[O2FL] TPMS przez MAXI-DOT (bez przycisku!) 2011+
  • Angel
    • 503
    • CKFC 2.0 TDI CR 150 KM
    #151
    Siemka. Jako nowy stary użuszkodnik.
    Niedawno stałem się posiadaczem O2 FL z 12 roku.
    próbowałem zakodować TPMS-a wg instrukcji.
    Jedyne co uzyskałem to błąd ESP...
    mój skan
    VCDS Version: Release 15.7.0 Running on Windows 10 x86
    Data version: 20150820
    VCDS,VAG-COM,VAGCOM,Diagnose,Diagnostics,DTC,Fault Codes,Data Logging,VW Scan Tool,Audi Scan Tool, VAG Scan Tool,Micro-CAN,HEX-USB+CAN,HEX+CAN,HEX-NET,VAG 11,VAG 12,VAG 14,VAG 15
    Tuesday,20,September,2016,11:18:58:04550
    Chassis Type: 1Z (7N0)
    Scan: 01 03 08 09 10 15 16 17 19 25 37 42 44 46 52 56 62 72 77
    VIN: TMBGE61Z8C8024004 Mileage: 177820km-110492miles
    01-Engine -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    10-Park/Steer Assist -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    25-Immobilizer -- Status: OK 0000
    37-Navigation -- Status: Malfunction 0010
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    56-Radio -- Status: Malfunction 0010
    62-Door, Rear Left -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    77-Telephone -- Status: OK 0000
    Address 01: Engine (J623-CFHC) Labels: 03L-906-018-CFF.clb
    Part No SW: 03L 906 018 C HW: 03L 906 018 BR
    Component: R4 2,0L EDC H24 7100
    Revision: 42H24--- Serial number:
    Coding: 00190012042400080000
    Shop #: WSC 73430 031 00125
    ASAM Dataset: EV_ECM20TDI01103L906018C 003005
    ROD: EV_ECM20TDI01103L906018C.rod
    VCID: 2A4714F31CFFD0D261C404D-807E
    2 Faults Found:
    4629 - ECM Power Relay Load Circuit
    P068A 00 [032] - Opens Too Early
    Intermittent - Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    8169 - Terminal 30
    U140A 00 [032] - Open Circuit
    Freeze Frame:
    Readiness: 0 0 0 0 0
    Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
    Part No SW: 1K0 907 379 BH HW: 1K0 907 379 BH
    Component: ESP MK60EC1 H31 0121
    Revision: 00H31001
    Coding: 113B401C0A2400FE880B02E4501D0042300000
    Shop #: WSC 73430 790 00125
    VCID: 79E5FBBFA9D9ABCA58DEE39-802C
    No fault code found.
    Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
    Part No SW: 3T0 907 044 BK HW: 3T0 907 044 BK
    Component: Climatronic H18 0506
    Revision: 00001007
    Coding: 0000000002
    ASAM Dataset: EV_Climatronic A01010
    ROD: EV_ClimaAutoBasis_SK12.rod
    VCID: 7CEBE2ABA6EB9E6243B8825-8028
    Address 09: Cent. Elect.
    Cannot be reached
    Unable to communicate with address 09. Are you sure the doors are unlocked?
    Address 10: Park/Steer Assist (J446) Labels: 1Z0-919-475-V2.clb
    Part No SW: 1Z0 919 475 E HW: 7N0 919 475
    Component: PARKHILFE 8K H06 0005
    Revision: --H06--- Serial number: 28261201201798
    Coding: 108001
    Shop #: WSC 13765 790 00125
    ASAM Dataset: EV_EPHVA18SKxxx0000 001001
    ROD: EV_EPHVA18SKxxx0000.rod
    VCID: 439959579B95219A42C2311-8016
    Address 15: Airbags Labels: 1K0-909-605.lbl
    Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
    Component: Q6 AIRBAG VW8 020 2300
    Revision: 05020000 Serial number: 0038PC29TXC4
    Coding: 0020790
    VCID: 3D6D2FAFFD715BEA3406779-8068
    Subsystem 1 - Serial number: 6332MSME6865333DI
    Subsystem 2 - Serial number: 6342MSME69361A19H
    Subsystem 3 - Serial number: 6351HSME2B220463/
    Subsystem 4 - Serial number: 6361HSME2B221D65A
    Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
    Part No SW: 5K0 953 521 BN HW: 5K0 953 569 E
    Component: LENKS.MODUL 015 0140
    Revision: FF010040 Serial number: 20120123801096
    Coding: 108A140000
    ASAM Dataset: EV_SMLSNGVOLWSXS A01004
    ROD: EV_SMLSNGVOLWS.rod
    VCID: 79E5FBBFA9D9AB4A58DEE39-802C
    Multi Function Steering Wheel Control Module:
    Subsystem 1 - Part No SW: 3T0 959 537 HW: 3T0 959 537 Labels: 3C8-959-537.CLB
    Component: E221__MFL-URO H07 0012
    Coding: 820000
    Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
    Part No SW: 1Z0 920 843 S HW: 1Z0 920 843 S
    Component: KOMBI H05 0607
    Serial number: 00000000000000
    Coding: 110E00
    ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04114
    ROD: EV_Kombi_UDS_VDD_RM09_SK35.rod
    VCID: 48834E7BA2B302C297B0CE5-801C
    Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
    Part No SW: 7N0 907 530 M HW: 1K0 907 951
    Component: J533 Gateway H42 1623
    Revision: H42 Serial number: 050112F2002572
    Coding: 352302
    VCID: 3A6724B3EC5F60D2112454D-806E
    Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
    Part No SW: 5K0 953 234 HW: 5K0 953 234
    Component: IMMO H05 0607
    Coding: 000000
    Shop #: WSC 00000 000 00000
    ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03009
    ROD: EV_Immo_UDS_VDD_RM09_SE25.rod
    VCID: 6AC7D4F3DC7F10D2A14444D-803E
    Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
    Part No SW: 3T0 035 680 E HW: 3T0 035 680 E
    Component: RNS-MID H61 3984
    Revision: AB001001 Serial number: SKZ6Z7M8024060
    Coding: 04000402000100810000
    VCID: 32770C93342F9892D994FCD-8066
    1 Fault Found:
    00862 - Antenna for GPS Navigation (R50/R52)
    007 - Short to Ground - Intermittent
    Freeze Frame:
    Fault Status: 00100111
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 218
    Mileage: 175859 km
    Time Indication: 0
    Date: 2016.05.22
    Time: 10:47:46
    Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX3.lbl
    Part No SW: 1T0 959 701 AA HW: 1T0 959 701 AA
    Component: Tuer-SG 009 2119
    Coding: 0004342
    VCID: 76FFF08398C7C8B235FCC0D-8022
    Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
    Part No: 1K0 909 144 P
    Component: EPS_ZFLS Kl. 69 3305
    Revision: 00H22000
    Shop #: WSC 20820 456 98472
    VCID: 37613D87DF4D71BAEE4AB51-8062
    Address 46: Central Conv.
    Cannot be reached
    Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
    Part No SW: 1T0 959 702 S HW: 1T0 959 702 S
    Coding: 0004342
    VCID: 48834E7BA2B30E4297B0CE5-801C
    Address 56: Radio (J0506) Labels: 1T0-035-680.clb
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 218
    Mileage: 175859 km
    Time Indication: 0
    Date: 2016.05.22
    Time: 10:47:46
    Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
    Part No SW: 5K0 959 703 A HW: 5K0 959 703 A
    Component: Tuer-SG 007 2101
    Coding: 0000144
    Shop #: WSC 73430 790 1012573
    VCID: 32770C93342F9492D994FCD-8066
    Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
    Part No SW: 5K0 959 704 A HW: 5K0 959 704 A
    Coding: 0000144
    VCID: 33790997CB359D9AD262E11-8066
    Address 77: Telephone (J412) Labels: 7P6-035-730.clb
    Part No SW: 5K0 035 730 E HW: 5K0 035 730 E
    Component: TELEFON H12 2902
    Revision: 1B001001 Serial number: 00007661668546
    Coding: 0201000000010110
    ASAM Dataset: EV_UHVNA A01719
    ROD: EV_UHVNA.rod
    VCID: 2741EDC70FEDEDBA7EEA651-8072
    End-------------------------(Elapsed Time: 02:23)--------------------------
    Pomoże ktoś?
    skan przed zmianami. które powodowały błąd
    • kowaltom99
      • 760
      Kolega ten_azja ma taki sam zestaw
      zegary - "S" i pompa "BH" i uruchomił TPMS przez MAXI DOT
      Skoro jemu zadziałało to u Ciebie też powinno.
      wklej kodowania po zmianach jakie robiłeś.
      • Angel
        • 503
        #153
        Odpaliłem dzisiaj. ABS nie obsługuje HHC....
        • czupakmabra
          • 17
          Chciałbym trochę odświeżyć temat. Udało się może komuś odpalić TMPS'a z Maxidotem w wersji 843 S i ABS'em ESP MK60EC1 w wersji 379 AN. Bo niestety sterownik od ABS'u nie chce zapamiętać ustawień w 17 bajcie tj. TMPS via instruments 2011+. Próbowałem na wszelkie sposoby i lipa .
          • kowaltom99
            • 760
            A masz w VCDS a opcjach wpisane nr workshop itd. Bo jak masz same zera to może kodowanie nie wchodzić.
            • czupakmabra
              • 17
              Tak VCDS'ie nr workshop mam wpisany. Wszystkie wcześniejsze opcje udaje mi się zapisać m.in gateway'u aktywacja C4 TMPS. Dzięki za sugestie bo faktycznie już kiedyś zdarzyło mi się, że brak tego numeru uniemożliwiał zmianę ustawień przez VCDS'a. Security code dla ABS też wprowadzałem ale tak mi wygląda jakby sterownik ABS nie chciał tego przyjąć do wiadomości. Mogę się mylić ale wygląda mi na to, że pomimo, że opcja jest w VCDS to wcale to nie znaczy, że musi ją obsługiwać konkretny sterownik a w moim przypadku ABS'u (379 AN) bo pewnie na to ma wpływ jego wewnętrzne oprogramowanie i zaprojektowana funkcjonalność (trudno wymagać od pompy z 2009, że będzie miała tą samą funkcjonalność co ta z 2011+ w sumie logiczne). Oczywiście to też nie znaczy, że musi być inna i tym się pocieszam. Nie mniej mogę się mylić w całym tym rozumowaniu. Zapraszam do dyskusji może ktoś z doświadczonych forumowiczów chce dorzucić coś od siebie.
              • patryk23
                • 1105
                Miał ktoś podobny problem ,że pacjent 2012 przyjmuje kodowania zero błędów , menu jest ale po próbie zapamiętania ustawien dla kół pokazuje zapisane i za chwilę nie można zapisać ustawień reset maxi nie pomaga
                • georgg
                  • 17203
                  Zamieszczone przez patryk23 Zobacz wpis
                  A zaznaczyłeś byte 16 bit 1?
                  Grzegorz
                  Moja Ambitna Czarnula
                  • patryk23
                    • 1105
                    W ABS , szafie , i CANIe, nawet znalazlem w BCM coś od kontroli ciśnienia ale nic nie daje . problem tylko z zapisaniem wartości .
                    • georgg
                      • 17203
                      patryk23 a czytałeś to - Przy zaznaczonym bicie 0 i 2 w bajcie 16 powinieneś mieć wartość HEX 35 i 00110101 binarnie , a przy bicie 0 , 1 ( nie jest opisany ) , 2 i wtedy HEX 37 i 00110111 binarnie .
                      Grzegorz
                      • patryk23
                        • 1105
                        Zamieszczone przez georgg Zobacz wpis
                        Jest tak jak jak w opisie odkodowane i zakodowane parę razy z resetem maxi za każdym razem oraz różne kolejności kodowania elementów can, zegary , abs.
                        • georgg
                          • 17203
                          To już nie wiem. U mnie to wszystko zagrało.
                          Grzegorz
                          • patryk23
                            • 1105
                            Sprawa rozwiązana , sam nie wiem w czym był problem ale po odpięciu aku zagrało...
                            • sebwiecz
                              • 330
                              • Yeti (5L)
                              #164
                              Hejka
                              Yeti MY13 działa fajnie
                              Ale się micha cieszy..
                              http://forum.octaviaclub.pl/viewtopic.php?t=70046
                              • sebwiecz
                                • 330
                                • Yeti (5L)
                                #165
                                Testował ktoś przy o ile jest mniejsze ciśnienie w kole?
                                Zimno trochę i nie chce mi się tego testować teraz
                                • sebos81
                                  • 66
                                  U mnie wszystko się zakodowało poprawnie na MAXI DOT też jest ok ale musiałem ręcznie wklepać bajt 16 na 36 zobaczymy jak pojeżdze
                                  • macherstudio
                                    • 2378
                                    • Mitshibishi
                                    Szanowni forumowicze, proszę was o pomoc:
                                    Superb IIFL (2013)
                                    Menu Maxi-Dot pokazuje TSMP - zakodowało się
                                    Błąd w zapisie wartości ciśnienia - nie da się zapisać niestety
                                    Mam takiego LOGa (ale on jest chyba sprzed kodowania)
                                    Part No SW: 1K0 907 379 BL HW: 1K0 907 379 BL
                                    Component: ESP MK60EC1 H31 0152
                                    Revision: 00H31001
                                    Coding: 843D6016092400FE211306E6901C0050300000
                                    Shop #: WSC 33361 790 00052
                                    VCID: 7D1435FBE4FEFEFAAED834-8028
                                    www.prostetorodo.pl
                                    • Maly745
                                      • 773
                                      Wygląda na z przed kodowania
                                      Skoda Octavia II FL
                                        • 11351
                                        czyli sam włączałeś? bo to nie tylko w ABS trzeba, ale jeszcze w liczniku
                                        • Res2
                                          • 2019
                                          #170
                                          Hej, jestem nowy na forum... piszę ponieważ oczywiście mam problem z vcds i uruchomieniem funkcji TPMS.
                                          Posiadam Skode Octavie z 2012 2.0 140 km
                                          Coś sam próbowałem z instrukcją zrobić, ale nie wyszło.
                                          Jeżeli jesteście w stanie mi pomóc to byłbym wdzięczny.
                                          wklejam ostatni scan auta
                                          Środa,09,Styczeń,2019,19:57:16:00007
                                          VCDS -- Emulator VAG/VAS pracujący w środowisku Windows, uruchomiony na Windows 10 x64
                                          Wersja VCDS: AKP 18.9.0.2
                                          Wersja danych: 20181107 DS296.0
                                          Dealer/nazwa serwisu: JJSerwis
                                          Kod serwisu: 678 12345 091234
                                          VIN: TMBGE61Z0C2126867 Numer rejestracyjny:
                                          Typ podwozia: 1Z-SK35 (7N0)
                                          Skanowanie: 01 03 08 09 10 15 16 17 19 25 37 42 44 46 4C 52 56 62 72 77
                                          VIN: TMBGE61Z0C2126867 Przebieg: 264530km
                                          01-Silnik -- Stan: OK 0000
                                          03-ABS/hamulce -- Stan: OK 0000
                                          04-Kąt skrętu kierow. -- Stan: OK 0000
                                          08-Klimatyzacja -- Stan: OK 0000
                                          09-Centr.zesp.elektr. -- Stan: OK 0000
                                          10-Asyst.park./kierow. -- Stan: OK 0000
                                          15-Airbag -- Stan: OK 0000
                                          16-Koło kierownicy -- Stan: OK 0000
                                          17-Zest.wskaźników -- Stan: OK 0000
                                          19-CAN Gateway -- Stan: Usterka 0010
                                          25-Immobiliser -- Stan: OK 0000
                                          37-Nawigacja -- Stan: OK 0000
                                          42-Elektr.drzwi kier. -- Stan: OK 0000
                                          44-Wsp.kierownicy -- Stan: OK 0000
                                          46-Moduł komfortu -- Stan: OK 0000
                                          4C-Ciśn.w oponach II -- Stan: Nie może być osiągnięty 1100
                                          52-Elektr.drzwi pas. -- Stan: OK 0000
                                          56-Radio -- Stan: OK 0000
                                          62-Drzwi tylne lewe -- Stan: OK 0000
                                          72-Drzwi tylne prawe -- Stan: OK 0000
                                          77-Telefon -- Stan: OK 0000
                                          Adres 01: Silnik (J623-CFHC) Plik etykiet:. 03L-906-018-CFF.clb
                                          Oznaczenie elementu SW: 03L 906 018 C HW: 03L 906 018 BR
                                          Komponent: R4 2.0l TDI H24 9978
                                          Weryfikacja: 42H24--- Numer seryjny:
                                          Kodowanie: 00190012042400080000
                                          Kod serwisu: WSC 42818 001 1048576
                                          Zbiór danych ASAM: EV_ECM20TDI01103L906018C 003008
                                          VCID: 2A5BB4A94DFF2E1AAB-807E
                                          Nie znaleziono błędów.
                                          Kody gotowości: 0 0 0 0 0
                                          Adres 03: ABS/hamulce (J104) Plik etykiet:. 1K0-907-379-60EC1F.clb
                                          Oznaczenie elementu SW: 1K0 907 379 BH HW: 1K0 907 379 BH
                                          Komponent: ESP MK60EC1 H31 0121
                                          Weryfikacja: 00H31001
                                          Kodowanie: 113B401C09240000881302EA90200062340000
                                          Kod serwisu: WSC 12345 678 91234
                                          VCID: 79F95BE5F0D9558292-802C
                                          Adres 08: Klimatyzacja (J255) Plik etykiet:| 5K0-907-044.clb
                                          Oznaczenie elementu SW: 3T0 907 044 BK HW: 3T0 907 044 BK
                                          Komponent: Climatronic H18 0506
                                          Weryfikacja: 00001007
                                          Kodowanie: 0000000002
                                          Kod serwisu: WSC 73430 790 00090
                                          Zbiór danych ASAM: EV_Climatronic A01010
                                          ROD: EV_ClimaAutoBasis_SK35.rod
                                          VCID: 7CF742F1F7EB60AA89-8028
                                          Adres 09: Centr.zesp.elektr. (J519) Plik etykiet:. AKP\1K0-937-08x-09.clb
                                          Oznaczenie elementu SW: 1K0 937 087 Q HW: 1K0 937 087 Q
                                          Komponent: BCM PQ35 H 110 0651
                                          Weryfikacja: 00110 AC
                                          Kodowanie: 40000AB8E00508C040080080110001E4437000AE726D81605C 8540000040
                                          VCID: 3F8DF5FDAE7DBBB2EC-806A
                                          Podsystem 1 - Oznaczenie elementu: 1Z1 955 119 D Plik etykiet: 1KX-955-119.CLB
                                          Komponent: Wischer 07011 26 0601
                                          Kodowanie: 00D7B7
                                          Podsystem 2 - Oznaczenie elementu: 1K0 955 559 AH Plik etykiet: 1K0-955-559-AG.CLB
                                          Komponent: RLS 040112 05 54 0403
                                          Kodowanie: 0730ED
                                          Adres 10: Asyst.park./kierow. (J446) Plik etykiet:| 1Z0-919-475-V2.clb
                                          Oznaczenie elementu SW: 1Z0 919 475 E HW: 7N0 919 475
                                          Komponent: PARKHILFE 8K H06 0005
                                          Weryfikacja: --H06--- Numer seryjny: 28261134802262
                                          Kodowanie: 108001
                                          Kod serwisu: WSC 13765 790 00090
                                          Zbiór danych ASAM: EV_EPHVA18SKxxx0000 001001
                                          ROD: EV_EPHVA18SKxxx0000_001.rod
                                          VCID: 4385F90DCA95DF5288-8016
                                          Adres 15: Airbag Plik etykiet: 1K0-909-605.lbl
                                          Oznaczenie elementu SW: 1K0 909 605 T HW: 1K0 909 605 T
                                          Komponent: Q6 AIRBAG VW8 020 2300
                                          Weryfikacja: 05020000 Numer seryjny: 0038PD2UMYPX
                                          Kodowanie: 0020790
                                          VCID: 3D718FF56471A9A2FE-8068
                                          Podsystem 1 - Numer seryjny: 6332MSME497245057
                                          Podsystem 2 - Numer seryjny: 6342MSME682225333
                                          Podsystem 3 - Numer seryjny: 6351HSME2B191E51B
                                          Podsystem 4 - Numer seryjny: 6361HSME2B1A0B09C
                                          Adres 16: Koło kierownicy (J527) Plik etykiet:| 5K0-953-569.clb
                                          Oznaczenie elementu SW: 5K0 953 521 BN HW: 5K0 953 569 E
                                          Komponent: LENKS.MODUL 015 0140
                                          Weryfikacja: FF010040 Numer seryjny: 20120110800409
                                          Kodowanie: 108A140000
                                          Zbiór danych ASAM: EV_SMLSNGVOLWSXS A01004
                                          VCID: 79F95BE5F8D9558292-802C
                                          Sterownik kierownicy wielofunkcyjnej:
                                          Podsystem 1 - Oznaczenie elementu SW: 3T0 959 537 HW: 3T0 959 537 Plik etykiet: 3C8-959-537.CLB
                                          Komponent: E221__MFL-URO H07 0012
                                          Kodowanie: 820000
                                          Adres 17: Zest.wskaźników (J285) Plik etykiet:| 5K0-920-xxx-17.clb-SRI1
                                          Oznaczenie elementu SW: 1Z0 920 843 S HW: 1Z0 920 843 S
                                          Komponent: KOMBI H05 0607
                                          Numer seryjny: 00000000000000
                                          Kodowanie: 110E01
                                          Zbiór danych ASAM: EV_Kombi_UDS_VDD_RM09 A04114
                                          ROD: EV_Kombi_UDS_VDD_RM09_004_SK34.rod
                                          VCID: 489FEE21F3B3FC0A5D-801C
                                          Adres 19: CAN Gateway (J533) Plik etykiet:. AKP\7N0-907-530-V2.clb
                                          Oznaczenie elementu SW: 7N0 907 530 M HW: 1K0 907 951
                                          Komponent: J533 Gateway H42 1623
                                          Weryfikacja: H42 Numer seryjny: 191211F1000405
                                          Kodowanie: 352302
                                          VCID: 3A7B84E9B55F9E9ADB-806E
                                          Znaleziono 1 błąd:
                                          03109 - Sterownik układu kontroli ciśnienia w oponach 2 (J793)
                                          004 - Brak sygnału / brak komunikacji
                                          Adres 25: Immobiliser (J334) Plik etykiet:| 5K0-920-xxx-25.clb
                                          Oznaczenie elementu SW: 5K0 953 234 HW: 5K0 953 234
                                          Komponent: IMMO H05 0607
                                          Kodowanie: 000000
                                          Kod serwisu: WSC 00000 000 00000
                                          Zbiór danych ASAM: EV_Immo_UDS_VDD_RM09 A03009
                                          ROD: EV_Immo_UDS_VDD_RM09.rod
                                          VCID: 6ADB74A98D7FEE1A6B-803E
                                          Adres 37: Nawigacja (J794) Plik etykiet:| 1K0-035-27x-37.clb
                                          Oznaczenie elementu SW: 3T0 035 192 E HW: 3T0 035 192 E
                                          Komponent: RNS315-EU H34 0263
                                          Numer seryjny: SKZAZ2M9237894
                                          Kodowanie: 000004310401000000008000
                                          Kod serwisu: WSC 73430 031 00090
                                          Zbiór danych ASAM: EV_RNS315EUV2UDS A01004
                                          ROD: EV_RNS315EUV2UDS.rod
                                          VCID: 306FA6C16B2354CA65-8064
                                          Naklejka z danymi:
                                          Podsystem 1 - Oznaczenie elementu: 3AA 919 866
                                          Komponent: EUR_W_0038 0038
                                          Adres 42: Elektr.drzwi kier. Plik etykiet:. AKP\1K0-959-701-MAX3.clb
                                          Oznaczenie elementu SW: 1T0 959 701 AA HW: 1T0 959 701 AA
                                          Komponent: Tuer-SG 009 2119
                                          Kodowanie: 0004342
                                          VCID: 76E350D901C73AFAFF-8022
                                          Adres 44: Wsp.kierownicy Plik etykiet: 1K0-909-14x-GEN3.clb
                                          Oznaczenie elementu: 1K0 909 144 N
                                          Komponent: EPS_ZFLS Kl. 69 3301
                                          Weryfikacja: 00H22000
                                          VCID: 356197D55C4171E236-8060
                                          Adres 52: Elektr.drzwi pas. Plik etykiet:. AKP\1K0-959-702-MAX3.clb
                                          Oznaczenie elementu SW: 1T0 959 702 S HW: 1T0 959 702 S
                                          Kodowanie: 0004342
                                          VCID: 489FEE213BB3FC0A5D-801C
                                          Adres 62: Drzwi tylne lewe Plik etykiet:. AKP\1K0-959-703-GEN3.clb
                                          Oznaczenie elementu SW: 5K0 959 703 A HW: 5K0 959 703 A
                                          Komponent: Tuer-SG 007 2101
                                          Kodowanie: 0000144
                                          Kod serwisu: WSC 73430 790 1012570
                                          VCID: 326BACC9AD2F66DA13-8066
                                          Adres 72: Drzwi tylne prawe Plik etykiet:. AKP\1K0-959-704-GEN3.clb
                                          Oznaczenie elementu SW: 5K0 959 704 A HW: 5K0 959 704 A
                                          Kodowanie: 0000144
                                          VCID: 3365A9CD52356FD218-8066
                                          Adres 77: Telefon (J412) Plik etykiet:. 3C8-035-730-A.clb
                                          Oznaczenie elementu SW: 3C8 035 730 B HW: 3C8 035 730 B
                                          Komponent: Telefon 015 0723
                                          Weryfikacja: -------- Numer seryjny: 35909603290386
                                          Kodowanie: 020000000100010000000000
                                          Zbiór danych ASAM: EV_UHVPremi A02003
                                          ROD: EV_UHVPremi_A02.rod
                                          VCID: 224B5C8935CFF65AE3-8076
                                          Nie można otworzyć:
                                          NF5AF5XOFClaqn5I3
                                          Koniec --------------------(Skanowanie trwało: 03:03)----------------------
                                          Ostatnio edytowany przez Res2; 47973.
                                          • Res2
                                            • 2019
                                            #171
                                            ok, udało mi się odpalić TMPS Dzięki za pomoc... :-P
                                            • Angel
                                              • 503
                                              #172
                                              Po pomocy przez tel pomogło odkodowanie całości, uśpienie systemów i ponowne kodowanie.
                                              • guzu2
                                                • 2022
                                                • 5
                                                Cześć wszystkim.
                                                Odświeżę troszkę tamat (być może ktoś tu jeszcze zagląda i pomoże ).
                                                W moim posiadaniu jest Skoda Octavia 2 FL z 2012 roku, wersje Ambiente (2.0 TDI 140 KM, CFHC) . Jakiś czas temu wymieniłem licznik na MAXI DOT (ustawienie immobilaizera i przegranie stanu km), dodałem tempomat - (wymiana manetek i taśmy kierownicy), zmieniłem kierownicę na multifunkcję (5L0 z Yeti). Wszystko ładnie działa, kilka korekt podczas kodowania.
                                                Planowałem też dołożyć przycisk TPMS, ale po przejrzeniu kilku stron forów w internecie (w tym również tego wątku) i obejrzeniu filmiku z kanału Krzynol garage, postanowiłem zakodować TPMS z opcją resetu z poziomu MAXIDOT'a.
                                                Moje zegary to 1Z0 920 843 S H06 608 - jest polska wersja językowa.
                                                Pompa elektronika ABS 1K0 907 379 BK ESP MK60EC1 H31 0152; hydraulika 1K0 614 517 DN (L1) ATE 10.0212-0700.4 (jest XDS, brak HHC)
                                                Wszystko ładnie, pięknie (no może )zostało zakodowane:
                                                - w pompie ABS (bajt 16, bajt 17), kodowanie przyjęte - brak błędów.
                                                - w Gatawey - TPMS 2 na liscie zaznaczone (4C).
                                                - licznik został zakodowany (co widać - 01 w końcówce kodowania)
                                                Efekt: nie ma błędów po zakodowaniu, przy zapłonie pojawia sie "oponka z wykrzyknikiem", na wyświtlaczu nie pojawia sie opcja "Ciśnienie w oponach"
                                                Uwaga - TPMS działa. Przy zmniejszeniu ciśnienia w jednym w kół i przejechaniu kilkuset metrów, na wyświetlaczu pojawił się komunikat o konieczności sprawdzeniu ciśnieniu w konkretnej oponie (foto).
                                                Zmiana kolejnosci kodowań, uśpienie, zmiana dwóch wersji oprogramowań VCDS (głowica to chiński klon), odpinanie klem, reset ustawień fabrycznych licznika nie przynosi efektu - w dalszym ciągu prak opcji w MAXIDOT.
                                                Dodatkowo wykonałem zestawieie (w tabeli) z informacją odnośnie wyświetlenia opcji na MAXIDOCIE, z resetem ustawień "ciśnienia w oponach" (z tym co pisali użytkownicy niniejszego wątku), odnosnie wersji pomp ABS i wersji liczników (poniżej).
                                                Teoretycznie, pompa ABS z daną elektroniką jaką posiadam wysyła sygnał. Licznik w tej wersji - 843S -posiada takie menu, ale ...
                                                Poniżej wklejam moje kodowanie, kilka zdjęć i tabelę.
                                                Czy coś mi umyka podczas kodowania?
                                                Czy ważna jest kolejnosć kodowania?
                                                Czy jeszcze jakaś inna opcja powinna być włączona?
                                                Czy trzeba zmienic soft licznika? (np. dograć jakiś plik - tak jak w przypadku "przerwy na kawkę" do gataway'a). Ten co mam to chyba ostatnia oficjalna wersja.
                                                Czy pompa nie wysyła właściwego sygnału? (Swoją drogą jestem ciekaw, że raz coś wystarczy wykonać np w adaptacjach i licznik to wykonuje, a raz zakodować w innym miejscu np. aby pojawiły się opcje Światło i ... i Komfort, należy mieć zaznaczony bajt 9 bit 3 w BCM).
                                                Czy można wykonać flash softu pompy (czytałem, że wersję BK raczej nie, albo nie ma wzorca na co można)?
                                                L.p Oznaczenie ABS HW SW Wersja licznika HW SW Widok w zegarach Uzytkownik Uwagi
                                                1 1K0907379BK H31 0152 1Z0920843Q tak georgg
                                                2 1K0907379AS pitersoon
                                                3 1K0907379AK 00H35001 obrus MK70
                                                4 1K0907379AK Wojtenio na przycisk
                                                5 tak paskuda
                                                6 1K0907379BD 1Z0920843K nie mecc
                                                7 1K0907379BD 1Z0920843Q tak heretic
                                                8 1Z0920843S H05 0607 tak Maicroft
                                                9 1K0907379BE 1Z0920843D nie kowaltom99
                                                10 1K0907379BE 1Z0920843S tak kowaltom99
                                                11 1K0907379BH nie rodro
                                                12 1K0907379BH 1Z0920843S tak panandrzejczak
                                                13 1K0907379BH H31 0121 tak leonn
                                                14 1K0907379BH 1Z0920843Q tak rodro
                                                15 1K0907379BD H31 0108 1Z0920843K H20 0420 nie uli07
                                                16 1K0907379BE 1Z0920843M nie sawic
                                                17 1K0907379AK 1Z0920843Q nie DJ Młody
                                                18 1K0907379AN H45 0107 1Z0920843Q nie ravas
                                                19 1K0907379BJ H31 0121 1Z0920843Q tak ravas zmiana pompy
                                                20 1K0907379BH H31 0121 tak Wojtenio
                                                21 1K0907379BL H31 0152 1Z0920843S H06 0608 tak pawnowy
                                                22 1K0907379BD H31 0108 1Z0920843M nie?? rafiki
                                                23 tak Ciacho123
                                                24 1K0907379BH H31 0121 1Z0920843S H05 0607 tak ten_azja
                                                25 1K0907379BE H31 0108 1Z0920843K H20 0420 krzysn
                                                26 1K0907379BH H31 0121 1Z0920843S H05 0607 tak Angel
                                                27 1K0907379AN 1Z0920843S tak czupakambra
                                                28 1K0907379BH H31 0121 1Z0920843S H05 0607 tak Res2
                                                29 1K0907379BH H31 0121 1Z0920843S H05 0607 tak Krzynol
                                                30 1K0907379BK H31 0152 1Z0920843S H06 0608 nie guzik
                                                Pompa ABS:
                                                Kod:
                                                Thursday,24,February,2022,10:57:11:00009
                                                VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
                                                VCDS Version: 21.9.0.2 (x64)
                                                Data version: 20210903 DS330.0
                                                VIN: License Plate: ABS
                                                Mileage: 136220km-84643mi Repair Order:
                                                Control Module Part Number: 1K0 907 379 BK
                                                Component and/or Version: ESP MK60EC1 H31 0152
                                                Software Coding: 113B401C092800FF880F02ED901F0042060400
                                                Work Shop Code: WSC 73430
                                                VCID: 7CF741F7FFEB6E691D-8028
                                                Advanced Identification
                                                Identification: TT1-03B
                                                Revision: 00H31001
                                                Date: 01.09.12
                                                Manufacturer number: 0301
                                                Test stand number: 0BF9
                                                Flash Status
                                                Programming Attempts(application): 0
                                                Successful Attempts(application): 0
                                                Programming Status: 00000000
                                                Flash Date: 2000.14.00
                                                Flash Tool Code: 00000 000 00000
                                                Misc.
                                                Hardware number: 1K0 907 379 BK
                                                Workshop System Name: J104
                                                VCDS Info:
                                                Zegary:
                                                Kod:
                                                Thursday,24,February,2022,10:34:08:00009
                                                Control Module Part Number: 1Z0 920 843 S
                                                Component and/or Version: KOMBI H06 0608
                                                Software Coding: 110A01
                                                VCID: 489FED27F3B3F2C9C9-801C
                                                Advanced Identification/FAZIT
                                                Identification: VD1-048
                                                Date: 08.03.13
                                                Manufacturer number: 5250
                                                Test stand number: 0480
                                                Flash Status
                                                Programming Attempts(application): 0/0/14/0/0/0/0/0/0/0
                                                Successful Attempts(application): 0/0/0/0/0/0/0/0/0/0
                                                Flash Date: 00.00.00
                                                Software
                                                BAP: 01.04.01
                                                OSEK-OS: 03.14.00
                                                HiSpd Net: 01.12.01
                                                Misc.
                                                Hardware number: 1Z0 920 843 S
                                                Workshop System Name: J285
                                                Equipment/PR Code: 2D2D2D2D2D2D2D2D
                                                Dataset Number: -----------
                                                Dataset Version: ----
                                                End of Line Equipment Level: ------------------
                                                ASAM Dataset Revision: A04114
                                                Car Info
                                                Chassis Number: TMBCE61Z3D2065496
                                                VCDS Info:
                                                Labels: 5K0-920-xxx-17.clb-SRI1
                                                ROD: EV_Kombi_UDS_VDD_RM09_004_SK35.rod
                                                Kodowanie auta:
                                                Kod:
                                                Monday,14,March,2022,21:30:23:00009
                                                Chassis Type: 1Z-SK35 (7N0)
                                                Scan: 01 03 08 09 10 15 16 17 19 25 42 44 46 4C 52 56 62 72
                                                VIN: TMBCE61Z3D2065496 Mileage: 137050km-85158miles
                                                4C-Tire Pressure II -- Status: OK 0000
                                                56-Radio -- Status: OK 0000
                                                Address 01: Engine (J623-CFHC) Labels:. 03L-906-018-CFF.clb
                                                Component: R4 2,0L EDC H25 9813
                                                Revision: 42H25--- Serial number: CVN: 619E22EA
                                                Shop #: WSC 73430 031 00206
                                                ASAM Dataset: EV_ECM20TDI01103L906018C 003006
                                                VCID: 2A5BB7AF4DFF20D93F-807E
                                                VINID: 91D49354606A0D408018510918D675478B
                                                Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-60EC1F.clb
                                                Part No SW: 1K0 907 379 BK HW: 1K0 907 379 BK
                                                Revision: 00H31001
                                                Coding: 113B401C092800FF880F02ED901F0042360C00
                                                Shop #: WSC 73430 790 00206
                                                Address 08: Auto HVAC (J255) Labels:| 5K0-907-044.clb
                                                Part No SW: 3T0 907 044 BS HW: 3T0 907 044 BS
                                                Component: Climatronic H19 0606
                                                Revision: 00001007
                                                Coding: 0010000002
                                                VCID: 040739178F1B16A965-8050
                                                Address 09: Cent. Elect. (J519) Labels:. 1K0-937-08x-09.clb
                                                Part No SW: 1K0 937 087 AD HW: 1K0 937 087 AD
                                                Component: BCM PQ35 H 111 0709
                                                Revision: AC111709
                                                Coding: 46000AB8A00508C040580080150081E4436800AE524D85605C 8440000040
                                                VCID: 73E56ACBD2B521114C-8026
                                                Subsystem 1 - Part No: 1Z1 955 119 D Labels: 1KX-955-119.CLB
                                                Component: Wischer 11091 26 0601
                                                Coding: 00D7B7
                                                Address 10: Park/Steer Assist (J446) Labels:| 5J0-919-475.clb
                                                Part No SW: 5J0 919 475 A HW: 5J0 919 475 A
                                                Component: PARKHILFE 4K H11 0005
                                                Revision: --H11--- Serial number: 32901225503593
                                                Coding: 10000E
                                                Shop #: WSC 13765 790 00206
                                                ASAM Dataset: EV_EPHVA14SKxxx0000 001001
                                                ROD: EV_EPHVA14SKxxx0000_001.rod
                                                VCID: 3365AACB9A3561118C-8066
                                                Revision: 05020000 Serial number: 0038PD2XU4PE
                                                Coding: 0020790
                                                VCID: 3D718CF36471A7616A-8068
                                                Subsystem 1 - Serial number: 6332MSME7043222E5
                                                Subsystem 2 - Serial number: 6342MSME7044375FH
                                                Subsystem 3 - Serial number: 6351HSME2E457377G
                                                Subsystem 4 - Serial number: 6361HSME2E3D094AN
                                                Address 16: Steering wheel (J527) Labels:| 5K0-953-569.clb
                                                Part No SW: 5K0 953 507 AH HW: 5K0 953 549 B
                                                Component: Lenks.Modul 008 0080
                                                Revision: -------- Serial number: 90440KGF000X5
                                                Coding: 1082144000
                                                Shop #: WSC 01357 011 00200
                                                ASAM Dataset: EV_SMLSNGKUDS A05001
                                                ROD: EV_SMLSNGKUDS_A05.rod
                                                VCID: 76E353DFC9C734396B-8022
                                                Multifunction steering wheel control module:
                                                Subsystem 1 - Part No SW: 5E0 919 719 F HW: 5E0 919 719 F
                                                Component: E221__MFL-PR6 H05 0130
                                                Serial number: 000000000A0829220115
                                                Coding: 820000
                                                Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
                                                Component: KOMBI H06 0608
                                                Coding: 110A01
                                                Shop #: WSC 73430 031 00213
                                                Address 19: CAN Gateway (J533) Labels:. 7N0-907-530-V2.clb
                                                Part No SW: 7N0 907 530 BL HW: 7N0 907 530 AN
                                                Component: J533 Gateway H56 1682
                                                Revision: H56 Serial number: 161011F2001609
                                                Coding: 351302
                                                Shop #: WSC 00046 123 12345
                                                VCID: 7BF542EBFAE5695114-802E
                                                Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
                                                Component: IMMO H06 0608
                                                Coding: 000000
                                                ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
                                                VCID: 6ADB77AF8D7FE0D9FF-803E
                                                Address 42: Door Elect, Driver Labels:. 1K0-959-701-MIN3.clb
                                                Part No SW: 1T0 959 701 T HW: 1T0 959 701 T
                                                Coding: 0000244
                                                VCID: 489FED273BB3F2C9C9-801C
                                                Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
                                                Revision: 00H22000
                                                VCID: 377D9EDB464D8D31B0-8062
                                                Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MIN3.clb
                                                Part No SW: 1T0 959 702 R HW: 1T0 959 702 R
                                                Coding: 0000244
                                                VCID: 479DEE1B36ADFDB1C0-8012
                                                Address 56: Radio (J503) Labels:. 5M0-035-1xx-56.clb
                                                Part No SW: 1Z0 035 161 F HW: 1Z0 035 161 F
                                                Component: SWING 010 0081
                                                Revision: 0I001001 Serial number: SKZ1Z2M9732025
                                                Coding: 0D0004000001
                                                VCID: 3169A0C368295301FE-8064
                                                Address 62: Door, Rear Left Labels:. 1K0-959-703-GEN3.clb
                                                Coding: 0000144
                                                Shop #: WSC 73430 790 1012558
                                                VCID: 326BAFCFAD2F681987-8066
                                                Address 72: Door, Rear Right Labels:. 1K0-959-704-GEN3.clb
                                                Coding: 0000144
                                                VCID: 3365AACB523561118C-8066
                                                End-------------------------(Elapsed Time: 02:13)--------------------------
                                                Komunikat o utracie ciśnienia
                                                Naklejka z licznika
                                                Pompa hydraulika.
                                                Ostatnio edytowany przez guzu2; 9995403.
                                                  • 11351
                                                  spróbuj to kodowanie abs
                                                  113B401C092800FF880F02ED901F0042320C00
                                                  chociaż nie bo podajesz w skanach dwa różne kodowania ABS i nie wiadomo do czego się odnieść
                                                  wyłącz B16b2, zostaw tylko B17b2
                                                  Ostatnio edytowany przez krzynol; 1427.
                                                  • guzu2
                                                    • 2022
                                                    • 5
                                                    Cześć.
                                                    Kodowanie auta jest to ostatnia wersja jaką mialem z marca. Te z samej pompy to tylko podalem dla szczegółów co to za pompa jaki soft czy flashowana itp. data z lutego.
                                                    Wiem o co chodzi z tym B16b2 - dzis sprawdze i dam znać,. Obawiam sie tylko że po wyłączeniu tego bitu w ogóle nie będzie tpms - nie zaswieci sie oponka z wykrzyknikiem przy zapłonie na liczniku.
                                                    Generalnie to chyba B16b2 to w ogole uruchomienie TPMS a B16b1, ktory jest ukryty, pozwala wykonać sam reset z licznika (pod warunkiem ,że opcja się pojawi w menu.
                                                    Wydaje mi sie że to już przerabiałem., ale... sprawdzę bo juz jestem ... prawie na etapie zamawiania przycisku .
                                                    P.S. przy okazji dziekuje na namiary do Damiana, ktory mi ten licznik adaptował.
