Aktualizacja softu przekładni 3 generacji 1K0909144...
  • spacewalker
    • 965
    #26
    need to sleep a little with that issue
    • 1 6 D
      • 547
      Only TPI on this moment have number 2026486/3
      And some text from it:
      Chassis: insufficient efficiency power steering fault indicator / warning on power steering Date of resolution of publication: 28.12.2012
      This update affects only cars with left-hand drive!
      Fault description clients:
      • Red light on the power steering malfunction in the instrument cluster.
      Newest version of software in Steering is 1101, my TPI base is not the newest so there could be actualisation to software 1401.
      Table from this TPI:
      old______________new______________Calendar Week
      5N1.909.144.J 0502 5N1.909.144.J 1101 45/2011
      5N1.909.144.J 0503 5N1.909.144.J 1101 45/2011
      5N1.909.144.K 0703 5N1.909.144.K 1101 45/2011
      5N1.909.144.L 0802 5N1.909.144.L 1101 45/2011
      5N1.909.144.L 1002 5N1.909.144.L 1101 45/2011
      5N1.909.144.M 1002 5N1.909.144.M 1101 45/2011
      Probably SVM code is 35FA
      File appear in 064 flash DVD for VW
      Before flashing check if U have offline option in VAS to flash curve characteristic.
      I found scan with 5N1 P/R versions:
      Address 44: Steering Assist Labels: 5N1-909-144.clb
      Part No SW: 5N1 909 144 P HW: 5N1 909 148 J
      Component: J500__APA-BS KL.302 1202
      Part No SW: 5N1 909 144 R HW: 5N1 909 148 J
      Component: J500__APA-BS KL.374 1401
      There is other HW number so it could be not safe to flash from unit with HW 5N1 909 148 G
      BTW, tomorrow I will test edited script with this list od characteristics:
      Curve \L\S\K\A69\L\S\K\N ... Scirocco TDI. >>>>>my factory setting
      Curve \L\S\K\A234\L\S\K\N ... Audi S3.
      Curve \L\S\K\A239\L\S\K\N ... Audi TTRS.
      Curve \L\S\K\A243\L\S\K\N ... Audi RS3.
      Curve \L\S\K\A251\L\S\K\N ... VW R-version.
      Curve \L\S\K\A74\L\S\K\N ... Octavia II RS.
      http://chomikuj.pl/lusob/VCDS
      • nightrider
        • 21
        #28
        Zamieszczone przez 1 6 D
        I use this database to find part # and software #.
        16D, still can't understand why u don't want to use odis E :roll:
        Skoda Octavia A5 FL 2011 7-DSG 1.8tsi (cdab)
        VAS5054a, VCDS, VCP
        • 1 6 D
          • 547
          My VAS5054a head doesn't have chips for UDS and it doesn't works with ODIS, maybe in few days I will buy them and solder.
          • spacewalker
            • 965
            #30
            16D do you have any UDS controler which you can diagnose via VAS ?
            ODIS also can diagnose older controlers, so there is no problem with missing chip fopr UDS.
            Dont listen china seller
            Most problem is with a right sw install and proper JAVA
            • 1 6 D
              • 547
              I tried run VAS on VW Sharan 2011 with UDS, it doesn't want to connect with ECU, Air condition, it can connect other nonUDS modules.
              I have installed ODIS-E but when I select VW36x project it loads but nothing more, only some fault. It was on my nonUDS Scirocco.
              • nightrider
                • 21
                #32
                The lack of UDS in vas5054a my not be the reason of this error.
                A couple of persons had this error, too. But somehow they fixed it.
                Try to reinstall odis with proper java version (Программы › VAS PC › Java)
                I used this installer and everything works fine.
                VAS5054a, VCDS, VCP
                • spacewalker
                  • 965
                  #33
                  True.
                  • 1 6 D
                    • 547
                    One of this?
                    Java_SDK_v.1.4.2.15_for_Win-x32.exe
                    Java_SE_Development_Kit_7u2-win-x86.exe
                    • nightrider
                      • 21
                      #35
                      One of this?
                      This version also works fine (I have it on VMWare with WinXP).
                      And u must install both of them.
                      VAS5054a, VCDS, VCP
                      • 1 6 D
                        • 547
                        Hi, I have edited this two files about adapting but I have error during it, I haven't made print screen so I have to do it again. After last screen there appear error, if U choose one position from list.
                        • nightrider
                          • 21
                          #37
                          Can u remember what was the point of this error?
                          VAS5054a, VCDS, VCP
                          • 1 6 D
                            • 547
                            There was some numbers, I will connect second time with this edited script, maybe something more should be changed in more files.
                            I made small research and file name "v074N0741K0___Lenkung_Reibung" was used in few nore files in skoda_31 folder, for example "SYS48_60____1_1110_31_Anpassung_J500.tst", it's in t8/testprog and t12/testprog folders.
                            • nightrider
                              • 21
                              #39
                              Also I see some entangled buttons in last screenshot, eg. curve 234 stands for button -1-.
                              VAS5054a, VCDS, VCP
                              • 1 6 D
                                • 547
                                Every option I choose, there is the same error, I haven't changed Octavia 2 RS and there was error too. This 234 and -1- I haven't changed in script files.
                                • nightrider
                                  • 21
                                  #41
                                  This two files for other vehicles, so contain only another curves for choosing. May be there are other differences, but they both and files above have the same script algorithm of flashing curve.
                                  t4 — Fabia 1999;
                                  t5 — Fabia 2007;
                                  t6 — Octavia 1997;
                                  t7 — Octavia 2004;
                                  t8 — Roomster 2006;
                                  t9 — Rapid 2012;
                                  t10 — Superb 2001;
                                  t11 — Superb 2008;
                                  t12 — Yeti 2012.
                                  VAS5054a, VCDS, VCP
                                  • 1 6 D
                                    • 547
                                    Have U tried to edit this script for Octavia? This is my edition of this two files, I have corrected issue with -1- button:
                                    SendSpace lets you transfer large files quickly and securely for free. Enjoy hassle-free file sharing today.
                                    • nightrider
                                      • 21
                                      #43
                                      https://www.sendspace.com/file/g0q5xm
                                      It is worthiness to wait until u'll get screenshot with the error...
                                      VAS5054a, VCDS, VCP
                                      • spacewalker
                                        • 965
                                        #44
                                        Zamieszczone przez nightrider
                                        t4 — Fabia 1999;
                                        t6 — Octavia 1997;
                                        U sure about these 2 ?
                                        • nightrider
                                          • 21
                                          #45
                                          Zamieszczone przez spacewalker
                                          t4 — Fabia 1999;
                                          t6 — Octavia 1997;
                                          No... Repost from bit.ly/105ubJX
                                          P.S.
                                          From TPI:
                                          Octavia II C:/SIDIS/home/dat.cze/skoda_31/docs/t7/testprog
                                          Superb II C:/SIDIS/home/dat.cze/skoda_31/docs/t10/testprog
                                          Yeti C:/SIDIS/home/dat.cze/skoda_31/docs/t11/testprog
                                          Seems some are incorrect. Will check them today.
                                          VAS5054a, VCDS, VCP
                                          • 1 6 D
                                            • 547
                                            In t7 I have seen files for these car codes in names of files:
                                            1Z
                                            3T
                                            5J
                                            5K
                                            5L
                                            17
                                            1F
                                            3C
                                            1K
                                            1T
                                            • nightrider
                                              • 21
                                              #47
                                              1Z
                                              3T
                                              5J
                                              5K
                                              5L
                                              17
                                              1F
                                              3C
                                              1K
                                              1T
                                              This isn't vehicle code, this is code of module's controller (3rd column in vcds database (link above)).
                                              VAS5054a, VCDS, VCP
                                              • 1 6 D
                                                • 547
                                                Here is fault with edited script:
                                                BTW U can go to Guided Functions as Superb or Yeti and there is offline programing too, Superb have different curves to choose, not sure what is in Yeti.
                                                • nightrider
                                                  • 21
                                                  #49
                                                  Can u use the original script and flash stock 74 octavia rs curve?
                                                  VAS5054a, VCDS, VCP
                                                  • 1 6 D
                                                    • 547
                                                    When I change files to original, it works and flash characteristic normally for example to kl.69.
                                                    I will try to edit this script with smaller steps and check if it works, firstly modify recognition, then change 1 characteristic from original list.
