Jak to z ksenonami (xenonami) w EU jest ...
  • Mareczek
    • 25
    a więc tak:
    po wymianie termostatu wszystko się ustabilizowało, temperatura podczas jazdy zblizona do tej na postoju czyli tamten termostat albo puszczał albo za wcześnie otwierał.
    teraz temperatura oscyluje między 96-101 stopni na postoju i 98-99 stopni podczas jazdy i czy to czasem nie za duzo trochę,wentylator zalącza na 100.5-101 stopni.
    tak czy inaczej hubert zalegasz dwa browary.
  • Hanz2k
    • 522
    Tekst jest po angielsku z:
    We work with our agencies and partners to support the transport network that helps the UK’s businesses and gets people and goods travelling around the country. We plan and invest in transport infrastructure to keep the UK on the move. DfT is a ministerial department, supported by 23 agencies and public bodies .
    więc regulacje RVLR nas nie dotyczą. Ale ECE98 i ECE48 jak najbardziej.
    Fact sheet: Aftermarket HID headlamps
    December 2006
    In the Department's view it is not legal to sell or use after market HID lighting kits, for converting conventional Halogen headlamps to HID Xenon. If a customer wants to convert his vehicle to Xenon HID he must purchase completely new Xenon HID headlamps. The reason for this is that the existing lens and reflector are designed around a Halogen filament bulb, working to very precise tolerances. If one places a HID "burner" (bulb) in the headlamp, the beam pattern will not be correct, there will be glare in some places and not enough light in other places within the beam pattern.
    The following is the legal rationale:
    The Road Vehicle Lighting Regulations 1989 regulate the situation in the UK.
    Under these Regulations, HID/Gas Discharge/Xenon headlamps are not mentioned and therefore they are not permitted according to the strict letter of the law.
    However new vehicles have HID headlamps. This is because they comply to European type approval Regulations. The UK cannot refuse to register a vehicle with a European type approval. These are to ECE Regulation 98 (for the HID headlamps which are tested on a rig in a laboratory) and ECE Regulation 48 (Lighting Installation on the vehicle).
    For the after market, a used vehicle cannot obtain type approval because it is only applicable for new vehicles. However we feel that saying "HID is banned in the after market" would not be reasonable. Instead we should make analogies with new vehicles. It would be reasonable to require HID in the after market to meet the same safety standards as on new vehicles. The same level of safety should apply.
    Therefore a HID headlamp unit sold in the after market should:
    1. be type approved to ECE Regulation 98 as a component.
    2. when fitted to the vehicle should enable ECE Regulation 48 to be complied with (although no government inspection will take place).
    3. Comply with RVLR as far as "use" is concerned.
    In practice this means:
    1. The headlamp unit (outer lens, reflector, bulb) shall be type approved to ECE 98 and be "e-marked" to demonstrate this. That can only be done by the headlamp supplier - Hella, Valeo etc. who must test the headlamp in an independent laboratory.
    2. Once fitted to the vehicle it must have headlamp cleaning and self-levelling (which can be for the headlamp or can be in the vehicle suspension - some expensive estate cars have "self-levelling suspension" and that is adequate). Also the dipped beam must stay on with the main beam.
    3. The headlamp must be maintained in good working order, kept clean, and aligned/adjusted correctly like any other headlamp.
    Under the Road Traffic Act 1988 it is an offence to supply, fit or use vehicle parts which are not legal.
    In summary it is not permitted to convert an existing halogen headlamp unit for use with HID bulbs. The entire headlamp unit must be replaced with one designed and approved for use with HID bulbs and it must be installed in accordance with the rules stated above.
    Hanz2k
    1,8 T by MT
    :admin: bo nie użyłem Szukaj
    • mariobros
      • 551
      O ile kiedyś szperałem, jest identycznie. W skrócie, nie można przerabiać reflektorów z żarówkami halogenowymi w ten sposób, że wkłada się do nich palniki w miejsce żarówek, choćby te palniki były opisane jako do tego urodzone. Reflektor otrzymuje homologację dla określonego typu źródła światła, innego w zamian stosować nie można. Można jednak kupić całą lampę przystosowaną do palników (od Helli czy innych producentów) i wstawić w miejsce "tradycyjnej", o ile dla tej nowej lampy producenci wystarali się o stosowne dopuszczenia. Dodatkowo trzeba dorobić samopoziomowanie oraz spryskiwacze reflektorów, bo to są elementy wymagane przepisami przy ksenonach (jak wiadomo, ksenon ). Jest to sprawa ogólnie znana 8)
      Skoda Octavia Kombi II 2005r. 1.9TDI 77kW Elegance czerń magiczna - sprzedana...
      Renault Scenic III 1.4TCe 2010 - jest...
      • Hanz2k
        • 522
        Mariobros - jesteśmy w EU a to oznacza, że obowiązują u nas regulacje: ECE Regulation 98 i ECE Regulation 48 i to co z nich wynika.
        Hanz2k
        1,8 T by MT
