Aktualizacja softu przekładni 3 generacji 1K0909144...
  • nightrider
    • 21
    #51
    Zamieszczone przez 1 6 D
    When I change files to original, it works and flash characteristic normally for example to kl.69.
    I will try to edit this script with smaller steps and check if it works, firstly modify recognition, then change 1 characteristic from original list.
    Try this modded script https://yadi.sk/d/0k6eE0vycYu2C
    Skoda Octavia A5 FL 2011 7-DSG 1.8tsi (cdab)
    VAS5054a, VCDS, VCP
    • 1 6 D
      • 547
      I tested it, it shows message about starting to flash but nothing is made and VAS shows that process was OK and curve haven't been changed, without faults.
      http://chomikuj.pl/lusob/VCDS
      • nightrider
        • 21
        #53
        Did u check the curve number after flashing?
        Do u receive this message
        The characteristic curves were not transferred.
        Do y0u want to repeat the update programming?
        VAS5054a, VCDS, VCP
        • 1 6 D
          • 547
          Curve wasn't changed, I haven't this message.
          • nightrider
            • 21
            #55
            Ok will check that. If it is possible, can u take the screenshot of each step while doing the adaptation (from curve selection step). It will help a lot.
            VAS5054a, VCDS, VCP
            • 1 6 D
              • 547
              Here is y0ur script:
              Curve wasn't changed, after this script I have turned off ignition for a moment to check what curve is now.
              By original script after flashing there was about 3 faults in car about communication with Steering and G85.
              • LUKI
                • 5776
                #57
                1 6 D, I have a question
                in my o2fl I have 144 J 3001 so that I should do an update to 144R 3501?
                I ask because ASO says that this applies only to a selected group...
                • 1 6 D
                  • 547
                  They make update when there are problems with steering, like fault 16344, 16353, 16355 from first post of this thread. I haven't faults but sometimes steering haven't worked for some seconds after engine start.
                  • LUKI
                    • 5776
                    #59
                    1 6 D, so when I haven't any fault/problem, I don't have to do that?
                    • spacewalker
                      • 965
                      #60
                      Zamieszczone przez LUKI
                      this same is with RNS 510 for example . If working , don't touch , however VW relisted SW with some reason .
                      I prefere keep up to the date SW , but if work .... let it work
                        I've updated my Superb 44 module, for testing - reflashed to Octavia RS. Everything went fine, but the result didn't satisfy to me - all the times the force needed for move the steering wheel was too high. I didn't feel the response of the steering system is better than standard, so I came back to the stock.
                        [ Dodano: Nie 21 Gru, 14 12:15 ]
                        znalazłem ciekawe materiały dodatkowe do tematu:
                        • szczetke
                          #62
                          maglownica
                          witam kolegów
                          wymieniłem w moim passat b6 maglownice na 3 generacji
                          Oznaczenie elementu: 1K0 909 144 M
                          Komponent: EPS_ZFLS Kl. 74 3201
                          Weryfikacja: 00H20000
                          Kod serwisu: WSC 01357 011 00200
                          VCID: 346C8F402EAA
                          błędów nie ma ale siła wspomagania jest mała czy wystarczy ze wgram odpowiednia charakterystykę np v074N2131k0.sgo czy sgo. od audi tt podejdzie ?
                          czy muszę zmienić firmware w maglownicy
                          [ Dodano: Wto 17 Lut, 15 09:32 ]
                          witam
                          uało sie wgrać fw do maglownicy mam teraz
                          System description
                          EPS_ZFLS BB
                          EPS_ZFLS Kl. 000
                          Software version
                          3305
                          3501
                          Hardware version
                          H20
                          VW/Audi part number
                          1K0909144ZA
                          1K0909144R
                          ale nie moge wgrac charakterystyki mam 000 używam odis-E co robie zle
                          oto pliki które wgrywałem
                          1. - lh0023305.sgo
                          2. - Lh0013501.sgo
                          3 - v074N***1k0.sgo
                          [ Dodano: Wto 17 Lut, 15 10:31 ]
                          temat załatwiony trzeba wyłączyć weryfikacje w odis
                          • czernobyl
                            • 1276
                            ogrzewam / odśnieżam:
                            ma ktoś wprawę we wgrywaniu charakterystyk do przekładni drugiej generacji (1K1 909 144 *) przy użyciu Vag Can Pro? zarówno mi jak i innemu userowi procedura po przyjęciu pliku i rozpocząceiu programowania przy użyciu funkcji Flasher kończy się komunikatem: "Błąd funkcji Reqdownload: 11 Funkcja nie wspierana", licznik flashowań udanych / nieudanych nie zmienia się. Co robimy źle? Coś trzeba gdzieś uprzednio przestawić w programie, by móc wgrać charakterystykę? Może posiada ktoś jaką porządną instrukcję do programu (ta oficjalna nic nie objaśnia)
                            Co ciekawe, raz udało mi się wgrać charakterystykę od RS bez żadnego problemu - flashowanie zakończone sukcesem, kierownica reaguje "sztywniej", licznik flashowań 1/1, ale to jednorazowy przypadek. Jest niby w One Click Function operacja zmiany charakterystyki dla PQ35, ALE od razu napisane, że dla FW>3300 (czyli tylko 3. gen) oraz pliki są gdzieś podbierane z neta, nie można tam podłożyć swojego pliku .sgo z dysku lokalnego.
                            • majuDJ
                              • 464
                              #64
                              Czy wie ktoś gdzie i jak zrobić aktualizację softu maglownicy? Maglownica II generacji
                              Adres 44: Wsp.kierownicy Plik etykiet: 1Kx-909-144-G2V2.clb
                              Oznaczenie elementu: 1K1 909 144 J
                              Komponent: EPS_ZFLS Kl.5 D04 1606
                              Kod serwisu: WSC 00000 000 00000
                              VCID: 326A2254AD2F60D12F-8066
                              Znaleziono 1 błąd:
                              00573 - Czujnik momentu obrotowego kierownicy (G269)
                              008 - Niezrozumiały sygnał
                              http://www.euromove.pl
                              • patryk23
                                • 1105
                                majuDJ w twoim przypadku przed zmianą softu spróbowałbym fizycznego zaaplikowania contakt sprayu pod pokrywę czujnika . Przerabiałem to ( ten sam błąd) bo u mnie czujnik wariował w pewnym zakresie tylko podczas skrętu w prawo .
                                • majuDJ
                                  • 464
                                  #66
                                  Przy teście czujnika G269 bloki pomiarowe się zmienią w lewo i prawo. Skasuje błąd VCDSem i jest spokój na kilkanaście do 300km. Żółta kontrolka potrafi sama wyskoczyć w czasie jazdy na prostej drodze. Wszyscy mi mówią bym wymieniał magiel
                                  patryk23 Czy aby dostać się pod pokrywę czujnika konieczny jest demontaż + montaż całej maglownicy + później geometria? Czy można się dostać tam bez demontażu? Jak odkręcić tą pokrywę czujnika, jakim kluczem? U Ciebie spray "KONTAK" pomógł i zero problemów?
                                  • patryk23
                                    • 1105
                                    Odpisałem PW by nie robić smietnika w temacie
                                    • mcaris
                                      • 425
                                      Witam. nie chcę zakładać nowego tematu a ten jest jak najbardziej pod moje pytanie. Czy duzo roboty jest z wymiana maglownicy? Chce wymienić "magiel" na 3 gen ( obecnie 2 gen 1k1) czy od skody O II FL podejdzie P&P bez przekładania kabli?
                                      ByŁ Leonsio 1.8T 200 km. Jest Szkodnik 140km
