Siemka. Jako nowy stary użuszkodnik.
Niedawno stałem się posiadaczem O2 FL z 12 roku.
próbowałem zakodować TPMS-a wg instrukcji.
Jedyne co uzyskałem to błąd ESP...
mój skan
VCDS Version: Release 15.7.0 Running on Windows 10 x86
Data version: 20150820
Tuesday,20,September,2016,11:18:58:04550
Chassis Type: 1Z (7N0)
Scan: 01 03 08 09 10 15 16 17 19 25 37 42 44 46 52 56 62 72 77
VIN: TMBGE61Z8C8024004 Mileage: 177820km-110492miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (J623-CFHC) Labels: 03L-906-018-CFF.clb
Part No SW: 03L 906 018 C HW: 03L 906 018 BR
Component: R4 2,0L EDC H24 7100
Revision: 42H24--- Serial number:
Coding: 00190012042400080000
Shop #: WSC 73430 031 00125
ASAM Dataset: EV_ECM20TDI01103L906018C 003005
ROD: EV_ECM20TDI01103L906018C.rod
VCID: 2A4714F31CFFD0D261C404D-807E
2 Faults Found:
4629 - ECM Power Relay Load Circuit
P068A 00 [032] - Opens Too Early
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
8169 - Terminal 30
U140A 00 [032] - Open Circuit
Freeze Frame:
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BH HW: 1K0 907 379 BH
Component: ESP MK60EC1 H31 0121
Revision: 00H31001
Coding: 113B401C0A2400FE880B02E4501D0042300000
Shop #: WSC 73430 790 00125
VCID: 79E5FBBFA9D9ABCA58DEE39-802C
No fault code found.
Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
Part No SW: 3T0 907 044 BK HW: 3T0 907 044 BK
Component: Climatronic H18 0506
Revision: 00001007
Coding: 0000000002
ASAM Dataset: EV_Climatronic A01010
ROD: EV_ClimaAutoBasis_SK12.rod
VCID: 7CEBE2ABA6EB9E6243B8825-8028
Address 09: Cent. Elect.
Cannot be reached
Unable to communicate with address 09. Are you sure the doors are unlocked?
Address 10: Park/Steer Assist (J446) Labels: 1Z0-919-475-V2.clb
Part No SW: 1Z0 919 475 E HW: 7N0 919 475
Component: PARKHILFE 8K H06 0005
Revision: --H06--- Serial number: 28261201201798
Coding: 108001
Shop #: WSC 13765 790 00125
ASAM Dataset: EV_EPHVA18SKxxx0000 001001
ROD: EV_EPHVA18SKxxx0000.rod
VCID: 439959579B95219A42C2311-8016
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
Component: Q6 AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PC29TXC4
Coding: 0020790
VCID: 3D6D2FAFFD715BEA3406779-8068
Subsystem 1 - Serial number: 6332MSME6865333DI
Subsystem 2 - Serial number: 6342MSME69361A19H
Subsystem 3 - Serial number: 6351HSME2B220463/
Subsystem 4 - Serial number: 6361HSME2B221D65A
Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
Part No SW: 5K0 953 521 BN HW: 5K0 953 569 E
Component: LENKS.MODUL 015 0140
Revision: FF010040 Serial number: 20120123801096
Coding: 108A140000
ASAM Dataset: EV_SMLSNGVOLWSXS A01004
ROD: EV_SMLSNGVOLWS.rod
VCID: 79E5FBBFA9D9AB4A58DEE39-802C
Multi Function Steering Wheel Control Module:
Subsystem 1 - Part No SW: 3T0 959 537 HW: 3T0 959 537 Labels: 3C8-959-537.CLB
Component: E221__MFL-URO H07 0012
Coding: 820000
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 1Z0 920 843 S HW: 1Z0 920 843 S
Component: KOMBI H05 0607
Serial number: 00000000000000
Coding: 110E00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04114
ROD: EV_Kombi_UDS_VDD_RM09_SK35.rod
VCID: 48834E7BA2B302C297B0CE5-801C
Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 M HW: 1K0 907 951
Component: J533 Gateway H42 1623
Revision: H42 Serial number: 050112F2002572
Coding: 352302
VCID: 3A6724B3EC5F60D2112454D-806E
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H05 0607
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03009
ROD: EV_Immo_UDS_VDD_RM09_SE25.rod
VCID: 6AC7D4F3DC7F10D2A14444D-803E
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 3T0 035 680 E HW: 3T0 035 680 E
Component: RNS-MID H61 3984
Revision: AB001001 Serial number: SKZ6Z7M8024060
Coding: 04000402000100810000
VCID: 32770C93342F9892D994FCD-8066
1 Fault Found:
00862 - Antenna for GPS Navigation (R50/R52)
007 - Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00100111
Fault Priority: 5
Fault Frequency: 1
Reset counter: 218
Mileage: 175859 km
Time Indication: 0
Date: 2016.05.22
Time: 10:47:46
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX3.lbl
Part No SW: 1T0 959 701 AA HW: 1T0 959 701 AA
Component: Tuer-SG 009 2119
Coding: 0004342
VCID: 76FFF08398C7C8B235FCC0D-8022
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K0 909 144 P
Component: EPS_ZFLS Kl. 69 3305
Revision: 00H22000
Shop #: WSC 20820 456 98472
VCID: 37613D87DF4D71BAEE4AB51-8062
Address 46: Central Conv.
Cannot be reached
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
Part No SW: 1T0 959 702 S HW: 1T0 959 702 S
Coding: 0004342
VCID: 48834E7BA2B30E4297B0CE5-801C
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 218
Mileage: 175859 km
Time Indication: 0
Date: 2016.05.22
Time: 10:47:46
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 5K0 959 703 A HW: 5K0 959 703 A
Component: Tuer-SG 007 2101
Coding: 0000144
Shop #: WSC 73430 790 1012573
VCID: 32770C93342F9492D994FCD-8066
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 5K0 959 704 A HW: 5K0 959 704 A
Coding: 0000144
VCID: 33790997CB359D9AD262E11-8066
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
Part No SW: 5K0 035 730 E HW: 5K0 035 730 E
Component: TELEFON H12 2902
Revision: 1B001001 Serial number: 00007661668546
Coding: 0201000000010110
ASAM Dataset: EV_UHVNA A01719
ROD: EV_UHVNA.rod
VCID: 2741EDC70FEDEDBA7EEA651-8072
End-------------------------(Elapsed Time: 02:23)--------------------------
Pomoże ktoś?
skan przed zmianami. które powodowały błąd
mój skan
2 Faults Found:
Freeze Frame:
8169 - Terminal 30
Freeze Frame:
Revision: 00H31001
Revision: 00001007
Coding: 0000000002
Cannot be reached
Coding: 108001
Coding: 0020790
Coding: 108A140000
Coding: 820000
Coding: 110E00
Coding: 352302
Coding: 000000
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 218
Mileage: 175859 km
Time Indication: 0
Date: 2016.05.22
Time: 10:47:46
Coding: 0004342
Revision: 00H22000
Cannot be reached
Coding: 0004342
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 218
Mileage: 175859 km
Time Indication: 0
Date: 2016.05.22
Time: 10:47:46
Coding: 0000144
Coding: 0000144
ROD: EV_UHVNA.rod
Pomoże ktoś?
