Dla warszawiaków
  • micnur
    • 109
    Dla warszawiaków
    Przy okazji instalacji Columbusa ( z drugiej reki ) stwierdzilem bledy w VAG-COMie. Te z Radia i Nawigacji martwia mnie mniej niz ten z Silnika i z CAN Gateway'a, czy moze mi ktos podsunac jakas idee o co tu dokladnie chodzi. Jesli jeszcze dowiem sie czegos wiecej o pozostalych bledach to bedzie MEGA Super! Oto co daje mi VAG-COM:
    Sunday,29,January,2012,11:17:14:06255
    VCDS Version: Release 11.11.1
    Data version: 20111209
    Chassis Type: 7N0
    Scan: 01 02 03 08 09 10 15 16 17 19 25 37 42 44 46 52 56 62 72
    VIN: TMBBE61Z8B8010XXX
    01-Engine -- Status: Malfunction 0010
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    10-Park/Steer Assist -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: Malfunction 0010
    25-Immobilizer -- Status: OK 0000
    37-Navigation -- Status: Malfunction 0010
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    56-Radio -- Status: Malfunction 0010
    62-Door, Rear Left -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    Address 01: Engine (J623-CFHC) Labels: 03L-906-018-CFF.clb
    Part No SW: 03L 906 018 CT HW: 03L 906 018 BR
    Component: R4 2,0L EDC H21 7101
    Revision: 42H21--- Serial number:
    Coding: 001D0012042400080000
    Shop #: WSC 73430 031 00000
    ASAM Dataset: EV_ECM20TDI01103L906018CT 003004
    ROD: EV_ECM20TDI01103L906018CT.rod
    VCID: 7EDD2F96E1EC554
    2 Faults Found:
    4629 - ECM Power Relay Load Circuit: (J271)
    P068A 00 [032] - De-Energized Performance Too Early
    Intermittent - Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 2
    Mileage: 0 km
    Date: 2000.00.00
    Time: 00:00:00
    8169 - Terminal 30
    U140A 00 [032] - Open Circuit
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 0 km
    Date: 2000.00.00
    Time: 00:00:00
    Readiness: 0 0 0 0 0
    Address 02: Auto Trans Labels: 02E-300-0xx.lbl
    Part No SW: 02E 300 052 G HW: 02E 927 770 AL
    Component: GSG DSG AG6 511 2207
    Revision: 05151112 Serial number: 00001006060142
    Coding: 0000020
    Shop #: WSC 73430 790 00000
    VCID: 1811190E2B888B4
    No fault code found.
    Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
    Part No SW: 1K0 907 379 AT HW: 1K0 907 379 AT
    Component: ESP MK60EC1 H30 0105
    Revision: 00H30001
    Coding: 113B401C092300FA881002E890200042350000
    VCID: 8429DD7E0700BF4
    Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
    Part No SW: 3T0 907 044 AR HW: 3T0 907 044 AR
    Component: Climatronic H15 0401
    Revision: 00005001
    Coding: 0000000002
    ASAM Dataset: EV_Climatronic A01006
    ROD: EV_Climatronic_SK35.rod
    VCID: 8225DB661514B14
    Part No SW: 1K0 937 087 J HW: 1K0 937 087 J
    Component: BCM PQ35 H 103 0615
    Revision: 00103 AD
    Coding: 40180AB8E00508C040080080110001E4427000AE526D816064 0440000040
    VCID: 3851F98E8B48AB4
    Subsystem 1 - Part No: 1Z1 955 119 C Labels: 1KX-955-119.CLB
    Component: Wischer 22061 22 0601
    Coding: 00D7B7
    Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
    Component: RLS 180610 05 54 0403
    Coding: 0730ED
    Address 10: Park/Steer Assist (J446) Labels: 1Z0-919-475.clb
    Part No SW: 1Z0 919 475 C HW: 1Z0 919 475 A
    Component: PARKHILFE 8K H06 0006
    Revision: -------- Serial number: 66541015401905
    Coding: 100101
    VCID: 41A7946AD892EAC
    Address 15: Airbags Labels: 1K0-909-605.lbl
    Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
    Component: Q6 AIRBAG VW8 020 2300
    Revision: 05020000 Serial number: 0038PC1YJUJM
    Coding: 0020790
    VCID: 3D5FE89A646A8EC
    Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
    Part No SW: 5K0 953 521 AT HW: 5K0 953 569 B
    Component: LENKS.MODUL 009 0136
    Revision: FF010036 Serial number: 20100624200855
    Coding: 1882140000
    ASAM Dataset: EV_SMLSNGVOLWS A01004
    ROD: EV_SMLSNGVOLWS_SK35.rod
    Multifunction steering wheel control module:
    Subsystem 1 - Part No SW: 3T0 959 537 HW: 3T0 959 537 Labels: 3C8-959-537.CLB
    Component: E221__MFL-URO H07 0012
    Coding: 800000
    Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
    Part No SW: 1Z0 920 843 M HW: 1Z0 920 843 M
    Component: KOMBI H04 0406
    Serial number: 00000000000000
    Coding: 110B01
    ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04089
    ROD: EV_Kombi_UDS_VDD_RM09_SK35.rod
    VCID: 42A59B66D594F14
    Address 19: CAN Gateway Labels: 7N0-907-530-V1.clb
    Part No SW: 7N0 907 530 HW: 1K0 907 951
    Component: J533 Gateway H27 0602
    Revision: H27 Serial number: 240610F2002138
    Coding: EDA07F0640020200001302
    VCID: EDFF98DAF48A5EC
    2 Faults Found:
    01305 - Databus for Infotainment
    004 - No Signal/Communication - Intermittent
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 1
    Fault Frequency: 2
    Reset counter: 232
    Mileage: 30762 km
    Time Indication: 0
    Date: 2017.14.06
    Time: 10:51:45
    01044 - Control Module Incorrectly Coded
    000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 1
    Fault Frequency: 227
    Mileage: 30804 km
    Time Indication: 0
    Date: 2017.14.07
    Time: 10:47:17
    Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
    Part No SW: 5K0 953 234 HW: 5K0 953 234
    Component: IMMO H04 0406
    Coding: 000000
    Shop #: WSC 00000 000 00000
    ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03008
    ROD: EV_Immo_UDS_VDD_RM09_SK35.rod
    VCID: EAF593C60D64494
    Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
    Part No SW: 3T0 035 680 B HW: 3T0 035 680 A
    Component: RNS-MID H05 3974
    Revision: AB001001 Serial number: SKZ6Z7K0420132
    Coding: 00000000000000900000
    Shop #: WSC 33361 790 00999
    ASAM Dataset: ------------------------- ------
    VCID: 2F43C2D27E066CC
    4 Faults Found:
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 5
    Fault Frequency: 206
    Reset counter: 197
    Mileage: 30800 km
    Time Indication: 0
    01523 - Microphone for Telephone (R38)
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 8
    Mileage: 0 km
    Time Indication: 0
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Mileage: 0 km
    Time Indication: 0
    00862 - Antenna for GPS Navigation (R50/R52)
    011 - Open Circuit - Intermittent
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 34
    Reset counter: 237
    Mileage: 0 km
    Time Indication: 0
    Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX3.lbl
    Part No SW: 1T0 959 701 AA HW: 1T0 959 701 AA
    Component: Tuer-SG 009 2119
    Coding: 0004342
    VCID: 76CD37B601DC1D4
    Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
    Part No: 1K0 909 144 J
    Component: EPS_ZFLS Kl. 69 3001
    Revision: 00H17000
    VCID: 3147C4AAA8327AC
    Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
    Part No SW: 1T0 959 702 S HW: 1T0 959 702 S
    Coding: 0004342
    VCID: 48B1894E3BA8DB4
    Address 56: Radio (J0506) Labels: 1T0-035-680.clb
    4 Faults Found:
    000 - -
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 207
    Reset counter: 197
    Mileage: 30800 km
    Time Indication: 0
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 8
    Mileage: 0 km
    Time Indication: 0
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Mileage: 0 km
    Time Indication: 0
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 34
    Reset counter: 237
    Mileage: 0 km
    Time Indication: 0
    Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
    Part No SW: 5K0 959 703 A HW: 5K0 959 703 A
    Component: Tuer-SG 007 2101
    Coding: 0000144
    Shop #: WSC 73430 790 1012544
    VCID: 3245CBA6AD34414
    Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
    Part No SW: 5K0 959 704 A HW: 5K0 959 704 A
    Coding: 0000144
    VCID: 334BCEA2522E48C
    End ---------------------------------------------------------------------
  • loru
    • 4286
    Dla warszawiaków
    http://www.tvnwarszawa.pl/informacje...t-,234814.html
    • Ayu
      • 4154
      Niby wakacje ale i tak korki zostały. Ja to już nawet się nie denerwuję :lol:
      • loru
        • 4286
        Zamieszczone przez hotrain
        od przyszłego tygodnia zelżeje, sezon wyjazdów zaczyna się w ten weekend
        • Mihau
          • 7461
          • CHHA 2.0 TSI RS 230 KM
          http://www.tvnwarszawa.pl/ulice,news...io,250153.html
          no to pozdro
          • Agamek12
            • 9956
            Never ending story... Który to już raz naprawiają...? 4-5?
