eaglemirek, To za wcześnie.Musi być jakiś podkład np.obiad
- P1463 - sterownik elektroniki centralnej, - P3137 - klapa kolektora ssącego, - P0642 - czujnik napięcia referencyjnego.
Sunday,23,November,2014,14:45:08:62939 VCDS -- Windows Based VAG/VAS Emulator VCDS Version: Release 12.12.0 (x64) Data version: 20130910 VIN: [CIACH!] License Plate: Mileage: 121970km-75788mi Repair Order: -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 1Z (1K0) Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 55 56 62 72 76 77 VIN: [CIACH!] Mileage: 121970km/75788miles 00-Steering Angle Sensor -- Status: OK 0000 01-Engine -- Status: Malfunction 0010 03-ABS Brakes -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: Malfunction 0010 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: Malfunction 0010 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: Malfunction 0010 25-Immobilizer -- Status: OK 0000 37-Navigation -- Status: Malfunction 1010 42-Door Elect, Driver -- Status: OK 0000 44-Steering Assist -- Status: OK 0000 46-Central Conv. -- Status: Malfunction 0010 52-Door Elect, Pass. -- Status: OK 0000 55-Xenon Range -- Status: OK 0000 56-Radio -- Status: Malfunction 1010 62-Door, Rear Left -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 76-Park Assist -- Status: OK 0000 77-Telephone -- Status: Sporadic communication error 1000 ------------------------------------------------------------------------------- Address 01: Engine Labels: 06F-907-115-AXX.lbl Part No SW: 1Z0 907 115 A HW: 8P0 907 115 B Component: 2.0l R4/4V TFSI 0040 Revision: 5BH15--- Serial number: SKZ7Z0F3929649 Coding: 0203000318070160 Shop #: WSC 00191 264 15243 VCID: 3365F94752C0B386591-8066 1 Fault Found: 005699 - Please check DTC Memory of Electric Load Controller P1643 - 001 - Freeze Frame: Fault Status: 01100001 Fault Priority: 0 Fault Frequency: 254 Reset counter: 255 Mileage: 118988 km Time Indication: 0 Date: 2000.00.00 Time: 16:24:56 Freeze Frame: RPM: 1981 /min Load: 36.1 % Speed: 17.0 km/h Temperature: 67.0°C Temperature: 27.0°C Absolute Pres.: 990.0 mbar Voltage: 14.224 V Readiness: 0010 0000 ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 1K0-614-517-MK60-F.lbl Part No SW: 1K0 614 517 AC HW: 1K0 614 517 AC Component: ESP FRONT MK60-AT 0102 Revision: 00H13001 Coding: 0037506 Shop #: WSC 73430 790 00000 VCID: 68DF5E2B5B86005E3C3-803D No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 1K0-907-044.lbl Part No: 1Z0 907 044 H Component: ClimatronicPQ35 084 0305 Shop #: WSC 00000 000 00000 VCID: 3B75D1677A907BC6811-806E No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl Part No SW: 3C0 937 049 AE HW: 3C0 937 049 AE Component: Bordnetz-SG H52 2002 Revision: 00H52000 Serial number: 00000004561478 Coding: E18E0F111004140046110D000000000000097F065C0000 Shop #: WSC 73430 790 00000 VCID: 6CD7223B4F7E2C7E58B-8039 Subsystem 1 - Part No: 1Z1 955 119 A Labels: 1KX-955-119.CLB Component: Wischer SK351 012 0401 Coding: 00063477 Shop #: WSC 73430 Subsystem 2 - Part No: 1K0 955 559 AE Labels: 1K0-955-559-AF.CLB Component: RLS 311006 014 1201 Coding: 00471077 Shop #: WSC 73430 1 Fault Found: 00979 - Lamp for Low Beam; Right (M31) 010 - Open or Short to Plus - Intermittent Freeze Frame: Fault Status: 00111010 Fault Priority: 1 Fault Frequency: 7 Reset counter: 27 Mileage: 119667 km Time Indication: 0 Date: 2005.09.13 Time: 31:63:63 Freeze Frame: ON Voltage: 14.10 V ON ON OFF OFF OFF ------------------------------------------------------------------------------- Address 15: Airbags Labels: 1K0-909-605.lbl Part No SW: 1K0 909 605 AA HW: 1K0 909 605 AA Component: Q2 AIRBAG VW8 027 0900 Revision: 11027000 Serial number: 003B5D10CJCX Coding: 0020786 Shop #: WSC 73430 790 00000 VCID: 6BD521274A702B46511-803E Subsystem 1 - Serial number: 6332MSME141B430FA Subsystem 2 - Serial number: 6342MSME133D606AE Subsystem 3 - Serial number: 6351HSME0B79486FR Subsystem 4 - Serial number: 6361HSME0B741F65H No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl Part No SW: 1K0 953 549 BC HW: 1K0 953 549 BC Component: Lenksäulenmodul 036 0070 Coding: 0000042 Shop #: WSC 73430 790 00000 VCID: 74E73A5B174EF4BE80B-8021 1 Fault Found: 00895 - Cruise Control Switch (E45) 014 - Defective ------------------------------------------------------------------------------- Address 17: Instruments Labels: 1K0-920-xxx-17.lbl Part No SW: 1Z0 920 842 C HW: 1Z0 920 842 C Component: KOMBIINSTRUMENT VD1 1612 Revision: V1612036 Serial number: SKZ7Z0F3929649 Coding: 0007101 Shop #: WSC 01010 010 01010 VCID: 377DCD5746B85FA6659-8062 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels: 1K0-907-530-V2.clb Part No SW: 1K0 907 530 K HW: 1K0 907 951 Component: J533__Gateway H04 0020 Revision: H04 02 Serial number: 121106F2000706 Coding: 7D3F07C807002302 Shop #: WSC 73430 790 00000 VCID: 2F6DF537BEE897663D9-807A 4 Faults Found: 01305 - Databus for Infotainment 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 1 Fault Frequency: 18 Reset counter: 20 Mileage: 121617 km Time Indication: 0 Date: 2000.00.00 Time: 15:01:20 01300 - Control Module for Navigation with CD-Rom (J401) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00110100 Fault Priority: 2 Fault Frequency: 201 Reset counter: 34 Mileage: 118138 km Time Indication: 0 Date: 2000.00.00 Time: 16:10:44 01304 - Radio 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00110100 Fault Priority: 2 Fault Frequency: 203 Reset counter: 34 Mileage: 118138 km Time Indication: 0 Date: 2000.00.00 Time: 16:10:44 01303 - Telephone Transceiver (R36) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 254 Reset counter: 34 Mileage: 118129 km Time Indication: 0 Date: 2000.00.00 Time: 07:39:00 ------------------------------------------------------------------------------- Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb Part No SW: 1Z0 920 842 C HW: 1Z0 920 842 C Component: IMMO VD1 1612 Revision: V1612036 Serial number: SKZ7Z0F3929649 Shop #: WSC 00000 000 00000 VCID: 377DCD5746B85FA6659-8062 No fault code found. ------------------------------------------------------------------------------- Address 37: Navigation (J0506) Labels: 1T0-035-680.clb Part No SW: 1Z0 035 680 A HW: 1Z0 035 680 A Component: RNS-MID H04 1004 Revision: AB001001 Serial number: SKZ6Z7H8003077 Coding: 0C0004000001000300 Shop #: WSC 73430 790 00000 VCID: 326BFC436DDABA8E527-8067 7 Faults Found: 00871 - Bass Speaker Front Right (R23) 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 5 Fault Frequency: 254 Reset counter: 250 Mileage: 118128 km Time Indication: 0 00870 - Bass Speaker Front Left (R21) 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 5 Fault Frequency: 254 Reset counter: 250 Mileage: 118128 km Time Indication: 0 00821 - Antenna 2 for Radio (R93) 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 5 Fault Frequency: 254 Reset counter: 250 Mileage: 118128 km Time Indication: 0 01044 - Control Module Incorrectly Coded 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 5 Fault Frequency: 254 Reset counter: 250 Mileage: 118128 km Time Indication: 0 00873 - Bass Speaker Rear Right (R17) 011 - Open Circuit - Intermittent Freeze Frame: Fault Status: 00101011 Fault Priority: 5 Fault Frequency: 1 Reset counter: 8 Mileage: 121280 km Time Indication: 0 01305 - Databus for Infotainment 014 - Defective - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 5 Fault Frequency: 2 Reset counter: 20 Mileage: 0 km Time Indication: 0 00862 - Antenna for GPS Navigation (R50/R52) 007 - Short to Ground - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 5 Fault Frequency: 2 Reset counter: 34 Mileage: 120813 km Time Indication: 0 Date: 2000.00.00 Time: 17:00:07 ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl Part No SW: 1T0 959 701 D HW: 1T0 959 701 D Component: Tuer-SG 005 0943 Coding: 0000244 Shop #: WSC 73430 790 00000 VCID: 387FCE6B4BA650DE6C3-806D No fault code found. ------------------------------------------------------------------------------- Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb Part No: 1K1 909 144 L Component: EPS_ZFLS Kl.074 H07 1806 Shop #: WSC 02069 000 90108 VCID: 3467FA5B57CEB4BE40B-8061 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT Component: KSG PQ35 G2 020 0203 Revision: 00020000 Serial number: 00000000000000 Coding: 80801A085283007F3F02050FC0084FD6907C00 Shop #: WSC 73430 790 00000 VCID: 8305E987C2E04306091-80D6 Subsystem 5 - Part No: 1Z0 951 171 A Component: NeigungsSensor 008 5003 Coding: 00000000 Shop #: WSC 73430 Subsystem 6 - Part No: 1K0 951 605 C Component: LIN BACKUP HORN H03 1301 Subsystem 7 - Part No: 1Z0 951 171 A Component: Innenraumueberw.008 5003 1 Fault Found: 00323 - Vehicle Inclination Sensor (G384) 014 - Defective Freeze Frame: Fault Status: 01101110 Fault Priority: 4 Fault Frequency: 1 Reset counter: 5 Mileage: 118129 km Time Indication: 0 Date: 2000.00.00 Time: 07:38:48 ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl Part No SW: 1T0 959 702 D HW: 1T0 959 702 D Component: Tuer-SG 005 0943 Coding: 0000244 Shop #: WSC 73430 790 00000 VCID: 3979CB6F70AC49D693D-806C No fault code found. ------------------------------------------------------------------------------- Address 55: Xenon Range Labels: 1T0-907-357.lbl Part No: 1T0 907 357 Component: Dynamische LWR 0003 Coding: 0000007 Shop #: WSC 73430 790 00000 VCID: F4E7BA5B974E74BE00B-80A1 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio (J0506) Labels: 1T0-035-680.clb Part No SW: 1Z0 035 680 A HW: 1Z0 035 680 A Component: RNS-MID H04 1004 Revision: AB001001 Serial number: SKZ6Z7H8003077 Coding: 0C0004000001000300 Shop #: WSC 73430 790 00000 VCID: 326BFC436DDABA8E527-8067 7 Faults Found: 00871 - Bass Speaker Front Right (R23) 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 5 Fault Frequency: 254 Reset counter: 250 Mileage: 118128 km Time Indication: 0 00870 - Bass Speaker Front Left (R21) 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 5 Fault Frequency: 254 Reset counter: 250 Mileage: 118128 km Time Indication: 0 00821 - Antenna 2 for Radio (R93) 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 5 Fault Frequency: 254 Reset counter: 250 Mileage: 118128 km Time Indication: 0 01044 - Control Module Incorrectly Coded 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 5 Fault Frequency: 254 Reset counter: 250 Mileage: 118128 km Time Indication: 0 00873 - Bass Speaker Rear Right (R17) 011 - Open Circuit - Intermittent Freeze Frame: Fault Status: 00101011 Fault Priority: 5 Fault Frequency: 1 Reset counter: 8 Mileage: 121280 km Time Indication: 0 01305 - Databus for Infotainment 014 - Defective - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 5 Fault Frequency: 2 Reset counter: 20 Mileage: 0 km Time Indication: 0 00862 - Antenna for GPS Navigation (R50/R52) 007 - Short to Ground - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 5 Fault Frequency: 2 Reset counter: 34 Mileage: 120813 km Time Indication: 0 Date: 2000.00.00 Time: 17:00:07 ------------------------------------------------------------------------------- Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl Part No SW: 1K0 959 703 J HW: 1K0 959 703 J Component: Tuer-SG 005 0907 Coding: 0000144 Shop #: WSC 73430 790 1012544 VCID: 377DCD5746B85FA6659-8062 No fault code found. ------------------------------------------------------------------------------- Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl Part No SW: 1K0 959 704 J HW: 1K0 959 704 J Component: Tuer-SG 005 0907 Coding: 0000144 Shop #: WSC 73430 790 1012544 VCID: 387FCE6B4BA650DE6C3-806D No fault code found. ------------------------------------------------------------------------------- Address 76: Park Assist Labels: 1Z0-919-283.lbl Part No SW: 1Z0 919 283 C HW: 1Z0 919 283 C Component: Parkhilfe 8-Kan H04 0020 Coding: 0000001 Shop #: WSC 73430 790 00000 VCID: 3E73D87369826EEEA6F-806B No fault code found. ------------------------------------------------------------------------------- Address 77: Telephone Cannot be reached End ---------------------------------------------------------------------
