pomoc w odczycie bledow
  • wnuczek1982
    mamaj12, ale ja tam nawet czysto towarzysko zaglądam
    thearchitect, Dzięki IMO bardzo fajna opona ta Potenza. Tak, cygańskie brembulce :szeroki_usmiech
    Przegląd techniczny zaliczony, rok spokoju :wink:
    były: 126p, 127p, Caro, nexia, 206, saxo, felicja pickup 1.9, dodge GC, Jest: C1, Captur, Plan: OctaviaIII/Superb III
  • 2009jacek
    witam
    znalazlem dwa bledy w moim samochodzie jesli ktosby zechcial mi wytlumaczyc co nalezaloby zrobic w tej kwesti
    Address 01: Engine Labels: 03G-906-016-BKC.lbl
    Part No SW: 03G 906 021 TB HW: 03G 906 021 AN
    Component: R4 1,9l EDC 000SG 2047
    Revision: --H09--- Serial number:
    Coding: 0000071
    Shop #: WSC 73430 790 00000
    VCID: 72EFDEFB6DB4014
    1 Fault Found
    005712 - Powertrain Data Bus
    P1650 - 000 - Missing Message from Instrument Cluster
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 0
    Fault Frequency: 13
    Mileage: 69302 km
    Time Indication: 0
    Date: 2111.14.26
    Time: 20:43:58
    Freeze Frame:
    RPM: 0 /min
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 12.24 V
    Bin. Bits: 11000100
    Bin. Bits: 00000000
    Bin. Bits: 00000000
    Readiness: 0 0 0 0 0
    Part No SW: 1K0 937 084 HW: 1K0 937 084
    Component: BCM PQ35 B 020 0358
    Revision: 00020000
    Coding: 48180AB89041B1C04010008011000024010000AE424D81605C 4440000000
    VCID: EBD1439F0A9E50C
    Subsystem 1 - Part No: 1Z2 955 119 C
    Component: Wischer 01120 22 0601
    Coding: 00D7B7
    Subsystem 2 - Part No: 1Z0 951 171
    Component: Innenraumuebe 008 5101
    Subsystem 3 - Part No: 1K0 951 605 C
    Component: LIN BACKUP HO H03 1301
    2 Faults Found
    01134 - Alarm Horn (H12)
    002 - Lower Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Status: 00100010
    Fault Priority: 4
    Fault Frequency: 4
    Reset counter: 90
    Mileage: 66750 km
    Time Indication: 0
    Date: 2109.14.25
    Time: 19:30:19
    Freeze Frame:
    Term 15 On
    Voltage: 11.15 V
    ON
    ON
    Term 50 Off
    ON
    OFF
    00896 - Trunk Lock Unit (F256)
    008 - Implausible Signal - Intermittent
    Freeze Frame:
    Fault Status: 00101000
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 72
    Mileage: 68628 km
    Time Indication: 0
    Date: 2111.14.07
    Time: 15:08:56
    Freeze Frame:
    Term 15 Off
    Voltage: 12.45 V
    OFF
    ON
    Term 50 Off
    OFF
    OFF
    dziekuje i pozdrawiam
    • Dafik88
      • 177
      Pierwszy błąd 005712 - Powertrain Data Bus dotyczy licznika- masz jakiś problem z nim? Działa tak jak powinien?
      Drugi 01134 - Alarm Horn (H12) problem z alarmem. Ja ten sam błąd mam akurat od początku użytkowania O2 i zbytnio się tym nie przejmuję- objawem błędu u mnie jest bardzo ciche wycie alarmu.
      Trzeci 00896 - Trunk Lock Unit (F256) to problem z zamkiem w bagażniku. Po prostu zobacz czy z nim wszystko ok. Akurat ten błąd został zarejestrowany tylko raz więc podejrzewam że z zamkiem będziesz miał wszystko ok.
      Na dobry początek wykasuj błędy, pojeźdź trochę i zobacz które wrócą. Wtedy będziesz wiedział z czym jest poważniejszy problem, a co było tylko chwilowym niedomaganiem szkodnika :wink:
      Życie to nie je bajka, to je bitwa!
        • 11353
        2009jacek
        po pierwsze, fajnie by było jakbyś podał skąd jesteś
        po drugie, sterownik CECM 08x był w O2 Tour lub O2 FL, więc masz profil zły auta
        po trzecie, masz trzy błędy
        Zamieszczone przez 2009jacek
        brak komunikacji silnika z zegarami przy 69302km
        chyba padł akumulator w syrence
        klasyczne dla O2 - musisz mocniej klapę tylną zmykać
        • 2009jacek
          witam dziekuje za odp
          tak wiec problem z zegarem nie mam lub nie zauwazylem
          sygnal dziala bez zarzutu
          z trzecim bledem nie mam problemow lub ja ich nie widze
          chce dodac ze co jakis czas miga mi kontrolka ( spirala ) i wtedy jest brak mocy wtedy musze zgasic auto chwile odczekac i ponownie odpalic i wtedy jest ok
          [ Dodano: Pon 26 Sie, 13 13:52 ]
          witam nowe bledy
          Control Module Part Number: 03G 906 021 TB HW: 03G 906 021 AN
          Component and/or Version: R4 1,9l EDC 000SG 2047
          Software Coding: 0000071
          Work Shop Code: WSC 73430 790 00000
          VCID: 72EFDEFB6DB4003
          3 Faults Found
          Freeze Frame
          Fault Priority: 0
          Fault Frequency: 181
          Mileage: 69302 km
          Time Indication: 0
          Date: 2111.14.26
          Time: 20:43:58
          Freeze Frame
          RPM: 0 /min
          Speed: 0.0 km/h
          Load: 0.0 %
          Voltage: 12.24 V
          Bin. Bits: 11000100
          Bin. Bits: 00000000
          Bin. Bits: 00000000
          000550 - Throttle Pedal Position Sensor (G79)
          P0226 - 000 - Implausible Signal - Intermittent
          Freeze Frame
          Fault Status: 00100000
          Fault Priority: 0
          Fault Frequency: 2
          Mileage: 70359 km
          Time Indication: 0
          Date: 2113.14.08
          Time: 15:32:08
          Freeze Frame
          RPM: 882 /min
          Speed: 0.0 km/h
          Load: 0.0 %
          Voltage: 14.44 V
          Bin. Bits: 11000100
          Voltage: 0.912 V
          Voltage: 0.684 V
          000551 - Throttle Pedal Position Sensor (G79)
          P0227 - 000 - Signal too Low - Intermittent
          Freeze Frame
          Fault Priority: 0
          Fault Frequency: 8
          Mileage: 70385 km
          Time Indication: 0
          Date: 2113.14.09
          Time: 09:02:32
          Freeze Frame
          RPM: 1260 /min
          Speed: 24.0 km/h
          Load: 0.0 %
          Voltage: 14.59 V
          Bin. Bits: 11000100
          Torque: 173.2 Nm
          Bin. Bits: 0 01 1
