCID: 6ADBA8CE8DBEC3121E-803E
    Address 3D: Special Function
    Cannot be reached
    Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
    Part No SW: 1T0 959 701 T HW: 1T0 959 701 T
    Component: Tuer-SG 009 2119
    Coding: 0000052
    VCID: 489F32463B72D10228-801C
    2 Faults Found:
    00913 - Window Regulator Switch; Front Right Driver (E81)
    008 - Implausible Signal - Intermittent
    Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
    Part No: 1K0 909 144 M
    Component: EPS_ZFLS Kl. 67 3201
    Revision: 00H20000
    VCID: 346776B657FA45E274-8060
    Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
    Part No SW: 1T0 959 702 R HW: 1T0 959 702 R
    Coding: 0000052
    VCID: 479D317A366CDE7A21-8012
    1 Fault Found:
    Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
    Part No SW: 1Z0 035 152 E HW: 1Z0 035 152 E
    Component: Radio 007 0010
    Revision: R0000000 Serial number: SKZAZ5K1525427
    Coding: 000004000001
    End-------------------------(Elapsed Time: 02:00)--------------------------
    Błąd P0420 jest mi akurat znany, bo borykam się z nim od jakiegoś czasu, ale poza wyskakującym "check engine" nie dzieje się nic ponadto, bo silnik pracuje normalnie bez zwiększonego zużycia paliwa czy spadku mocy.
    Bardziej interesuje mnie czy bardziej doświadczeni forumowicze byliby mi w stanie powiedzieć coś więcej na temat dalszej części / odczytów? Czy wszystko jest OK czy coś powinno mnie niepokoić?
    Ponadto próbując zrobić coś więcej moim VCDSem, zauważyłem, że bez problemu mogę się tylko połączyć z modułem silnika (Engine), a próba połączenia się z jakimkolwiek innym modułem powoduje problemy i wyświetla się komunikat "no response from controller" Co to może oznaczać i czy ktoś spotkał się z takim problemem?
    Ostatnio edytowany przez River; 41340.
