Przy okazji instalacji Columbusa ( z drugiej reki ) stwierdzilem bledy w VAG-COMie. Te z Radia i Nawigacji martwia mnie mniej niz ten z Silnika i z CAN Gateway'a, czy moze mi ktos podsunac jakas idee o co tu dokladnie chodzi. Jesli jeszcze dowiem sie czegos wiecej o pozostalych bledach to bedzie MEGA Super! Oto co daje mi VAG-COM:
Sunday,29,January,2012,11:17:14:06255
VCDS Version: Release 11.11.1
Data version: 20111209
Chassis Type: 7N0
Scan: 01 02 03 08 09 10 15 16 17 19 25 37 42 44 46 52 56 62 72
VIN: TMBBE61Z8B8010XXX
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (J623-CFHC) Labels: 03L-906-018-CFF.clb
Part No SW: 03L 906 018 CT HW: 03L 906 018 BR
Component: R4 2,0L EDC H21 7101
Revision: 42H21--- Serial number:
Coding: 001D0012042400080000
Shop #: WSC 73430 031 00000
ASAM Dataset: EV_ECM20TDI01103L906018CT 003004
ROD: EV_ECM20TDI01103L906018CT.rod
VCID: 7EDD2F96E1EC554
2 Faults Found:
4629 - ECM Power Relay Load Circuit: (J271)
P068A 00 [032] - De-Energized Performance Too Early
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 2
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
8169 - Terminal 30
U140A 00 [032] - Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
Readiness: 0 0 0 0 0
Address 02: Auto Trans Labels: 02E-300-0xx.lbl
Part No SW: 02E 300 052 G HW: 02E 927 770 AL
Component: GSG DSG AG6 511 2207
Revision: 05151112 Serial number: 00001006060142
Coding: 0000020
Shop #: WSC 73430 790 00000
VCID: 1811190E2B888B4
No fault code found.
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AT HW: 1K0 907 379 AT
Component: ESP MK60EC1 H30 0105
Revision: 00H30001
Coding: 113B401C092300FA881002E890200042350000
VCID: 8429DD7E0700BF4
Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
Part No SW: 3T0 907 044 AR HW: 3T0 907 044 AR
Component: Climatronic H15 0401
Revision: 00005001
Coding: 0000000002
ASAM Dataset: EV_Climatronic A01006
ROD: EV_Climatronic_SK35.rod
VCID: 8225DB661514B14
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 1K0 937 087 J HW: 1K0 937 087 J
Component: BCM PQ35 H 103 0615
Revision: 00103 AD
Coding: 40180AB8E00508C040080080110001E4427000AE526D816064 0440000040
VCID: 3851F98E8B48AB4
Subsystem 1 - Part No: 1Z1 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer 22061 22 0601
Coding: 00D7B7
Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 180610 05 54 0403
Coding: 0730ED
Address 10: Park/Steer Assist (J446) Labels: 1Z0-919-475.clb
Part No SW: 1Z0 919 475 C HW: 1Z0 919 475 A
Component: PARKHILFE 8K H06 0006
Revision: -------- Serial number: 66541015401905
Coding: 100101
VCID: 41A7946AD892EAC
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
Component: Q6 AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PC1YJUJM
Coding: 0020790
VCID: 3D5FE89A646A8EC
Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
Part No SW: 5K0 953 521 AT HW: 5K0 953 569 B
Component: LENKS.MODUL 009 0136
Revision: FF010036 Serial number: 20100624200855
Coding: 1882140000
ASAM Dataset: EV_SMLSNGVOLWS A01004
ROD: EV_SMLSNGVOLWS_SK35.rod
Multifunction steering wheel control module:
Subsystem 1 - Part No SW: 3T0 959 537 HW: 3T0 959 537 Labels: 3C8-959-537.CLB
Component: E221__MFL-URO H07 0012
Coding: 800000
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 1Z0 920 843 M HW: 1Z0 920 843 M
Component: KOMBI H04 0406
Serial number: 00000000000000
Coding: 110B01
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04089
ROD: EV_Kombi_UDS_VDD_RM09_SK35.rod
VCID: 42A59B66D594F14
Address 19: CAN Gateway Labels: 7N0-907-530-V1.clb
Part No SW: 7N0 907 530 HW: 1K0 907 951
Component: J533 Gateway H27 0602
Revision: H27 Serial number: 240610F2002138
Coding: EDA07F0640020200001302
VCID: EDFF98DAF48A5EC
2 Faults Found:
01305 - Databus for Infotainment
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 1
Fault Frequency: 2
Reset counter: 232
Mileage: 30762 km
Time Indication: 0
Date: 2017.14.06
Time: 10:51:45
01044 - Control Module Incorrectly Coded
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 1
Fault Frequency: 227
Mileage: 30804 km
Time Indication: 0
Date: 2017.14.07
Time: 10:47:17
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H04 0406
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03008
ROD: EV_Immo_UDS_VDD_RM09_SK35.rod
VCID: EAF593C60D64494
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 3T0 035 680 B HW: 3T0 035 680 A
Component: RNS-MID H05 3974
Revision: AB001001 Serial number: SKZ6Z7K0420132
Coding: 00000000000000900000
Shop #: WSC 33361 790 00999
ASAM Dataset: ------------------------- ------
VCID: 2F43C2D27E066CC
4 Faults Found:
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 5
Fault Frequency: 206
Reset counter: 197
Mileage: 30800 km
Time Indication: 0
01523 - Microphone for Telephone (R38)
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 8
Mileage: 0 km
Time Indication: 0
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Mileage: 0 km
Time Indication: 0
00862 - Antenna for GPS Navigation (R50/R52)
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Priority: 5
Fault Frequency: 34
Reset counter: 237
Mileage: 0 km
Time Indication: 0
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX3.lbl
Part No SW: 1T0 959 701 AA HW: 1T0 959 701 AA
Component: Tuer-SG 009 2119
Coding: 0004342
VCID: 76CD37B601DC1D4
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 69 3001
Revision: 00H17000
VCID: 3147C4AAA8327AC
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
Part No SW: 1T0 959 702 S HW: 1T0 959 702 S
Coding: 0004342
VCID: 48B1894E3BA8DB4
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
4 Faults Found:
000 - -
Freeze Frame:
Fault Priority: 5
Fault Frequency: 207
Reset counter: 197
Mileage: 30800 km
Time Indication: 0
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 8
Mileage: 0 km
Time Indication: 0
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Mileage: 0 km
Time Indication: 0
Freeze Frame:
Fault Priority: 5
Fault Frequency: 34
Reset counter: 237
Mileage: 0 km
Time Indication: 0
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 5K0 959 703 A HW: 5K0 959 703 A
Component: Tuer-SG 007 2101
Coding: 0000144
Shop #: WSC 73430 790 1012544
VCID: 3245CBA6AD34414
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 5K0 959 704 A HW: 5K0 959 704 A
Coding: 0000144
VCID: 334BCEA2522E48C
End ---------------------------------------------------------------------
Chassis Type: 7N0
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
8169 - Terminal 30
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
Coding: 0000020
Revision: 00H30001
Revision: 00005001
Coding: 0000000002
Revision: 00103 AD
Coding: 00D7B7
Coding: 0730ED
Coding: 100101
Coding: 0020790
Coding: 1882140000
Coding: 800000
Coding: 110B01
2 Faults Found:
Freeze Frame:
Fault Priority: 1
Fault Frequency: 2
Reset counter: 232
Mileage: 30762 km
Time Indication: 0
Date: 2017.14.06
Time: 10:51:45
Freeze Frame:
Fault Priority: 1
Mileage: 30804 km
Time Indication: 0
Date: 2017.14.07
Time: 10:47:17
Coding: 000000
4 Faults Found:
000 - -
Freeze Frame:
Fault Priority: 5
Reset counter: 197
Mileage: 30800 km
Time Indication: 0
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 8
Mileage: 0 km
Time Indication: 0
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Mileage: 0 km
Time Indication: 0
Freeze Frame:
Fault Priority: 5
Fault Frequency: 34
Reset counter: 237
Mileage: 0 km
Time Indication: 0
Coding: 0004342
Revision: 00H17000
Coding: 0004342
4 Faults Found:
000 - -
Freeze Frame:
Fault Priority: 5
Reset counter: 197
Mileage: 30800 km
Time Indication: 0
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 8
Mileage: 0 km
Time Indication: 0
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Mileage: 0 km
Time Indication: 0
Freeze Frame:
Fault Priority: 5
Fault Frequency: 34
Reset counter: 237
Mileage: 0 km
Time Indication: 0
Coding: 0000144
Coding: 0000144
