[O2] pilna diangloza
  • piotrgm
    • 13
    4tech,
  • piotrgm
    • 54
    Witam. Koledzy szfagier kupiło 2 z 2005 2l 140km dziś podpiołem go pod kompa i są takie błędy:
    Tuesday,01,October,2013,10:22:03:40973
    VCDS -- Windows Based VAG/VAS Emulator
    VCDS Version: 12.12.0.0
    Data version: 20130910
    VIN: TM License Plate:
    Mileage: 166720km-103595mi Repair Order:
    Chassis Type: 1Z (1K0)
    Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 55 56 62 65 69 72
    76
    VIN: TMBBE61ZX52054959 Mileage: 166720km/103595miles
    00-Steering Angle Sensor -- Status: OK 0000
    01-Engine -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    08-Auto HVAC -- Status: Malfunction 0010
    09-Cent. Elect. -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: Malfunction 0010
    25-Immobilizer -- Status: OK 0000
    37-Navigation -- Status: OK 0000
    42-Door Elect, Driver -- Status: Malfunction 0010
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: Sporadic communication error 1000
    52-Door Elect, Pass. -- Status: OK 0000
    55-Xenon Range -- Status: OK 0000
    56-Radio -- Status: OK 0000
    62-Door, Rear Left -- Status: Malfunction 0010
    65-Tire Pressure -- Status: Cannot be reached 1100
    69-Trailer -- Status: Malfunction 0010
    72-Door, Rear Right -- Status: Malfunction 0010
    76-Park Assist -- Status: Not registered 0011
    Address 01: Engine Labels: 03G-906-016-BKD.lbl
    Part No SW: 03G 906 016 F HW: 028 101 139 1
    Component: R4 2,0L EDC G000SG 6201
    Revision: 12345678 Serial number: SKZ7Z0E2889787
    Coding: 0000072
    Shop #: WSC 73430 790 00000
    VCID: 2643101A9147002ECEF-8073
    No fault code found.
    Readiness: 0 0 1 1 1
    Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
    Part No: 1K0 907 379 K
    Component: ESP FRONT MK60 0104
    Coding: 0006786
    VCID: 3A7BD46A75FF94CE9A7-806F
    Address 08: Auto HVAC Labels: 1K0-907-044.lbl
    Part No: 1Z0 907 044 J
    Component: ClimatronicPQ35 084 0304
    Shop #: WSC 00000 000 00000
    VCID: 3D71DF7664D1A3F6BF5-8068
    2 Faults Found:
    00710 - Defroster Flap Positioning Motor (V107)
    000 - - - Intermittent
    00229 - Refrigerant Pressure
    002 - Lower Limit Exceeded - Intermittent
    Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
    Part No SW: 1K0 937 049 N HW: 1K0 937 049 N*
    Component: Bordnetz-SG H34 0803
    Revision: 00H34000 Serial number: 00000001457967
    Coding: 4D8A8F120004140000110D000000000000087F065C
    Subsystem 1 - Part No: 1Z1 955 119 A Labels: 1KX-955-119.CLB
    Component: Wischer SK351 012 0401
    Coding: 00065525
    Shop #: WSC 73430
    Subsystem 2 - Part No: 1K0 955 559 M Labels: 1K0-955-559-AF.CLB
    Component: RegenLichtSens 005 0605
    Coding: 00217125
    Shop #: WSC 73430
    1 Fault Found:
    00061 - Footwell Lights
    012 - Electrical Fault in Circuit
    Address 15: Airbags Labels: 1K0-909-605.lbl
    Part No SW: 1K0 909 605 H HW: 1K0 909 605 H
    Component: 08 AIRBAG VW8 023 0700
    Revision: 06023000 Serial number: 00385D0N7VEI
    Coding: 0012344
    VCID: 3169F346A88957962BD-8064
    Subsystem 1 - Serial number: 6332MSME2B0B3608
    Subsystem 2 - Serial number: 6342MSME221C0C08
    Subsystem 3 - Serial number: 6351HSME4B4E1806
    Subsystem 4 - Serial number: 6361HSME22110C06
    Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
    Part No SW: 1K0 953 549 F HW: 1K0 953 549 F
    Component: Lenksäulenmodul 021 0050
    Coding: 0000042
    VCID: 3561C7565CE17BB6775-8060
    Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
    Part No: 1Z0 920 841 D
    Component: KOMBIINSTRUMENT VD1 0914
    Coding: 0007101
    Shop #: WSC 00011 888 96745
    VCID: 377DCD5E46ED89A6659-8062
    Address 19: CAN Gateway Labels: 1K0-907-530-V1.clb
    Part No SW: 1K0 907 530 E HW: 1K0 907 951
    Component: Gateway H09 0110
    Revision: 09 Serial number: 270010510601FC
    Coding: 7DBF4348071302
    Shop #: WSC 00012 000 00000
    VCID: 29591B2680592F56E3D-807C
    3 Faults Found:
    01325 - Control Module for Tire Pressure Monitoring (J502)
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 2
    Fault Frequency: 254
    Reset counter: 158
    Mileage: 160551 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 14:51:48
    01330 - Central Control Module for Central Convenience (J393)
    004 - No Signal/Communication - Intermittent
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 2
    Fault Frequency: 3
    Reset counter: 194
    Mileage: 166590 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 17:16:39
    01044 - Control Module Incorrectly Coded
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 1
    Fault Frequency: 7
    Reset counter: 158
    Mileage: 166663 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 13:38:29
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
    Component: IMMO VD1 0914
    Address 37: Navigation Labels: 1T0-919-887.lbl
    Part No: 1Z0 919 887
    Component: Navigation 0309
    Coding: 0000002
    VCID: 050177964C812B36A75-8050
    Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN1.lbl
    Part No: 1T0 959 701
    Component: Tuersteuergeraet 09 0165
    Coding: 0000118
    VCID: F4E7BA52971BA2BE00B-80A1
    2 Faults Found:
    00932 - Electric Window Motor; Drivers Side (V147)
    005 - No or Incorrect Basic Setting / Adaptation - Intermittent
    Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
    Part No: 1K1 909 144 H
    Component: EPS_ZFLS Kl.2 1502
    VCID: 306FF642A3835E9E243-8065
    Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb
    Part No: 1K0 959 433 BL
    Component: 01 KSG 0301
    Coding: 00F802007F2D8505084F010004
    VCID: 7BF5116E3A456DC6C11-802E
    Subsystem 1 - Component: Sounder n.mounted
    Subsystem 2 - Component: NGS n.mounted
    Subsystem 3 - Component: IRUE n.mounted
    Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN1.lbl
    Part No: 1T0 959 702
    Coding: 0000118
    VCID: F5E187569C61BBB6375-80A0
    Address 55: Xenon Range Labels: 1T0-907-357.lbl
    Part No: 1T0 907 357
    Component: Dynamische LWR 0002
    Coding: 0000007
    Address 56: Radio Labels: 1T0-035-095.lbl
    Part No: 1T0 035 095
    Component: Radio 0309
    Coding: 0000445
    VCID: EBD5A12ECA257D46D11-80BE
    1 Fault Found:
    00858 - Connection; Radio Intermediate Frequency (IF) Output to Antenna Amplifier
    011 - Open Circuit
    Address 62: Door, Rear Left Labels: 1K0-959-703-GEN1.lbl
    Part No: 1K0 959 703 B
    Component: Tuersteuergeraet 06 0219
    Coding: 0000048
    VCID: 2F6DF53EBEBD41663D9-807A
    1 Fault Found:
    Address 65: Tire Pressure
    Cannot be reached
    Address 69: Trailer Labels: 8P0-907-383.lbl
    Part No SW: 8P0 907 383 HW: 8P0 907 383
    Component: ANHAENGERELEKTR H01 0010
    Coding: 0000001
    VCID: F6E3805A8167B0AE3EF-80A3
    1 Fault Found:
    00526 - Brake Light Switch-F
    008 - Implausible Signal - Intermittent
    Freeze Frame:
    Fault Status: 00101000
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 184
    Mileage: 166308 km
    Time Indication: 0
    Date: 2001.09.15
    Time: 11:45:00
    Address 72: Door, Rear Right Labels: 1K0-959-704-GEN1.lbl
    Part No: 1K0 959 704 B
    Coding: 0000048
    1 Fault Found:
    Address 76: Park Assist Labels: 1Z0-919-283.lbl
    Part No SW: 1Z0 919 283 C HW: 1Z0 919 283 C
    Component: Parkhilfe 8-Kan H04 0020
    Coding: 0000001
    VCID: 3E73D87A69D7B8EEA6F-806B
    1 Fault Found:
    01548 - Sensor for Parking Aid; Rear Right (G206)
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 158
    Mileage: 166727 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 10:15:24
    End ---------------------------------------------------------------------
    są błędy parktronika i 2 świec żarowych a reszta ???
      • 15997
      piotrgm,
      z a4club.pl: 00710 - "To błąd silnika regulacyjnego pokrywy przestrzeni na nogi i odmrażania przedniej szyby. Inaczej pisząc klapa, która steruje strumieniem powietrza w górę (na szybę), lub w dół (na nogi). Jak będzie owa klapa się zacinać (np. przez zabrudzenie), to też w ów czas taki błąd Ci wywali. Szukaj w środku od strony pasażera tejże klapy (w konsoli oczywiście). "
      kolejne błędy klimy: http://forum.octaviaclub.pl/viewtopic.php?t=68038
      012 - Electrical Fault in Circuit - oświetlenie przestrzeni na nogi, przerwa w obwodzie
      01325 - Control Module for Tire Pressure Monitoring (J502) - czujnik monitorowania ciśnienia w oponach - brak sygnału opis
      004 - No Signal/Communication - Intermittent - moduł komfortu, więcej
      01044 - Control Module Incorrectly Coded - błędne kodowanie forum passata
      005 - No or Incorrect Basic Setting / Adaptation - Intermittent - sterowanie elektryczne szyb; strona kierowcy http://leonclub.pl/forum/viewtopic.php?f=42&t=31959
      00858 - Connection; Radio Intermediate Frequency (IF) Output to Antenna Amplifier - wzmacniacz anteny radiowej, obwód otwarty, więcej
      00526 - Brake Light Switch-F - włącznik świateł hamowania http://www.vw-sharan.pl/forum/showthread.php?tid=3009 http://www.a6klub.pl/viewtopic.php?t=9877
      01548 - Sensor for Parking Aid; Rear Right (G206) - czujnik parkowania tył prawy - brak sygnału http://forum.skodaclub.pl/roomster/c...nie-t6544.html
