Zamieszczone przez McGan
Skoro masz gumowaty pedał to wina źle odpowietrzonych hamulców
VAG-COM Version: Release 311.2-N
Chassis Type: 1U - Skoda Octavia
Scan: 01,02,03,08,15,17,19,35,46,56
Address 01 -------------------------------------------------------
Controller: 06A 906 018 FH
Component: 2.0l R4/2V MOTR HS V03
Coding: 00011
Shop #: WSC 00026
2 Faults Found:
16806 - Main Catalyst: Bank 1: Efficiency Below Threshold
P0422 - 35-00 - -
16518 - Oxygen (Lambda) Sensor B1 S1: No Activity
P0134 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 03 -------------------------------------------------------
Controller: 1J0 907 379 Q
Component: ABS/EDS 20 IE CAN 0001
Coding: 13504
Shop #: WSC 35110
No fault code found.
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 1U1 919 034 B
Component: A4-KOMBIINSTR. VDO V01
Coding: 02142
Shop #: WSC 35110
IMMO-IDENTNR: SKZ7Z0Y0503050
Address 46 -------------------------------------------------------
Controller: 1J0 959 799 Q
Component: 5M Zentral-SG Komf. 0001
Coding: 04097
Shop #: WSC 35110
11 Faults Found:
00849 - S-contact at Ignition/Starter Switch (D)
25-00 - Unknown Switch Condition
00950 - Central Locking Motor - tailgate (V53): UNLOCK
01329 - Convenience System Data Bus in Emergency Mode
35-00 - -
01334 - Door Control Module: Rear Right (J398)
49-10 - No Communications - Intermittent
01333 - Door Control Module: Rear Left (J388)
01332 - Door Control Module: Passenger Side (J387)
01331 - Door Control Module: Driver Side (J386)
00931 - Locking Module for Central Locking: Rear Right (F223)
54-10 - Incorrectly Equipped - Intermittent
00929 - Locking Module for Central Locking: Front Passenger Side (F221)
00928 - Locking Module for Central Locking: Front Driver Side (F220)
49-00 - No Communications
End -------------------------------------------------------
16806 Główny katalizator poniżej progu wydajności strona 1 brak osprzętu / nie związany ze sprzętem 16518 Sonda lambda brak zmian napięcia (strona 1 czujnik 1) brak osprzętu / nie związany ze sprzętem - BŁĄD SPORADYCZNY 849 Styk S stacyjki rozrusznik/zapłon -D- nieznane ustawienie przełączników 950 Siłownik zamka centralnego bagażnika odblokowanie nieznane ustawienie przełączników 1329 Magistrala danych funkcji komfort w trybie awaryjnym brak osprzętu / nie związany ze sprzętem 1334 Moduł sterujący drzwi prawy tył-J389 magistrala CAN brak sygnału - BŁĄD SPORADYCZNY 1333 Moduł sterujący drzwi lewy tył-J388 magistrala CAN brak sygnału - BŁĄD SPORADYCZNY 1332 Moduł sterujący drzwi pasażera-J387 magistrala CAN brak sygnału - BŁĄD SPORADYCZNY 1331 Moduł sterujący drzwi kierowcy-J386 magistrala CAN brak sygnału - BŁĄD SPORADYCZNY 931 Siłownik zamka centralnego prawy tył-F223 nie autoryzowane - BŁĄD SPORADYCZNY 929 Siłownik zamka centralnego prawy przód-F221 nie autoryzowane - BŁĄD SPORADYCZNY 928 Siłownik zamka centralnego lewy przód-F220 nie autoryzowane - BŁĄD SPORADYCZNY 1333 Moduł sterujący drzwi lewy tył-J388 magistrala CAN brak sygnału
849 Styk S stacyjki rozrusznik/zapłon -D- nieznane ustawienie przełączników 1329 Magistrala danych funkcji komfort w trybie awaryjnym brak osprzętu / nie związany ze sprzętem 1333 Moduł sterujący drzwi lewy tył-J388 magistrala CAN brak sygnału
