Problem z Kodowaniem Abs Skoda Superb 3T
  • zbigniew.gromke
    • 2021
    Mam problem z zakodowaniem abs kombinowalem z vcds ale i tak nie chce przyjąc kodu taki już kupilem mój vin
    TMBJJ73TXB9054517 silnik 1,6 tdi 2011 dorzucam skan z vcds może jest ktoś, kto to rozumie
    Monday,02,August,2021,20:16:16:00009 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64 VCDS Version: 21.3.0.0 (x64) Data version: 20210226 DS325.0 www.Ross-Tech.com VIN: TMBJJ73TXB9054517 License Plate: Chassis Type: 3T-SK46 (7N0) Scan: 01 03 08 09 10 15 16 17 19 25 36 42 44 46 52 55 56 61 62 69 72 VIN: TMBJJ73TXB9054517 Mileage: 262810km-163302miles 01-Engine -- Status: Malfunction 0010 03-ABS Brakes -- Status: Malfunction 1010 04-Steering Angle -- Status: OK 0000 08-Auto HVAC -- Status: Malfunction 0010 09-Cent. Elect. -- Status: Malfunction 0010 10-Park/Steer Assist -- Status: OK 0000 15-Airbags -- Status: Malfunction 0010 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: Malfunction 0010 19-CAN Gateway -- Status: Malfunction 0010 25-Immobilizer -- Status: OK 0000 36-Seat Mem. Drvr -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 44-Steering Assist -- Status: Malfunction 0010 46-Central Conv. -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 55-Headlight Range -- Status: OK 0000 56-Radio -- Status: Malfunction 0010 61-Battery Regul. -- Status: OK 0000 62-Door, Rear Left -- Status: OK 0000 69-Trailer -- Status: Malfunction 0010 72-Door, Rear Right -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine (J623-CAYC) Labels:. 03L-906-023-CAY.clb Part No SW: 03L 906 023 JJ HW: 03L 906 023 JH Component: R4 1.6l TDI H43 9978 Revision: --H43--- Serial number: Coding: 00114036032401080000 Shop #: WSC 33361 790 00999 ASAM Dataset: EV_ECM16TDI02103L906023JJ 003011 ROD: GV_ECM16TDI021VW32X.rod VCID: 77FD5EDBCECD4D33F2-8022 1 Fault Found: 7196 - Function Restriction due to Faults in Other Modules U1113 00 [101] - - Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 254 Mileage: 259610 km Date: 2021.07.11 Time: 19:39:54 Engine RPM: 780.50 /min Normed load value: 20.4 % Vehicle speed: 0 km/h Coolant temperature: 56 �C Intake air temperature: 25 �C Ambient air pressure: 930 mbar Voltage terminal 30: 13.214 V Unlearning counter according OBD: 40 Engine RPM: 0 /min Vehicle speed: 0 km/h Accelerator position: normalized-Accelerator position: 0.00 % Battery voltage: 12.0 V Readiness: 0 0 0 0 0 ------------------------------------------------------------------------------- Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-60EC1F.clb Part No SW: 1K0 907 379 BE HW: 1K0 907 379 BE Component: ESP MK60EC1 H31 0108 Revision: 00H31001 Coding: 00000000000000000000000000000000000000 Shop #: WSC 33361 790 00101 VCID: 76E353DFC1C7343BE9
    przepraszam nie moglem dodac pliku bo za duzy jest
