Panowie, a więc pod koniec grudnia dotarł do mnie zamówiony u Chińczyka najnowszy VCDS 16.8, ale z braku czasu wziąłem się za jego testy dopiero teraz. W 1 kolejności wklejam odczyt po wykonaniu skanowania:
Wednesday,15,February,2017,14:20:19:49450
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 16.8.0.3
Data version: 20160803 DS255
www.Ross-Tech.com
VIN: TMBDA21Z8B2102080 License Plate:
Mileage: 147590km-91708mi
Chassis Type: 1Z (7N0)
Scan: 01 03 08 09 15 16 17 19 20 25 3D 42 44 46 52 56
VIN: TMBDA21Z8B2102080 Mileage: 147590km-91708miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
20-High Beam Assist. -- Status: Cannot be reached 1100
25-Immobilizer -- Status: OK 0000
3D-Special Function -- Status: Cannot be reached 1100
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
Address 01: Engine (BSE) Labels: 06A-906-033-BGU.lbl
Part No SW: 06A 906 033 NT HW: 06A 906 033 MP
Component: BSE S71 1.6 2V 8459
Revision: --H01--- Serial number:
Coding: 0044071
Shop #: WSC 11111 111 45725
VCID: 7EF3949E29365FB2D2-802A
1 Fault Found:
16804 - Catalyst System; Bank 1
P0420 - 000 - Efficiency Below Threshold - Intermittent
Freeze Frame:
RPM: 2656 /min
Hex Value: 0x0069
Speed: 84.4 km/h
Temperature: 544.0°C
Mass Air / Rev.: 218.0 mg/str
Tank Cont.: 0.0 l
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 1K0-907-379-MK70M.clb
Part No SW: 1K0 907 379 AK HW: 1K0 907 379 AK
Component: MK70 M MASR 0105
Revision: 00H35001
Coding: 0017665
Shop #: WSC 73430 790 00085
VCID: 7BF59D8A3A244A9AF5-802E
No fault code found.
Address 08: Auto HVAC (J301) Labels: 3C8-907-336.clb
Part No SW: 3T0 820 047 R HW: 3T0 820 047 R
Component: AC Manuell H16 0401
Revision: 00007001
Coding: 0000000002
ASAM Dataset: EV_ACManueBHBVW36X A01010
ROD: EV_ACManueBHBVW36X_VW32.rod
VCID: 3E73549EA1B69FB292-806A
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 1K0 937 085 H HW: 1K0 937 085 H
Component: BCM PQ35 B+ 104 0615
Revision: 00104 AE
Coding: 40000AB8A00508B040100080110000E4430000AE520089605C 8440000040
Shop #: WSC 12345 123 45725
VCID: 346776B697FA45E274-8060
Subsystem 1 - Part No: 1Z1 955 119 D Labels: 1KX-955-119.CLB
Component: Wischer 09011 26 0601
Coding: 00D7B7
1 Fault Found:
00380 - Special Vehicle Control Module (J608)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 6
Fault Frequency: 1
Reset counter: 43
Mileage: 50824 km
Time Indication: 0
Date: 2014.05.02
Time: 11:50:00
Freeze Frame:
Term 15 On
Voltage: 12.25 V
ON
ON
Term 50 Off
OFF
OFF
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
Component: Q2 AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PC234KG7
Coding: 0020786
VCID: 3D71539264B084AA8B-8068
Subsystem 1 - Serial number: 6332MSME5954140BA
Subsystem 2 - Serial number: 6342MSME5A517548H
Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
Part No SW: 1K5 953 521 AE HW: 5K0 953 569
Component: LENKS.MODUL 009 0136
Revision: FF010039 Serial number: 20110114201283
Coding: 4080040000
ASAM Dataset: EV_SMLSNGVOLWS A01004
ROD: EV_SMLSNGVOLWSXS.rod
VCID: 70EFBAA6AB6239C250-8024
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 1Z0 920 803 K HW: 1Z0 920 803 K
Component: KOMBI H05 0405
Serial number: 00000000000000
Coding: 110A00
Shop #: WSC 73430 031 00085
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04089
ROD: EV_Kombi_UDS_VDD_RM09_VW25.rod
VCID: 3C775E96B7AA8DA2BC-8068
1 Fault Found:
13635328 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 254
Reset counter: 33
Mileage: 50824 km
Date: 2014.05.02
Time: 11:49:55
Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 C HW: 1K0 907 951
Component: J533 Gateway H37 0614
Revision: H37 Serial number: 080111F1001455
Coding: 351302
VCID: 306F7AA663E279C210-8064
3 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 43
Mileage: 50824 km
Time Indication: 0
Date: 2014.05.02
Time: 11:50:03
00469 - Infotainment Databus in Single Wire Operation
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 46
Mileage: 147005 km
Time Indication: 0
Date: 2017.01.31
Time: 20:09:51
03395 - Control Module for High Beam Assistant
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 43
Mileage: 50824 km
Time Indication: 0
Date: 2014.05.02
Time: 11:50:07
Address 20: High Beam Assist.
Cannot be reached
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H05 0405
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03008
ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
VCID: 6ADBA8CE8DBEC3121E-803E
Address 3D: Special Function
Cannot be reached
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 1T0 959 701 T HW: 1T0 959 701 T
Component: Tuer-SG 009 2119
Coding: 0000052
VCID: 489F32463B72D10228-801C
2 Faults Found:
00913 - Window Regulator Switch; Front Right Driver (E81)
008 - Implausible Signal - Intermittent
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K0 909 144 M
Component: EPS_ZFLS Kl. 67 3201
Revision: 00H20000
VCID: 346776B657FA45E274-8060
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 1T0 959 702 R HW: 1T0 959 702 R
Coding: 0000052
VCID: 479D317A366CDE7A21-8012
1 Fault Found:
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 1Z0 035 152 E HW: 1Z0 035 152 E
Component: Radio 007 0010
Revision: R0000000 Serial number: SKZAZ5K1525427
Coding: 000004000001
End-------------------------(Elapsed Time: 02:00)--------------------------
Błąd P0420 jest mi akurat znany, bo borykam się z nim od jakiegoś czasu, ale poza wyskakującym "check engine" nie dzieje się nic ponadto, bo silnik pracuje normalnie bez zwiększonego zużycia paliwa czy spadku mocy.
Bardziej interesuje mnie czy bardziej doświadczeni forumowicze byliby mi w stanie powiedzieć coś więcej na temat dalszej części / odczytów? Czy wszystko jest OK czy coś powinno mnie niepokoić?
Ponadto próbując zrobić coś więcej moim VCDSem, zauważyłem, że bez problemu mogę się tylko połączyć z modułem silnika (Engine), a próba połączenia się z jakimkolwiek innym modułem powoduje problemy i wyświetla się komunikat "no response from controller" Co to może oznaczać i czy ktoś spotkał się z takim problemem?
www.Ross-Tech.com
Coding: 0044071
1 Fault Found:
Freeze Frame:
RPM: 2656 /min
Hex Value: 0x0069
Speed: 84.4 km/h
Tank Cont.: 0.0 l
Revision: 00H35001
Coding: 0017665
Revision: 00007001
Coding: 0000000002
Revision: 00104 AE
Coding: 00D7B7
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 43
Mileage: 50824 km
Time Indication: 0
Date: 2014.05.02
Time: 11:50:00
Freeze Frame:
Term 15 On
Voltage: 12.25 V
ON
ON
Term 50 Off
OFF
OFF
Coding: 0020786
Coding: 4080040000
Coding: 110A00
1 Fault Found:
U1111 00 [009] - -
Freeze Frame:
Fault Priority: 6
Reset counter: 33
Mileage: 50824 km
Date: 2014.05.02
Time: 11:49:55
Coding: 351302
3 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 43
Mileage: 50824 km
Time Indication: 0
Date: 2014.05.02
Time: 11:50:03
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 46
Mileage: 147005 km
Time Indication: 0
Date: 2017.01.31
Time: 20:09:51
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 43
Mileage: 50824 km
Time Indication: 0
Date: 2014.05.02
Time: 11:50:07
Cannot be reached
Coding: 000000
Cannot be reached
Coding: 0000052
2 Faults Found:
Revision: 00H20000
Coding: 0000052
1 Fault Found:
