Chyba coś nie tak kliknąłem :|
Address 01
Protocol: KW1281
Controller: 06A 906 018 FK
Component: 2.0l R4/2V MOTR HS V05
Coding: 00031
Shop #: WSC 31480
Address 03
Protocol: KWP2000
Controller: 1C0 907 379 L
Component: ABS FRONT MK60 0101
Coding: 0004097
Shop #: WSC 31480
Skipping Address 15-Airbags
Address 17
Protocol: KW1281
Controller: 1U0 920 811 B
Component: KOMBI+WEGFAHRSP VDO V07
Coding: 18102
Shop #: WSC 31480
Address 19
Protocol: KW1281
Controller: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 31480
Address 25
Protocol: KW1281
Controller: Bitte Adress
Component: e 17 eingeben
Address 33
Protocol: ????
Controller: OBD-II/EOBD, KeyWord:0808
Address 3F
Protocol: KW1281
Controller:
Address 46
Protocol: KW1281
Controller: 1C0 959 799
Component: 3P Komfortgerát HLO 0002
Coding: 00259
Shop #: WSC 31480
Protocol: KW1281
Coding: 00031
Shop #: WSC 31480
Address 03
Protocol: KWP2000
Coding: 0004097
Shop #: WSC 31480
Address 17
Protocol: KW1281
Coding: 18102
Shop #: WSC 31480
Address 19
Protocol: KW1281
Coding: 00006
Shop #: WSC 31480
Address 25
Protocol: KW1281
Address 33
Protocol: ????
Address 3F
Protocol: KW1281
Controller:
Address 46
Protocol: KW1281
Coding: 00259
Shop #: WSC 31480
VAG-COM Version: Release 311.2-N
Chassis Type: 1U - Skoda Octavia
Scan: 01,02,03,08,15,17,19,35,46,56
Address 01 -------------------------------------------------------
Coding: 00031
Shop #: WSC 31480
No fault code found.
Address 03 -------------------------------------------------------
Coding: 0004097
Shop #: WSC 31480
Address 17 -------------------------------------------------------
Coding: 18102
Shop #: WSC 31480
TMBCE41U532741213 SKZ7Z0B1675273
Address 19 -------------------------------------------------------
Coding: 00006
Shop #: WSC 31480
Address 46 -------------------------------------------------------
Coding: 00259
Shop #: WSC 31480
5 Faults Found:
01330 - Central Control Module for Central Convenience (J393)
53-10 - Supply Voltage Too Low - Intermittent
01331 - Door Control Module: Driver Side (J386)
01332 - Door Control Module: Passenger Side (J387)
01333 - Door Control Module: Rear Left (J388)
01334 - Door Control Module: Rear Right (J398)
End -------------------------------------------------------
Coding: 00031
Shop #: WSC 31480
Coding: 0004097
Shop #: WSC 31480
Coding: 18102
Shop #: WSC 31480
Coding: 00006
Shop #: WSC 31480
Coding: 00259
Shop #: WSC 31480
5 Faults Found:
